For some videos on my instance uploads to object storage fails with:
Job: 254 Type: move-to-object-storage Processed on 7/20/23, 5:54:56.155 AM Finished on 7/20/23, 5:55:19.994 AM
{ "videoUUID": "3773fafa-6c3b-4791-aea8-57f96660dd53", "isNewVideo": true, "previousVideoState": 2 }
Error [ERR_STREAM_WRITE_AFTER_END]: write after end
at new NodeError (node:internal/errors:387:5)
at ClientRequest.end (node:_http_outgoing:968:15)
at writeBody (/app/node_modules/@aws-sdk/node-http-handler/dist-cjs/write-request-body.js:22:21)
at ClientRequest.<anonymous> (/app/node_modules/@aws-sdk/node-http-handler/dist-cjs/write-request-body.js:9:13)
at ClientRequest.emit (node:events:513:28)
at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:635:11)
at HTTPParser.parserOnHeadersComplete (node:_http_common:128:17)
at TLSSocket.socketOnData (node:_http_client:534:22)
at TLSSocket.emit (node:events:513:28)
at addChunk (node:internal/streams/readable:315:12)
at readableAddChunk (node:internal/streams/readable:289:9)
at TLSSocket.Readable.push (node:internal/streams/readable:228:10)
at TLSWrap.onStreamRead (node:internal/stream_base_commons:190:23)
After running create-move-video-storage-job the video got uploaded successfully to object store but master playlist is still on local storage. The video is now stuck in TO MOVE TO AN EXTERNAL STORAGE state and can’t be played.
I tried downloading the video files from object store to local store, reset state in database and run the script again - without success. The video is stuck in mentioned state, videos got uploaded and master playlist is still in local store.
Any help with this is highly appreciated.
