When i try to upgrade my dev environment from v5.0 to v5.2 I get an error running the upgrade script:
root@werkvm3:~# sudo ~/PeerTube/scripts/upgrade.sh
Backing up PostgreSQL database in /var/www/peertube/backup/sql-peertube_prod-20230829-1726.bak
node:internal/modules/cjs/loader:1031
throw err;
Error: Cannot find module ‹ js-yaml ›
Require stack:
- /root/[eval]
at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15)
at Function.Module._load (node:internal/modules/cjs/loader:873:27)
at Module.require (node:internal/modules/cjs/loader:1100:19)
at require (node:internal/modules/cjs/helpers:119:18)
at [eval]:1:13
at Script.runInThisContext (node:vm:129:12)
at Object.runInThisContext (node:vm:313:38)
at node:internal/process/execution:79:19
at [eval]-wrapper:6:22
at evalScript (node:internal/process/execution:78:60) {
code: ‹ MODULE_NOT_FOUND ›,
requireStack: [ ‹ /root/[eval] › ]
Can anybody help me fix this so i can update my environment.
T. Boer
