More audio options
I would appreciate a little bit more focus on audio - processing - resolutions and info:
  1. please provide audio parameters (bit depth and bit rate and sample rate) in the STATS FOR NERDS option when right clicking a video
  2. provide more audio processing options and preferably more codecs.
Just upgraded to PT 9.0 RC and will test that - but the previous version re sampled my original audio down to 128 - what I don’t want.
I produce a lot of music video’s - classical, jazz etc etc and the original audio is HR lossless - I would prefer the audio to stay in that format.
NB there is a plug in but I have to test more in depth because the results are not there. Maybe because PT does not provide any AUDIO options (only for video… but that’s a blind spot: audio is equally as important ).
Can you send me your audio if v9 still sample it to 128?
you can check here and download the files: original and rendered:
And I have upoloaded more tests: latest is (on 9.0) with the ultimate audio plug in and separate audio, rendered with audio pass through to a MOV with FLAC 512 kbps file:
PS it would be great if you can monitor rendered audio quality of the files you play with STATS for NERDS. It is very cumbersome to find info of streaming audio quality in a browser (developer tools, but lately something changed and I get no MEDIA info of the audio playing in ant browser…)
and there are more here:
sounds - EarthshipTV.nl
