I’m trying to fix federation in my Dockerized PeerTube instance by following this:
https://docs.joinpeertube.org/#/maintain-tools?id=update-hostjs
I’m running this in Docker so I sudo docker exec -it peertube
, and then when inside the container, I do NODE_CONFIG_DIR=/app/config NODE_ENV=production npm run reset-password -- -u target_username
. The problem is, when I do that, I get this:
npm ERR! code ENOENT
npm ERR! syscall open
npm ERR! path /package.json
npm ERR! errno -2
npm ERR! enoent ENOENT: no such file or directory, open '/package.json'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2020-05-22T17_49_41_513Z-debug.log
So it can’t find package.json
, but package.json
is in /app
. How do I get it to see package.json
