After working on the peertube-plugin-categories
I encoutered the following issues. I’ll probably create Github issues from some of these and even submit PR …but mb I’m missing a few obvious things…
Overall
unregister
should take the same arguments asregister
ex: when the extension is uninstalled how to reset settings or storage?
typescript
type definition should be exposed
see Expose Typescript type definition · Issue #4201 · Chocobozzz/PeerTube · GitHub
Categories (or constants customization overall)
getCategories
should be exposed oncategoryManager
other getter methods should probably be added to retrieve the customizations done mb
getAddedCategories
,getDeletedCategories
categories
shouldn’t be modified in memory but stored somewhere in database
many potential unwanted side effects
Missing hooks
- [client-hook] form submit success/settings changed success
- add a way to set the form submission as failed server side
ex: throwing in the plugin
handleSettingsChages
doesn’t do anything
ex: this could allow custom error messages
Translation
might be just me, so please forgive me…
- it seems plugin translation system doesn’t work
see PeerTube/client/src/app/core/plugins/plugin.service.ts at v3.2.1 · Chocobozzz/PeerTube · GitHub
it seems thehelpers
property is never populated…
- I don’t know whcich
i18n
library is used internally, but there should be a way to add parameters to the translationkey
Something like the following:
Hello {name}, how are you today?
To avoid having lengthy keys, I tried to use technical key instead of plain english (ex:
settings.greeting
) but renounce because of the previous point (bug?).
Settings
- as there is a
registerSetting
method there probably should be anunregisterSettting
method - an
html
form element added viaregisterSetting
is never found back in the settings
thus it can never be retrieved or updated via the `settingsManager
- missing
delete
method on thesettingsManager
mb clear settings automatically when the plugin is uninstalled?
OR leave the choice to the plugin developer?
there could be an input type
file
Question: how to implement efficiently a datagrid on the settings page? Should it be part of the plugin API?*
…or mb there is a way to reuse part of the Angular UI?
Storage
- missing
delete
method onstorageManager
same thought as for the settings: shall it be cleared on uninstall?
Here’s an HedgeDoc version of this list, if it can be of any help:
PeerTube issues - HedgeDoc
