Problem with clean install on Freebsd
Hi, I follow the the guideline to setup Peertube on my testing Freebsd server.
However, the landing page is text only and got exception from browser console. Not sure where is the problem.
Browser console:
service-worker.js:377 Service worker registration failed with: DOMException: Failed to register a ServiceWorker for scope (‹ https://video.in.lchs.network/client/en-US/ ›) with script (‹ https://video.in.lchs.network/client/en-US/ngsw-worker.js ›): The script has an unsupported MIME type (‹ text/plain ›).
It looks like it wasn’t able to render all of the css. What versions of node, yarn and redis are you using?
If you can grab the console output, that may also help troubleshoot.
node-15.14.0
yarn-1.22.10
redis-6.0.14
Cheers
Your instance is not running so I can’t test but it seems there is something wrong with your reverse proxy. Check your nginx config: PeerTube/peertube at develop · Chocobozzz/PeerTube · GitHub
Thanks. I don’t have reverse proxy setup in my test lab. I modified the default peertube and put as nginx.conf on my Freebsd. Attached the nginx.conf
Minimum Nginx version required: 1.13.0 (released Apr 25, 2017)
Please check your Nginx installation features the following modules via ‹ nginx -V ›:
STANDARD HTTP MODULES: Core, Proxy, Rewrite, Access, Gzip, Headers, HTTP/2, Log, Real IP, SSL, Thread Pool, Upstream, AIO Multithreading.
THIRD PARTY MODULES: None.
worker_processes 1;
error_log logs/error.log;
pid logs/nginx.pid;
events {
worker_connections 1024;
http {
server {
listen 80;
#listen [::]:80;
server_name video.in.lchs.network;
 # location /.well-known/acme-challenge/ {
	#default_type "text/plain";
	#root /var/www/certbot;
upstream backend {
  server 127.0.0.1:9000;
server {
  listen 443 ssl http2;
 # listen [::]:443 ssl http2;
  error_log  /var/log/nginx/peertube.error.log;
  # Certificates
  # you need a certificate to run in production. see https://letsencrypt.org/
  ssl_certificate     /var/db/acme/certs/video.in.lchs.network/video.in.lchs.network.cer;
  ssl_certificate_key /var/db/acme/certs/video.in.lchs.network/video.in.lchs.network.key;
  ssl_trusted_certificate   /var/db/acme/certs/video.in.lchs.network/fullchain.cer;
  #location ^~ '/.well-known/acme-challenge' {
  # Security hardening (as of Nov 15, 2020)
  # based on Mozilla Guideline v5.6
  ssl_protocols             TLSv1.2 TLSv1.3;
  ssl_prefer_server_ciphers on;
  ssl_ciphers               ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256; # add ECDHE-RSA-AES256-SHA if you want compatibility with Android 4
  ssl_session_timeout       1d; # defaults to 5m
  ssl_session_cache         shared:SSL:10m; # estimated to 40k sessions
  ssl_session_tickets       off;
  ssl_stapling              on;
  ssl_stapling_verify       on;
  # HSTS (https://hstspreload.org), requires to be copied in 'location' sections that have add_header directives
  #add_header Strict-Transport-Security "max-age=63072000; includeSubDomains";
  # Application
  location @api {
	proxy_set_header Host            $host;
	proxy_set_header X-Real-IP       $remote_addr;
	proxy_connect_timeout 10m;
	proxy_send_timeout    10m;
	proxy_read_timeout    10m;
	send_timeout          10m;
	proxy_pass http://backend;
  location / {
	try_files /dev/null @api;
  location = /api/v1/videos/upload-resumable {
	client_max_body_size    0;
	proxy_request_buffering off;
