Peertube's mascot
Hey,
As you might remember, I started long ago; in june 2018 a work on designing a mascot for Peertube. It all started with polls over social medias, and the first confusion I massively seen was audience mixing logo and mascot. So, for starting this thread on good base:
« A mascot is any person, animal, or object thought to bring luck, or anything used to represent a group with a common public identity » ~ Wikipedia mascot page
I like mascots, they make documentations funnier to read; they decorate contents sometime a bit too serious (404 pages, error messages), they also creates item to collect or to wear.
So, it started like that:
and quickly the poll elected the tiny octopus
but I wanted to push the design further, and get something a bit more in relation with the logo. But I just get confused, not happy about the design and about my art technique for rendering it. Also, the test of the cubic TV on left was misunderstood to be a microwave from the generation who knew only flat TV and monitors.
I eventually continued later on my sketchbook with tests until I finally was happy with this one:
The latest mystery for me was « how to render it? ». If I paint it; it will be hard to maintain because I would be the only one to generate new derivation of the mascot, and for sustainability of the design, I disliked the idea. It took time until I realise I should try with Inkscape with flat vectors.
2019-10-28_peery
This way, all the parts are easy to combine, rotate like a muppet made of paper shapes.
The source SVG is here:
https://www.peppercarrot.com/extras/temp/drawing.svg
I plan to release it under the same license than Peertube, GPLv3.0. I usually goes with CC-By but I don’t want to be attributed on any usage of the mascot.
What do you think about it?
This is so awesome !
I’m in love ! Thanks, @Deevad
Awesome!
So it’s more like a cuttlefish with the triangular “head” ! I like that 7774507576_2104186ca8_b|653x500
@Deevad cute, original and unforgettable: love it!
Looks awesome! Great job.
love it too :smiley:
I love it! :heart_eyes: Excellent work! :+1:
:octopus:
Damn! Can’t they be taught something about the past maybe? This one is really a work of art… the triangle head looks weird because it’s too rigid… needs to be more organic…Like separate overlapping triangles like it’s hair, or thought bubbles, or something…?
Wow ! Realy stunning works ! :heart_eyes:
So we have landed on a name for this mascott, and it is…
:drum: :drum: :drum:
Sepia
(thanks @goofy for suggesting it)
It is both a color that remind of old movies and a latin radical for the cuttlefish, so it seems fitting.
BTW, we (at Framasoft) won’t make any PeerTube merch, but fortunately @Deevad has opened a shop (and I know he’s shy and won’t plug it so I’m doing it), and you’ll find Sepia on clothes, prints, etc. on this link.
Hello @Deevad.
I’m going to use your work for buttons in my plugin peertube-plugin-livechat (https://github.com/JohnXLivingston/peertube-plugin-livechat)
What is the current license for your work? How can I credit you?
My plugin use the license GNU AFFERO, because it is the one in the peertube-plugin-quickstart repository. Have I to change this license for something else? (GPL?)
AGPL is compatible with GPL, and PeerTube’s licence is AGPL anyway.
Hi @JohnLivingston, the license is CC-By ( 4.0 International, for the details; https://creativecommons.org/licenses/by/4.0/ ).
For the credit, simply to « David Revoy », and I’m fine if it’s in README somewhere at the end or in the footer of GUI in very small :wink:
(TIL today: GNU Affero General Public License v3.0, thanks for that!)
That’s for the SVGs of the mascott (the vector files and its derivatives) to ease inclusion inside the software/documentation.
The character design as an illustration is CC-By: it ease my own reusage in recent CC-By illustrations.
I hope it clarify the situation a bit. Sorry if it was fuzzy :sweat_smile:
What link to your work can I put in my readme?
I used this file https://www.peppercarrot.com/extras/temp/drawing.svg, and I’m modifying it to adapt to my buttons. I will show you as soon at it is comitted.
Ideal link: https://www.davidrevoy.com/index.php?tag/peertube maybe if you want a Peertube specific one with article that mention the CC-By.
