Mobilizon capacity
We are considering using Mobilizon as part of a large-scale project, potentially involving several hundred thousand participants.
Can the platform handle such a load? What technical infrastructure would be required?
Hi Paul
We currently know tow big instances :
  • mobilizon.fr has 13k users and 30k events, operated by Framasoft, maybe @tcit can give you some information about the hardware they use for
  • keskonfai.fr has 600 users and 600k events, operated by Kaihuri (here speaking :slight_smile: ). We use to have this instance on a wheezy Intel Atom CPU N2800 1.86GHz and 4GB RAM, mechanical HDD, built in 2012, and it was fine. We now use a beefy Intel Xeon CPU E3-1245-V2 3.40GHz and 32GB RAM, SSD, also built in 2012. And the server has currently a load of 0.5/8 while hosting several other services.
I’m pretty confident with the Application holding 100k users on a quite modest machine.
The current server is an AX41-NVME , but that’s really much much more than what’s needed for the current use of the service, because we have Sentry on the same server (for many other uses than Mobilizon) and it uses much more the system. Load for all that is around 2/12.
