Bonjour, d’habitude je n’ai aucun problème pour mettre à jour peertube, mais là ça coince pour la version 6.3.0 (j’ai la 6.2.1 actuellement).
En soi la mise à jour fonctionne bien avec ./upgrade.sh mais la commande :
sudo -u peertube NODE_CONFIG_DIR=/srv/peertube/config NODE_ENV=production node dist/scripts/migrations/peertube-6.3.js
me donne l’erreur suivante :
Error
at Query.run (/srv/peertube/versions/peertube-v6.3.0/node_modules/sequelize/lib/dialects/postgres/query.js:50:25)
at /srv/peertube/versions/peertube-v6.3.0/node_modules/sequelize/lib/sequelize.js:315:28
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async run (file:///srv/peertube/versions/peertube-v6.3.0/dist/scripts/migrations/peertube-6.3.js:22:21) {
parent: error: column "formatFlags" does not exist
at Parser.parseErrorMessage (/srv/peertube/versions/peertube-v6.3.0/node_modules/pg-protocol/dist/parser.js:283:98)
at Parser.handlePacket (/srv/peertube/versions/peertube-v6.3.0/node_modules/pg-protocol/dist/parser.js:122:29)
at Parser.parse (/srv/peertube/versions/peertube-v6.3.0/node_modules/pg-protocol/dist/parser.js:35:38)
at Socket.<anonymous> (/srv/peertube/versions/peertube-v6.3.0/node_modules/pg-protocol/dist/index.js:11:42)
at Socket.emit (node:events:519:28)
at addChunk (node:internal/streams/readable:559:12)
at readableAddChunkPushByteMode (node:internal/streams/readable:510:3)
at Readable.push (node:internal/streams/readable:390:5)
at TCP.onStreamRead (node:internal/stream_base_commons:191:23) {
length: 111,
severity: 'ERROR',
code: '42703',
detail: undefined,
hint: undefined,
position: '77',
internalPosition: undefined,
internalQuery: undefined,
where: undefined,
schema: undefined,
table: undefined,
column: undefined,
dataType: undefined,
constraint: undefined,
file: 'parse_relation.c',
line: '3722',
routine: 'errorMissingColumn',
sql: 'SELECT COUNT(*) AS "total" FROM "videoFile" WHERE "videoId" IS NOT NULL AND "formatFlags" != 1',
parameters: undefined
original: error: column "formatFlags" does not exist
length: 111,
severity: 'ERROR',
code: '42703',
detail: undefined,
hint: undefined,
position: '77',
where: undefined,
schema: undefined,
table: undefined,
column: undefined,
line: '3722',
parameters: {}
En effet, je n’ai pas de colonne formatFlags dans la table videoFile mais je ne sais pas pourquoi ni comment la créer et la peupler proprement.
Merci d’avance pour votre aide pour résoudre de souci.
