Hello everyone, I would like to know if there is a possibility to use Oracle as a database instead of PostgreSQL. I know that in the official documentation PostgreSQL is used and I don’t see anything referring to Oracle.
If so, I would like to know the steps I should follow or modify in my configuration to achieve this, if I have to create a schema, etc.
If it is only intended to use PostgreSQL I would also like to know so I don’t try tests that don’t get me anywhere.
Thank you very much
