Please explain these errors, is it normal?
Hello everyone, please explain these errors to me. As I understand it, this is due either to an unstable connection of the client, or if it minimizes the browser after browsing, and then after some time it starts watching again (but these are my guesses). Perhaps the Samsung browser mobile version behaves like this, although it is on others, but less often. Also in version 6.2 this led to slowdowns and freezes, now there have been no complaints yet, but I would like to understand if this can be fixed as a way to fix it, Or give recommendations to customers, for example? Thank you
warn[07.08.2024, 23:12:35] Client log: HLS.js error: mediaError - fatal: false - bufferStalledError
  "tags": [
    "client"
  "username": "raisabulkina2035",
  "userAgent": "Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) SamsungBrowser/25.0 Chrome/121.0.0.0 Mobile Safari/537.36",
  "url": "https://angeltales.angellive.ru/w/p/kNEeFRJjFJa9LQRhB7ao16?playlistPosition=3&resume=true"
warn[07.08.2024, 23:13:19] Client log: HLS.js error: mediaError - fatal: false - bufferStalledError
  "tags": [
    "client"
warn[07.08.2024, 23:13:20] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
  "tags": [
    "client"
warn[07.08.2024, 23:13:22] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
warn[07.08.2024, 23:17:02] Client log: HLS.js error: mediaError - fatal: false - bufferStalledError
  "tags": [
    "client"
warn[07.08.2024, 23:17:02] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
warn[07.08.2024, 23:17:06] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
warn[07.08.2024, 23:17:07] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
  "tags": [
    "client"
warn[07.08.2024, 23:17:07] Client log: HLS.js error: mediaError - fatal: false - bufferStalledError
  "tags": [
    "client"
warn[07.08.2024, 23:17:08] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
warn[07.08.2024, 23:18:32] Client log: HLS.js error: mediaError - fatal: false - bufferStalledError
  "tags": [
    "client"
warn[07.08.2024, 23:18:36] Client log: HLS.js error: mediaError - fatal: false - bufferStalledError
  "tags": [
    "client"
warn[07.08.2024, 23:18:38] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
warn[07.08.2024, 23:18:41] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
warn[07.08.2024, 23:18:46] Client log: HLS.js error: mediaError - fatal: false - bufferStalledError
  "tags": [
    "client"
warn[07.08.2024, 23:18:48] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
warn[07.08.2024, 23:18:50] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
warn[07.08.2024, 23:18:54] Client log: HLS.js error: mediaError - fatal: false - bufferStalledError
  "tags": [
    "client"
warn[07.08.2024, 23:18:58] Client log: HLS.js error: mediaError - fatal: false - bufferStalledError
  "tags": [
    "client"
warn[07.08.2024, 23:19:00] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
warn[07.08.2024, 23:19:02] Client log: HLS.js error: mediaError - fatal: false - bufferNudgeOnStall
  "tags": [
    "client"
And also this type of mistakes?
error[07.08.2024, 23:29:17] Client log: Segment https://angeltales.angellive.ru/static/streaming-playlists/hls/private/67a80540-d692-45a8-aefd-55da003701b1/8e84b5e2-34eb-4ff7-a7f9-962c85361206-master.m3u8+V1+24 error.
  "tags": [
    "client"
  "meta": "{\"isTrusted\":true}",
  "url": "https://angeltales.angellive.ru/w/p/kNEeFRJjFJa9LQRhB7ao16?playlistPosition=4"
error[07.08.2024, 23:31:16] Client log: Segment https://angeltales.angellive.ru/static/streaming-playlists/hls/private/67a80540-d692-45a8-aefd-55da003701b1/8e84b5e2-34eb-4ff7-a7f9-962c85361206-master.m3u8+V1+24 error.
