OTP: Missing two factor header / Status Code 401
Hello guys
Installed latest PeerTube via Docker today, and so far it is great. Unfortunately, after enabling OTP in the User Interface, log out and trying to log in again, I am presented status code 401 instead of a field to enter the OTP.
Anything I miss?
production.yaml:
listen:
  hostname: '0.0.0.0'
  port: 9000
# Correspond to your reverse proxy server_name/listen configuration
webserver:
  https: true
  hostname: tube.redacted.com
  port: 443
# Proxies to trust to get real client IP
# If you run PeerTube just behind a local proxy (nginx), keep 'loopback'
# If you run PeerTube behind a remote proxy, add the proxy IP address (or subnet)
trust_proxy:
  - 'loopback'
tracker:
  enabled: false
federation:
  # Enable ActivityPub endpoints (inbox/outbox)
  enabled: false
signup:
  enabled: false
  # When the total number of users in your instance reaches this limit, registrations are disabled.
  # -1 == unlimited
  limit: 10
  minimum_age: 16 # Used to configure the signup form
  # Users fill a form to register so moderators can accept/reject the registration
  requires_approval: true
  requires_email_verification: true
secrets:
  peertube: 'redacted'
Can you paste the URL of your instance?
Thanks for your reply. Well, I’d prefer not to publish the URL, as the instance is for personal / friends / family use only (central management of educational videos). Therefore, access is also heavily restricted by the firewall / WAF.
Any ideas maybe with regards to configuration? I assume OTP completely runs on premise and does not need a separate container etc?
Seems like related to missing otp header (or content)?
[peertube.sample.com:443] 2025-03-20 13:01:44.773 debug: Missing two factor error {
  "err": {
    "stack": "missing_two_factor: Missing two factor header\n    at handlePasswordGrant (file:///app/dist/core/lib/auth/oauth.js:124:19)\n    at async handleToken (file:///app/dist/core/controllers/api/users/token.js:32:23)",
    "message": "Missing two factor header",
    "code": 401,
    "name": "missing_two_factor"
In the documentation it says OTP value must be passed in the header x-peertube-otp. I assume this is done automatically? But, I am missing even the field to enter OTP.
Nvm, no problem with other reverse proxy. You can close this topic pls, as it is not an issue originating from peertube. Thx.
