Hello, i was wondering if anyone hase experience or would know if.i can run peertube on the Zimablade.
Im looking to make a HA proxmox cluster and thought i could run this
Heres the spec link
SPECIFICATION
- CPU:
- dual-core option (3760): Intel® Celeron with 2.2 GHz Turbo Speed
- quad-core option (7700): Intel® Celeron with 2.4 GHz Turbo Speed
- Intel® AES New Instructions
- Intel® Virtualization Technology (VT-x)
- Intel® Virtualization Technology for Directed I/O (VT-d)
- Memory: SODIMM slot, compatible with 16 GB DDR3L RAM
- Storage: Integrated 32 GB eMMC
- Network: 1 x 10/100/1000 Mbps Gigabit Ethernet
- Display:
- 1 x 4K MiniDP @ 60 Hz
- 1 x board-to-board eDP interface
- Graphics:
- Up to 700 MHz
- Intel® Quick Sync Video
- Intel® Clear Video HD Technology
- Intel® Clear Video Technology
- PCIe: 1 x PCIe 2.0, four lanes
- USB:
- 1 x USB Type-C (data + power + display)
- 1 x USB 3.0
- 2 x USB 2.0
- SATA: 2 x SATA 3.0
- Power: 45 W USB Type-C power adapter
- Thermal: 6 W TDP with passive cooling
- Dimensions: 107 mm x 80 mm x 23 mm
- Enclosure: Custom injection molded
- CPU:
Any advice would be appreciated
