Thank you very much for your feedback.
What do they mean by « in your venue »? Do they want all the instance events sorted by date or is « venue » something more specific than the instance?
Well, our instance mainly has events dat are organised by and/or are held on the premises of Bosvreugd.
But more generally, What they want to see is all upcoming events on the instance (or as many as can fit on the homepage) maybe as a scrollable list/display. sorted by date. The earlies upcoming event should be displayed first on the list
A bit like the display of events from a group, as displayed below:
Currently the list of events on the homepage displays the very last event first (for us that is in december at this moment). Whatever is coming up this day/week/month is completely invisible and it is not even possible to scroll to it or have it sorted the other way round. like below screenshot:
Even when you go to the « upcoming events » You get the list sorted with the last event first, this should be sorted by the first upcoming event. Not that many visitor are already interested in the events we organise a year ahead. Nor do they want to make choices in the filter for that, it is exactly the other way round. They want to use the filter to see events later in the year, but not for the recent upcoming events.
OK that’s in scope for… Soon! I can’t commit on a date but that’s the very next step to have a default homepage which is the list of upcoming event in grid mode (no horizontal scroll). Stay tuned
Du coup je comprends pas bien comment se fait l’avancé du développement de Mobilizon ?
Qui fait quoi ? sur la base de quel retour ? ou se déroule les échanges ?
Merci pour tes questions.
En résumé:
-Kaihuri dont je fais partie centralise les développements avec le soutien financier de NLNet
-les contributions technique sont bienvenues, mais pour être sûr que nous puissions les intégrer (ce qui représente une certaine charge de travail), il faut se rapprocher de nous au préalable
-les échanges se font sur ce forum et sur le git et éventuellement sur rendez-vous pour les contributeurs techniques et représentants de communauté (ie ceux qui ont des instances avec beaucoup de contenu et d’utilisateurs)
J’espère que ça répond un peu à tes questions.
J’ajoute que le travail de Kaihuri est en énorme partie bénévole, nous utilisons principalement le financement de NLNet pour rémnuérer des développeurs freelance. Je suis à la recherche de financements afin d’allouer plus de temps à la gestion de ce projet et sa gouvernance.
Je ne sais pas où vous en êtes, mais dans la toute dernières version on a ajouter la possibilité de mettre des “external links” dans le menu. On peut aussi tout a fait mettre des liens vers des recherches précises de sa propre instance.
Tu pourrais donc ajouter dans le menu du haut “Strasbourg”, “Mulhouse” et renvoyer vers des recherches localisées (ex pour Mulhouse: Keskonfai - Mobilizon )
Pour populariser une adresse web avec des résultats de recherches, il faut qu’elle soit courte, mais aussi cohérente pour être facilement mémorisable (transmissible à l’orale).
Là, on se retrouve avec une liste trop longue de variables dans l’adresse web : ”/search?locationName=Mulhouse&lat=47.7467233&lon=7.3389937&distance=25_km&contentType=EVENTS&eventPage=1”.
Je soutiens à 200% l’utilisation de tags, pour retrouver des évènements et partager des adresses web, comme évoqué dans ce fil de discussion, mais aussi par derf, dans celui-ci : Which changes and fixes would you like? - #12 par derf
Une fois que les tags ne seront plus sensibles à casse, et seront donc exploitables, en plus d’url du genre mobilizon.fr/tag/xxx, il serait très utile de pouvoir aussi en proposer avec des tags combinés, je trouve, du genre mobilizon.fr/tag/nantes+sport ou mobilizon.fr/tag/LoireAtlantique+musique+sam29nov25, ou encore mobilizon.fr/tag/35+44+56, pour avoir une liste des évènements se déroulant dans ces 3 départements, si on est au croisement de l’Ille-et-Vilaine, de la Loire-Atlantique et du Morbihan, par exemple.
Et de pouvoir sélectionner directement ensuite la visualisation des résultats de recherche sous format liste ou calendrier.
C’est vraiment ce qui manque pour pouvoir rendre Mobilizon adoptable par un plus large public, à mon sens, et cela représente donc à mes yeux, la top des priorités.
Il y a plusieurs sujets dans ton post - je ne sais pas si tous sont créés comme issue dans le git, et sinon je t’invite à le faire.
Concernant les URL qui contiennent de nombreuses variables par exemple, je ne sais pas si elles sont “simplifiable” techniquement, mais je n’ai trouvé aucune entrée dans le git à ce sujet (en cherchant sur “URL”).
