j’ai eu un soucis avec une mise à jour de notre instance Mobilizon sur mon serveur Yunohost, est-ce que à tout hasard vous auriez une piste ?
Après la mise à jour il m’étais impossible de me connecter…
J’ai eu ce genre de logs
2022/06/19 19:59:50 [error] 13740#13740: *1193146 connect() failed (111: Connection refused) while connecting to upstream, client: XX.XX.XX.XXX, server: domain.domainname.tld, request: "POST /api HTTP/2.0", upstream: "http://[::1]:8095/api", host: "domain.domainname.tld", referrer: "https://domain.domainname.tld/"
2022/06/19 20:00:01 [error] 13740#13740: *1193146 connect() failed (111: Connection refused) while connecting to upstream, client: XX.XX.XX.XXX, server: domain.domainname.tld, request: "GET /fonts/materialdesignicons-webfont.f5b84261.ttf HTTP/2.0", upstream: "http://[::1]:8095/fonts/materialdesignicons-webfont.f5b84261.ttf", host: "domain.domainname.tld", referrer: "https://domain.domainname.tld/service-worker.js"
2022/06/19 20:00:32 [error] 13740#13740: *1193175 connect() failed (111: Connection refused) while connecting to upstream, client: XXXX:XXX:XXXX:XXXX:XXXX:XXXX:XXXX:XXXX, server: domain.domainname.tld, request: "GET /.well-known/host-meta HTTP/2.0", upstream: "http://[::1]:8095/.well-known/host-meta", host: "domain.domainname.tld"
2022/06/19 20:01:47 [error] 13740#13740: *1193183 connect() failed (111: Connection refused) while connecting to upstream, client: XXXX:XXXX:X:X::XXX, server: domain.domainname.tld, request: "GET /.well-known/nodeinfo/2.1 HTTP/2.0", upstream: "http://[::1]:8095/.well-known/nodeinfo/2.1", host: "domain.domainname.tld"
2022/06/19 20:02:20 [error] 13740#13740: *1193188 connect() failed (111: Connection refused) while connecting to upstream, client: XXX.XXX.XXX.XX, server: domain.domainname.tld, request: "GET /.well-known/nodeinfo/2.1 HTTP/2.0", upstream: "http://[::1]:8095/.well-known/nodeinfo/2.1", host: "domain.domainname.tld"
2022/06/19 20:04:28 [error] 13740#13740: *1193207 connect() failed (111: Connection refused) while connecting to upstream, client: XX.XXX.XXX.XX, server: domain.domainname.tld, request: "GET /.well-known/nodeinfo/2.1 HTTP/1.1", upstream: "http://[::1]:8095/.well-known/nodeinfo/2.1", host: "domain.domainname.tld"
2022/06/19 20:12:25 [error] 13740#13740: *1193260 connect() failed (111: Connection refused) while connecting to upstream, client: XXXX:XXXX:X:XX::XXXX:XXXX, server: domain.domainname.tld, request: "HEAD /nodeinfo/2.1.json HTTP/1.1", upstream: "http://[::1]:8095/nodeinfo/2.1.json", host: "domain.domainname.tld"
2022/06/19 20:12:38 [error] 13740#13740: *1193291 connect() failed (111: Connection refused) while connecting to upstream, client: XXXX:XXXX:X:XX::XXXX:XXXX, server: domain.domainname.tld, request: "HEAD /nodeinfo/2.0.json HTTP/1.1", upstream: "http://[::1]:8095/nodeinfo/2.0.json", host: "domain.domainname.tld"
2022/06/19 20:12:51 [error] 13740#13740: *1193318 connect() failed (111: Connection refused) while connecting to upstream, client: XXXX:XXXX:X:XX::XXXX:XXXX, server: domain.domainname.tld, request: "GET /api/v1/instance/nodeinfo/2.0 HTTP/1.1", upstream: "http://[::1]:8095/api/v1/instance/nodeinfo/2.0", host: "domain.domainname.tld"
J’ai ouvert l’issue sur le dépôt github de l’app mobilizon_ynh ici Can't login after upgrade to 2.1.0~ynh1 · Issue #135 · YunoHost-Apps/mobilizon_ynh · GitHub
Est-ce que vous auriez une piste sur ce bug ??
Un développeur de Yunohost évoque peut-être cette piste:
In 2.1.0 change log : « Add Überauth CAS Strategy »
May be it’s a regression due to this new feature ?
