I have a problem when there are 1k-2k visitors to the live stream, the site does not open, it opens from the 3rd-5th page refresh. What optimizations could I do to nginx so that the site opens to more than 2k visitors?
Can you provide some PeerTube logs? Do you know what is the bottleneck? CPU? Network? Nginx? PeerTube?
The logs were not saved, the processor was used somewhere at 50%, the player worked well, network traffic 60%, I intuit that the problem is in nginx because many times it shows me bad gateway and sometimes the site opens but does not display the live streams. I moved the folder /var/www/peertube/storage/streaming-playlists to ram (tmpfs) so it’s not a problem in SSD.
Okay thanks. Unfortunately I can’t help without nginx logs and peertube logs.
You need to increase nginx worker connections. See What are worker_connections in Nginx
Thanks for the help, I added it manually in nginx.conf
worker_processes 16;
events {
worker_connections 1024;
use epoll;
multi_accept on;
I hope it helps, does it make sense to add the last 2 lines?
worker_connections 1024 is the nginx default on nginx mainline.
I would keep worker_processes on auto and set worker_connections to 5000-10000. You’ll need to modify the /etc/security/limits.conf accordingly.
I increased the number of worker_connections to 65535 in nginx and in the system, the errors with worker_connections disappeared from the logs, but anyway it is very difficult to display the streams at 1.5-2k views.
In htop I noticed that the problem appears when 1 or 2 cores reach 100% usage.
And when I access the website, it opens quickly, but it is very difficult to display the live streams.
I use PeerTube version 4.2.1
I don’t see any errors in nginx, but in peertube there are a lot like:
2022/11/23 13:55:58 [error] 1382#1382: *14203100 open() "/var/www/peertube/storage/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0-007925.ts" failed (2: No such file or directory), client: 185.181.230.179, server: stream.trm.md, request: "GET /static/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0-007925.ts HTTP/2.0", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c?peertubeLink=0"
2022/11/23 13:55:58 [error] 1395#1395: *14061335 open() "/var/www/peertube/storage/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0-008818.ts" failed (2: No such file or directory), client: 89.32.232.82, server: stream.trm.md, request: "GET /static/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0-008818.ts HTTP/2.0", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c?peertubeLink=0"
2022/11/23 13:55:58 [error] 1382#1382: *14183099 open() "/var/www/peertube/storage/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0-012007.ts" failed (2: No such file or directory), client: 95.65.58.192, server: stream.trm.md, request: "GET /static/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0-012007.ts HTTP/2.0", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c"
2022/11/23 13:55:58 [error] 1382#1382: *14069482 open() "/var/www/peertube/storage/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0-008154.ts" failed (2: No such file or directory), client: 93.116.73.210, server: stream.trm.md, request: "GET /static/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0-008154.ts HTTP/2.0", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c?peertubeLink=0"
2022/11/23 13:55:59 [crit] 1382#1382: *13506201 connect() to 127.0.0.1:9000 failed (99: Cannot assign requested address) while connecting to upstream, client: 178.168.109.69, server: stream.trm.md, request: "GET /live/segments-sha256/dd7acba9-2151-4415-8751-5d08a342340c HTTP/2.0", upstream: "http://127.0.0.1:9000/live/segments-sha256/dd7acba9-2151-4415-8751-5d08a342340c", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c"
2022/11/23 13:55:59 [crit] 1392#1392: *14105418 connect() to 127.0.0.1:9000 failed (99: Cannot assign requested address) while connecting to upstream, client: 178.168.119.65, server: stream.trm.md, request: "POST /api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views HTTP/2.0", upstream: "http://127.0.0.1:9000/api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c?peertubeLink=0"
2022/11/23 13:55:59 [crit] 1392#1392: *13403932 connect() to 127.0.0.1:9000 failed (99: Cannot assign requested address) while connecting to upstream, client: 178.168.121.225, server: stream.trm.md, request: "POST /api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views HTTP/2.0", upstream: "http://127.0.0.1:9000/api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c?peertubeLink=0"