  location = /api/v1/videos/upload {
	# on a dedicated filesystem.
	client_max_body_size                      12G; # default is 1M
	add_header            X-File-Maximum-Size 8G always; # inform backend of the set value in bytes before mime-encoding (x * 1.4 >= client_max_body_size)
	client_max_body_size                      3M; # default is 1M
	add_header            X-File-Maximum-Size 2M always; # inform backend of the set value in bytes before mime-encoding (x * 1.4 >= client_max_body_size)
  # Websocket
  location @api_websocket {
	proxy_http_version 1.1;
	proxy_set_header   Upgrade         $http_upgrade;
	proxy_set_header   Connection      "upgrade";
  location /socket.io {
  location /tracker/socket {
  # Performance optimizations
  gzip              on;
  gzip_vary         on;
  gzip_types        # text/html is always compressed by HttpGzipModule
					text/css
					application/javascript
					font/truetype
					font/opentype
					application/vnd.ms-fontobject
					image/svg+xml;
  gzip_min_length   1000; # default is 20 bytes
  gzip_buffers      16 8k;
  gzip_comp_level   2; # default is 1
  client_body_timeout       30s; # default is 60
  client_header_timeout     10s; # default is 60
  send_timeout              10s; # default is 60
  keepalive_timeout         10s; # default is 75
  resolver_timeout          10s; # default is 30
  reset_timedout_connection on;
  proxy_ignore_client_abort on;
  tcp_nopush                on; # send headers in one piece
  tcp_nodelay               on; # don't buffer data sent, good for small data bursts in real time
  # If you have a small /var/lib partition, it could be interesting to store temp nginx uploads in a different place
  # See https://nginx.org/en/docs/http/ngx_http_core_module.html#client_body_temp_path
  # Should be consistent with client-overrides assets list in /server/controllers/client.ts
  location ~ ^/client/(assets/images/(icons/icon-36x36\.png|icons/icon-48x48\.png|icons/icon-72x72\.png|icons/icon-96x96\.png|icons/icon-144x144\.png|icons/icon-192x192\.png|icons/icon-512x512\.png|logo\.svg|favicon\.png))$ {
	add_header Cache-Control "public, max-age=31536000, immutable"; # Cache 1 year
	root /var/www/peertube;
	try_files /storage/client-overrides/$1 /peertube-latest/client/dist/$1 @api;
	  add_header Access-Control-Allow-Origin  '*';
	  add_header Access-Control-Allow-Methods 'GET, OPTIONS';
	  add_header Access-Control-Allow-Headers 'Range,DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type';
	  add_header Access-Control-Max-Age       1728000; # Preflight request can be cached 20 days
	  add_header Content-Type                 'text/plain charset=UTF-8';
	  add_header Content-Length               0;
	  return 204;
	add_header Cache-Control                  "public, max-age=7200"; # Cache response 2 hours
	rewrite ^/static/(.*)$ /$1 break;
	try_files $uri @api;
  location ~ ^/static/(webseed|redundancy|streaming-playlists)/ {
	limit_rate_after            5M;
	set $peertube_limit_rate    800k;
	# Increase rate limit in HLS mode, because we don't have multiple simultaneous connections
	if ($request_uri ~ -fragmented.mp4$) {
	  set $peertube_limit_rate  5M;
	#limit_rate $peertube_limit_rate;
	# Or this line if your nginx < 1.17.0
	set $limit_rate $peertube_limit_rate;
	  return 204;
	  access_log off;
	sendfile on;
	sendfile_max_chunk 1M; # prevent one fast connection from entirely occupying the worker process. should be > 800k.
	aio threads;
	# Use this in tandem with fuse-mounting i.e. https://docs.joinpeertube.org/admin-remote-storage
	# to serve files directly from a public bucket without proxying.
	# Assumes you have buckets named after the storage subdirectories, i.e. 'videos', 'redundancy', etc.
	#set $cdn <your S3-compatiable bucket public url mounted via fuse>;
	#rewrite ^/static/webseed/(.*)$ $cdn/videos/$1 redirect;
	#rewrite ^/static/(.*)$         $cdn/$1        redirect;
Hi. problem has been fixed by commenting
pid logs/nginx.pid;
and adding
include mime.types; in http.
Thanks
