Problems with official LDAP plugin
Hi all,
I have installed and configured peertube-plugin-auth-ldap with an Active Directory backend.
When I try to log in with a domain user, I see the following in the logs:
info: Login success with auth method ldap of plugin peertube-plugin-auth-ldap for myuser
info: Bypassing oauth login by plugin peertube-plugin-auth-ldap
warn: Login error {
  "err": {
    "stack": "invalid_grant: Invalid grant: user credentials are invalid\n    at handlePasswordGrant (file:///app/dist/core/lib/auth/oauth.js:112:15)\n    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n
 at async handleToken (file:///app/dist/core/controllers/api/users/token.js:32:23)",
    "message": "Invalid grant: user credentials are invalid",
    "statusCode": 400,
    "status": 400,
    "code": 400,
    "name": "invalid_grant"
info: (...) "POST /api/v1/users/token HTTP/1.0" 400 271 "https://my.domain.tld/login" "Chrome"
error: Client log: Backend returned code 400, errorMessage is Invalid grant: user credentials are invalid {
  "userAgent": "(...)",
  "meta": "(...)",
  "url": "https://my.domain.tld/login"
To me it looks like the user is correctly authenticated by Active Directory, but something goes wrong with the handling of authentication tokens, leading to a login error.
Does anyone have an idea about what the issue might be?
Additional info:
  • I’m using Global Catalog on port 3269
  • Search filter: (&(objectClass=user)(sAMAccountName={{username}}))
  • Username property: sAMAccountName
  • PeerTube is running in an airgapped Kubernetes cluster based on the supplied docker-compose file and container images
Ensure the user has a LDAP auth method in admin (user list → update user)
Thanks, the issue was that my email address had already been used for the root account.