  "tags": [
    "client"
error[07.08.2024, 23:33:34] Client log: Segment https://angeltales.angellive.ru/static/streaming-playlists/hls/private/67a80540-d692-45a8-aefd-55da003701b1/8e84b5e2-34eb-4ff7-a7f9-962c85361206-master.m3u8+V1+24 error.
  "tags": [
    "client"
error[07.08.2024, 23:34:04] Client log: Segment https://angeltales.angellive.ru/static/streaming-playlists/hls/private/67a80540-d692-45a8-aefd-55da003701b1/8e84b5e2-34eb-4ff7-a7f9-962c85361206-master.m3u8+V1+24 error.
  "tags": [
    "client"
warn[07.08.2024, 23:35:33] Warning in tracker.
  "err": {
    "stack": "Error: WebSocket is not open: readyState 2 (CLOSING)\n    at sendAfterClose (/var/www/peertube/versions/peertube-v6.2.1/node_modules/ws/lib/websocket.js:1128:17)\n    at WebSocket.send (/var/www/peertube/versions/peertube-v6.2.1/node_modules/ws/lib/websocket.js:460:7)\n    at file:///var/www/peertube/versions/peertube-v6.2.1/node_modules/@peertube/bittorrent-tracker-server/server.js:489:16\n    at file:///var/www/peertube/versions/peertube-v6.2.1/node_modules/@peertube/bittorrent-tracker-server/server.js:645:25\n    at Server.filter [as _filter] (file:///var/www/peertube/versions/peertube-v6.2.1/dist/core/controllers/tracker.js:50:13)\n    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)",
    "message": "WebSocket is not open: readyState 2 (CLOSING)"
error[07.08.2024, 23:37:12] Client log: Segment https://angeltales.angellive.ru/static/streaming-playlists/hls/private/67a80540-d692-45a8-aefd-55da003701b1/8e84b5e2-34eb-4ff7-a7f9-962c85361206-master.m3u8+V1+24 error.
  "tags": [
    "client"
error[07.08.2024, 23:38:06] Client log: Segment https://angeltales.angellive.ru/static/streaming-playlists/hls/private/67a80540-d692-45a8-aefd-55da003701b1/8e84b5e2-34eb-4ff7-a7f9-962c85361206-master.m3u8+V1+24 error.
  "tags": [
    "client"
error[07.08.2024, 23:38:30] Client log: Segment https://angeltales.angellive.ru/static/streaming-playlists/hls/private/67a80540-d692-45a8-aefd-55da003701b1/8e84b5e2-34eb-4ff7-a7f9-962c85361206-master.m3u8+V1+24 error.
  "tags": [
    "client"
error[07.08.2024, 23:39:32] Client log: Segment https://angeltales.angellive.ru/static/streaming-playlists/hls/private/67a80540-d692-45a8-aefd-55da003701b1/8e84b5e2-34eb-4ff7-a7f9-962c85361206-master.m3u8+V1+24 error.
  "tags": [
    "client"
error[07.08.2024, 23:40:07] Client log: Segment https://angeltales.angellive.ru/static/streaming-playlists/hls/private/67a80540-d692-45a8-aefd-55da003701b1/8e84b5e2-34eb-4ff7-a7f9-962c85361206-master.m3u8+V1+24 error.
  "tags": [
    "client"
error[07.08.2024, 23:40:55] Client log: Segment https://angeltales.angellive.ru/static/streaming-playlists/hls/private/67a80540-d692-45a8-aefd-55da003701b1/8e84b5e2-34eb-4ff7-a7f9-962c85361206-master.m3u8+V1+24 error.
  "tags": [
    "client"
error[07.08.2024, 23:52:38] Client log: Segment https://angeltales.angellive.ru/static/streaming-playlists/hls/private/67a80540-d692-45a8-aefd-55da003701b1/8e84b5e2-34eb-4ff7-a7f9-962c85361206-master.m3u8+V1+24 error.
  "tags": [
    "client"
I’ll mitigate these warnings/errors in the next PeerTube versions that may occur due to network issues.