2022/11/23 13:55:59 [crit] 1382#1382: *14254746 connect() to 127.0.0.1:9000 failed (99: Cannot assign requested address) while connecting to upstream, client: 91.211.51.119, server: stream.trm.md, request: "POST /api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views HTTP/2.0", upstream: "http://127.0.0.1:9000/api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c"
2022/11/23 13:55:59 [crit] 1382#1382: *13855722 connect() to 127.0.0.1:9000 failed (99: Cannot assign requested address) while connecting to upstream, client: 46.166.62.7, server: stream.trm.md, request: "POST /api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views HTTP/2.0", upstream: "http://127.0.0.1:9000/api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c?peertubeLink=0"
2022/11/23 13:55:59 [crit] 1392#1392: *14104363 connect() to 127.0.0.1:9000 failed (99: Cannot assign requested address) while connecting to upstream, client: 86.105.57.10, server: stream.trm.md, request: "POST /api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views HTTP/2.0", upstream: "http://127.0.0.1:9000/api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c?peertubeLink=0"
2022/11/23 13:55:59 [crit] 1392#1392: *14058239 connect() to 127.0.0.1:9000 failed (99: Cannot assign requested address) while connecting to upstream, client: 89.28.67.105, server: stream.trm.md, request: "POST /api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views HTTP/2.0", upstream: "http://127.0.0.1:9000/api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c?peertubeLink=0"
2022/11/23 13:55:59 [crit] 1392#1392: *14040687 connect() to 127.0.0.1:9000 failed (99: Cannot assign requested address) while connecting to upstream, client: 89.32.230.50, server: stream.trm.md, request: "POST /api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views HTTP/2.0", upstream: "http://127.0.0.1:9000/api/v1/videos/dd7acba9-2151-4415-8751-5d08a342340c/views", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c?peertubeLink=0"
2022/11/23 13:55:59 [error] 1392#1392: *14252025 open() "/var/www/peertube/storage/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0-008094.ts" failed (2: No such file or directory), client: 185.33.106.97, server: stream.trm.md, request: "GET /static/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0-008094.ts HTTP/2.0", host: "stream.trm.md", referrer: "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c?peertubeLink=0"
From changes in nginx I added this:
worker_rlimit_nofile 65535;
events {
worker_connections 65535;
use epoll;
multi_accept on;
Check peertube logs to see why nginx can’t connect to it
I updated to version 4.3.1, but now no peer appears, everything is downloaded directly from the server.
In the error logs I see this:
error[23/11/2022, 23:26:57] Client log: Cannot get sha256 segments
"tags": [
"client"
"userAgent": "Mozilla/5.0 (Linux; Android 10; Redmi 7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Mobile Safari/537.36",
"stackTrace": "Unexpected end of JSON input\nSyntaxError: Unexpected end of JSON input",
"url": "https://stream.trm.md/videos/embed/dd7acba9-2151-4415-8751-5d08a342340c"
error[23/11/2022, 23:45:00] Client log: HLS.js error: mediaError - fatal: false - bufferStalledError
"tags": [
"client"
"userAgent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36",
"meta": "{\"data\":{\"type\":\"mediaError\",\"details\":\"bufferStalledError\",\"fatal\":false,\"buffer\":3.387165999999999}}",
error[23/11/2022, 23:39:55] Client log: HLS.js error: networkError - fatal: false - fragLoadError
"tags": [
"client"
"meta": "{\"data\":{\"type\":\"networkError\",\"details\":\"fragLoadError\",\"fatal\":false,\"frag\":{\"_byteRange\":null,\"_url\":\"https://stream.trm.md/static/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0-000182.ts\",\"baseurl\":\"https://stream.trm.md/static/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/0.m3u8\",\"relurl\":\"0-000182.ts\",\"elementaryStreams\":{\"audio\":null,\"video\":null,\"audiovideo\":null},\"_decryptdata\":null,\"rawProgramDateTime\":\"2022-11-23T23:39:03.680+0200\",\"programDateTime\":1669239543680,\"tagList\":[[\"INF\",\"4.760000\"],[\"PROGRAM-DATE-TIME\",\"2022-11-23T23:39:03.680+0200\"]],\"duration\":4.76,\"sn\":182,\"type\":\"main\",\"loader\":null,\"level\":0,\"cc\":0,\"start\":536.6798333333334,\"stats\":{\"loaded\":564,\"total\":564,\"aborted\":false,\"retry\":0,\"chunkCount\":0,\"bwEstimate\":0,\"loading\":{\"start\":533380.3,\"end\":0,\"first\":533380.3},\"parsing\":{\"start\":0,\"end\":0},\"buffering\":{\"start\":0,\"end\":0,\"first\":0}},\"urlId\":0,\"bitrateTest\":false,\"title\":null,\"initSegment\":null},\"response\":{\"isTrusted\":true}}}",
error[23/11/2022, 23:39:55] Client log: Segment https://stream.trm.md/static/streaming-playlists/hls/dd7acba9-2151-4415-8751-5d08a342340c/master.m3u8+V0+183 error.
