On Ubuntu 18.04, with PeerTube 3.1.0 with a remote PostgreSQL instance, when I run:
sudo journalctl -feu peertube
I am getting the error pasted below. The odd thing is that production.yaml specifies ssl: true however, the error message indicates SSL off. Also, the database host is specified as foobar.postgres.database.azure.com (but the address IP resolves to 40.127.XXX.YYY).
Indeed, the following works:
psql -h foobar.postgres.database.azure.com -p 5432 -U lokad peertube -W
But the following does not work:
psql -h 40.127.XXX.YYY -p 5432 -U lokad peertube -W
It’s seem that PeerTube does an IP resolution which prevent the SSL connection to work.
Can someone help be to get this working?
Best regards,
Joannes
Apr 16 15:53:12 tube-lokad systemd[1]: peertube.service: Service hold-off time over, scheduling restart. Apr 16 15:53:12 tube-lokad systemd[1]: peertube.service: Scheduled restart job, restart counter is at 133. Apr 16 15:53:12 tube-lokad systemd[1]: Stopped PeerTube daemon. Apr 16 15:53:12 tube-lokad systemd[1]: Started PeerTube daemon. Apr 16 15:53:12 tube-lokad peertube[2551]: > peertube@3.1.0 start /var/www/peertube/versions/peertube-v3.1.0 Apr 16 15:53:12 tube-lokad peertube[2551]: > node dist/server Apr 16 15:53:13 tube-lokad systemd[1]: Stopping PeerTube daemon... Apr 16 15:53:13 tube-lokad systemd[1]: Stopped PeerTube daemon. Apr 16 15:53:22 tube-lokad systemd[1]: Started PeerTube daemon. Apr 16 15:53:22 tube-lokad peertube[2618]: > peertube@3.1.0 start /var/www/peertube/versions/peertube-v3.1.0 Apr 16 15:53:22 tube-lokad peertube[2618]: > node dist/server Apr 16 15:53:25 tube-lokad peertube[2618]: [tube.lokad.com:443] 2021-04-16 15:53:25.187 warn: Emailer is disabled so the contact form will not work. Apr 16 15:53:25 tube-lokad peertube[2618]: [tube.lokad.com:443] 2021-04-16 15:53:25.634 error: Unable to connect to PostgreSQL database. { Apr 16 15:53:25 tube-lokad peertube[2618]: "err": { Apr 16 15:53:25 tube-lokad peertube[2618]: "stack": "SequelizeConnectionError: no pg_hba.conf entry for host \"40.127.XXX.YYY\", user \"lokad\", database \"peertube\", SSL off\n at Client._connectionCallback (/var/www/peertube/versions/peertube-v3.1.0/node_modules/sequelize/lib/dialects/postgres/connection-manager.js:184:24)\n at Client._handleErrorWhileConnecting (/var/www/peertube/versions/peertube-v3.1.0/node_modules/pg/lib/client.js:305:19)\n at Client._handleErrorMessage (/var/www/peertube/versions/peertube-v3.1.0/node_modules/pg/lib/client.js:325:19)\n at Connection.emit (events.js:314:20)\n at /var/www/peertube/versions/peertube-v3.1.0/node_modules/pg/lib/connection.js:115:12\n at Parser.parse (/var/www/peertube/versions/peertube-v3.1.0/node_modules/pg-protocol/dist/parser.js:40:17)\n at Socket.<anonymous> (/var/www/peertube/versions/peertube-v3.1.0/node_modules/pg-protocol/dist/index.js:10:42)\n at Socket.emit (events.js:314:20)\n at addChunk (_stream_readable.js:297:12)\n at readableAddChunk (_stream_readable.js:272:9)\n at Socket.Readable.push (_stream_readable.js:213:10)\n at TCP.onStreamRead (internal/stream_base_commons.js:188:23)", Apr 16 15:53:25 tube-lokad peertube[2618]: "message": "no pg_hba.conf entry for host \"40.127.111.54\", user \"lokad\", database \"peertube\", SSL off", Apr 16 15:53:25 tube-lokad peertube[2618]: "name": "SequelizeConnectionError", Apr 16 15:53:25 tube-lokad peertube[2618]: "parent": { Apr 16 15:53:25 tube-lokad peertube[2618]: "stack": "error: no pg_hba.conf entry for host \"40.127.111.54\", user \"lokad\", database \"peertube\", SSL off\n at Parser.parseErrorMessage (/var/www/peertube/versions/peertube-v3.1.0/node_modules/pg-protocol/dist/parser.js:278:15)\n at Parser.handlePacket (/var/www/peertube/versions/peertube-v3.1.0/node_modules/pg-protocol/dist/parser.js:126:29)\n at Parser.parse (/var/www/peertube/versions/peertube-v3.1.0/node_modules/pg-protocol/dist/parser.js:39:38)\n at Socket.<anonymous> (/var/www/peertube/versions/peertube-v3.1.0/node_modules/pg-protocol/dist/index.js:10:42)\n at Socket.emit (events.js:314:20)\n at addChunk (_stream_readable.js:297:12)\n at readableAddChunk (_stream_readable.js:272:9)\n at Socket.Readable.push (_stream_readable.js:213:10)\n at TCP.onStreamRead (internal/stream_base_commons.js:188:23)", Apr 16 15:53:25 tube-lokad peertube[2618]: "message": "no pg_hba.conf entry for host \"40.127.111.54\", user \"lokad\", database \"peertube\", SSL off", Apr 16 15:53:25 tube-lokad peertube[2618]: "length": 152, Apr 16 15:53:25 tube-lokad peertube[2618]: "name": "error", Apr 16 15:53:25 tube-lokad peertube[2618]: "severity": "FATAL", Apr 16 15:53:25 tube-lokad peertube[2618]: "code": "28000", Apr 16 15:53:25 tube-lokad peertube[2618]: "file": "auth.c", Apr 16 15:53:25 tube-lokad peertube[2618]: "line": "502", Apr 16 15:53:25 tube-lokad peertube[2618]: "routine": "ClientAuthentication" Apr 16 15:53:25 tube-lokad peertube[2618]: } Apr 16 15:53:25 tube-lokad peertube[2618]: } Apr 16 15:53:25 tube-lokad peertube[2618]: } Apr 16 15:53:25 tube-lokad peertube[2618]: npm ERR! code ELIFECYCLE Apr 16 15:53:25 tube-lokad peertube[2618]: npm ERR! errno 255 Apr 16 15:53:25 tube-lokad peertube[2618]: npm ERR! peertube@3.1.0 start:node dist/serverApr 16 15:53:25 tube-lokad peertube[2618]: npm ERR! Exit status 255 Apr 16 15:53:25 tube-lokad peertube[2618]: npm ERR! Apr 16 15:53:25 tube-lokad peertube[2618]: npm ERR! Failed at the peertube@3.1.0 start script. Apr 16 15:53:25 tube-lokad peertube[2618]: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
