hello developers. please tell me: you can create exactly the same plugins that are indicated for the avideo but created for peertube?
Hi.
I can’t tell if you can reproduce exactly each plugins your linked but if there are missing hooks or API and it makes sense to add them, PeerTube developpers will probably do it.
So, you can try and if you are being blocked somewhere, just ask for help or API enhancement.