"tags": [
"client"
"meta": "{\"isTrusted\":true}",
I moved the stream to another server, version 4.3.0 was installed cleanly, and I have the same problem, when I reach 2k viewers in real time on the live stream, I moved the hls folder to ram (tmpfs). When I access the site with 2k - 2.5k viewers, it gives me the error 502 (Bad Gateway):
Peertube error:
Line 383136: 2022/11/24 21:47:22 [crit] 1323#1323: *15695864 connect() to 127.0.0.1:9000 failed (99: Unknown error) while connecting to upstream, client: 192.168.10.222, server: media.trm.md, request: "GET / HTTP/2.0", upstream: "http://127.0.0.1:9000/", host: "media.trm.md"
Line 383269: 2022/11/24 21:47:22 [crit] 1323#1323: *15695864 connect() to 127.0.0.1:9000 failed (99: Unknown error) while connecting to upstream, client: 192.168.10.222, server: media.trm.md, request: "GET /favicon.ico HTTP/2.0", upstream: "http://127.0.0.1:9000/favicon.ico", host: "media.trm.md", referrer: "https://media.trm.md/"
Line 386245: 2022/11/24 21:47:25 [crit] 1323#1323: *15695864 connect() to 127.0.0.1:9000 failed (99: Unknown error) while connecting to upstream, client: 192.168.10.222, server: media.trm.md, request: "GET / HTTP/2.0", upstream: "http://127.0.0.1:9000/", host: "media.trm.md"
Line 387459: 2022/11/24 21:47:27 [crit] 1323#1323: *15695864 connect() to 127.0.0.1:9000 failed (99: Unknown error) while connecting to upstream, client: 192.168.10.222, server: media.trm.md, request: "GET / HTTP/2.0", upstream: "http://127.0.0.1:9000/", host: "media.trm.md"
Line 388435: 2022/11/24 21:47:28 [crit] 1323#1323: *15695864 connect() to 127.0.0.1:9000 failed (99: Unknown error) while connecting to upstream, client: 192.168.10.222, server: media.trm.md, request: "GET / HTTP/2.0", upstream: "http://127.0.0.1:9000/", host: "media.trm.md"
Line 389312: 2022/11/24 21:47:29 [crit] 1323#1323: *15695864 connect() to 127.0.0.1:9000 failed (99: Unknown error) while connecting to upstream, client: 192.168.10.222, server: media.trm.md, request: "GET / HTTP/2.0", upstream: "http://127.0.0.1:9000/", host: "media.trm.md"
Line 390198: 2022/11/24 21:47:30 [crit] 1323#1323: *15695864 connect() to 127.0.0.1:9000 failed (99: Unknown error) while connecting to upstream, client: 192.168.10.222, server: media.trm.md, request: "GET / HTTP/2.0", upstream: "http://127.0.0.1:9000/", host: "media.trm.md"
Nginx error, it’s because of geoblocking:
2022/11/24 21:47:14 [error] 1328#1328: OCSP responder timed out (110: Unknown error) while requesting certificate status, responder: r3.o.lencr.org, peer: 84.53.161.192:80, certificate: "/etc/letsencrypt/live/media.trm.md/fullchain.pem"
2022/11/24 21:47:50 [error] 1321#1321: OCSP responder timed out (110: Unknown error) while requesting certificate status, responder: r3.o.lencr.org, peer: 84.53.161.192:80, certificate: "/etc/letsencrypt/live/media.trm.md/fullchain.pem"
2022/11/24 21:48:00 [error] 1323#1323: OCSP responder timed out (110: Unknown error) while requesting certificate status, responder: r3.o.lencr.org, peer: 84.53.161.192:80, certificate: "/etc/letsencrypt/live/media.trm.md/fullchain.pem"
I intuit that the problem is that the peertube process uses only one core, and when this process reaches 95%-98%, these problems appear for me.
The problem is not in cpu/ram/hdd/network resources, out of 4Gb peertube channel uses only 2.5-3.5Gb.
Is it somehow possible to implement a cache for displaying the site or the player? something like fastcgi cache and proxy cache?
This should already be the case, thanks to the nginx configuration.
For example:
(and other similar nginx locations)
Can you try to profile peertube?
Restart PeerTube using --inspect option (node --inspect dist/server) on server
Run ssh -L 9229:127.0.0.1:9229 name@host on your computer
Run Chrome and go on chrome://inspect using search bar
Profile the application while you stream for a few seconds and send me by private message the profile file
