Добавление QUIC в PeerTube повышение стабильности соединения
Hello everyone, QUIC gives stability, with an unstable connection of mobile devices, this has been tested on many applications repeatedly. Since I am concerned about client errors, and video freezes when using mobile devices, let’s watch together (test) videos with HTTP 3. Test version of the server PeerTube I will leave it for testing for a while
Enable in the browser
Iceraven, firefox
To enable HTTP/3, type about:config into the browser string and find
network.http.http3.enable
network.http.http3.enable_0rtt
network.http.http3.enable_kyber
Making them true
For Brave, just type chrome://flags/#enable-quic into the browser bar and select enable
After that, restart the browser.
  1. Update Nginx to the latest stable version
  2. Add the QUIC Settings
server {
  listen 80;
  listen [::]:80;
  server_name angeltales1.angellive.ru;
    default_type "text/plain";
    root /var/www/certbot;
upstream backend {
  server 127.0.0.1:9000;
server {
  listen 443 ssl;
  listen [::]:443 ssl;
  listen 443 quic reuseport;
  listen [::]:443 quic reuseport;
  http2 on;
  http3 on;
  error_log  /var/log/nginx/peertube.error.log;
  # Certificates
  # you need a certificate to run in production. see https://letsencrypt.org/
  ssl_certificate     /etc/letsencrypt/live/angeltales1.angellive.ru/fullchain.pem;
  ssl_certificate_key /etc/letsencrypt/live/angeltales1.angellive.ru/privkey.pem;
  # Security hardening (as of Nov 15, 2020)
  # based on Mozilla Guideline v5.6
  ssl_protocols             TLSv1.2 TLSv1.3;
  ssl_prefer_server_ciphers on;
  ssl_ciphers               ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256; # add ECDHE-RSA-AES256-SHA if you want compatibility with Android 4
  ssl_session_timeout       1d; # defaults to 5m
  ssl_session_cache         shared:SSL:10m; # estimated to 40k sessions
  ssl_session_tickets       off;
  ssl_stapling              on;
  ssl_stapling_verify       on;
  # HSTS (https://hstspreload.org), requires to be copied in 'location' sections that have add_header directives
  #add_header Strict-Transport-Security "max-age=63072000; includeSubDomains";
  add_header Alt-Svc 'h3=":443"; ma=86400'; # Advertise HTTP/3 support
  add_header QUIC-Status $http3;
  # Application
  location @api {
    proxy_set_header Host            $host;
    proxy_set_header X-Real-IP       $remote_addr;
    proxy_connect_timeout 10m;
    proxy_send_timeout    10m;
    proxy_read_timeout    10m;
    send_timeout          10m;
    proxy_pass http://backend;
  location / {
    try_files /dev/null @api;
  location ~ ^/api/v1/videos/(upload-resumable|([^/]+/source/replace-resumable))$ {
    client_max_body_size    0;
    proxy_request_buffering off;
  location ~ ^/api/v1/users/[^/]+/imports/import-resumable$ {
  location ~ ^/api/v1/videos/(upload|([^/]+/studio/edit))$ {
    # on a dedicated filesystem.
    client_max_body_size                      12G; # default is 1M
    add_header            X-File-Maximum-Size 8G always; # inform backend of the set value in bytes before mime-encoding (x * 1.4 >= client_max_body_size)
  location ~ ^/api/v1/runners/jobs/[^/]+/(update|success)$ {
    client_max_body_size                      6M; # default is 1M
    add_header            X-File-Maximum-Size 4M always; # inform backend of the set value in bytes before mime-encoding (x * 1.4 >= client_max_body_size)
  # Websocket
  location @api_websocket {
    proxy_http_version 1.1;
    proxy_set_header   Upgrade         $http_upgrade;
    proxy_set_header   Connection      "upgrade";
  location /socket.io {
  location /tracker/socket {
  # Plugin websocket routes
  location ~ ^/plugins/[^/]+(/[^/]+)?/ws/ {
  # Performance optimizations
  gzip              on;
  gzip_vary         on;
  gzip_types        # text/html is always compressed by HttpGzipModule
                    text/css
                    application/javascript
                    font/truetype
                    font/opentype
                    application/vnd.ms-fontobject
                    image/svg+xml;
  gzip_min_length   1000; # default is 20 bytes
  gzip_buffers      16 8k;
  gzip_comp_level   2; # default is 1
  client_body_timeout       30s; # default is 60
  client_header_timeout     10s; # default is 60
  send_timeout              10s; # default is 60
  keepalive_timeout         10s; # default is 75
  resolver_timeout          10s; # default is 30
  reset_timedout_connection on;
  proxy_ignore_client_abort on;
  tcp_nopush                on; # send headers in one piece
  tcp_nodelay               on; # don't buffer data sent, good for small data bursts in real time
  # If you have a small /var/lib partition, it could be interesting to store temp nginx uploads in a different place
  # See https://nginx.org/en/docs/http/ngx_http_core_module.html#client_body_temp_path
  # Should be consistent with client-overrides assets list in client.ts server controller
  location ~ ^/client/(assets/images/(icons/icon-36x36\.png|icons/icon-48x48\.png|icons/icon-72x72\.png|icons/icon-96x96\.png|icons/icon-144x144\.png|icons/icon-192x192\.png|icons/icon-512x512\.png|logo\.svg|favicon\.png|default-playlist\.jpg|default-avatar-account\.png|default-avatar-account-48x48\.png|default-avatar-video-channel\.png|default-avatar-video-channel-48x48\.png))$ {
    add_header Cache-Control "public, max-age=31536000, immutable"; # Cache 1 year
    root /var/www/peertube;
    try_files /storage/client-overrides/$1 /peertube-latest/client/dist/$1 @api;
  location ~ ^(/static/(webseed|web-videos|streaming-playlists/hls)/private/)|^/download {
    # We can't rate limit a try_files directive, so we need to duplicate @api
    proxy_limit_rate 5M;
  location ~ ^/static/(webseed|web-videos|redundancy|streaming-playlists)/ {
    limit_rate_after            5M;
    set $peertube_limit_rate  5M;
    limit_rate $peertube_limit_rate;
    # Or this line with nginx < 1.17.0
    # set $limit_rate $peertube_limit_rate;
      add_header Access-Control-Allow-Origin  '*';
      add_header Access-Control-Allow-Methods 'GET, OPTIONS';
      add_header Access-Control-Allow-Headers 'Range,DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type';
      add_header Access-Control-Max-Age       1728000; # Preflight request can be cached 20 days
      add_header Content-Type                 'text/plain charset=UTF-8';
      add_header Content-Length               0;
      return 204;
      access_log off;
    sendfile on;
    sendfile_max_chunk 1M; # prevent one fast connection from entirely occupying the worker process. should be > 800k.
    aio threads;
    # web-videos is the name of the directory mapped to the `storage.web_videos` key in your PeerTube configuration
    rewrite ^/static/webseed/(.*)$ /web-videos/$1 break;
    rewrite ^/static/(.*)$         /$1        break;
    try_files $uri @api;
Let’s see together (if it’s Interesting, of course) what can be added or improved. Thank you
root@3317567-cy23677:~# grep -Ri 'listen' /etc/nginx/sites-available/peertube
  listen 80;
  listen [::]:80;
  listen 443 ssl;
root@3317567-cy23677:~# grep -R reuseport /etc/nginx/sites-available/peertube
Hello everyone, I’ll leave it here, QUIC will only work fine if you open UDP port 443, otherwise there will be no connection
ufw allow 443/udp #Для QUIC
I also created a file called http2-directive.conf and put it in etc/nginx/conf.d with the contents according to the official documentation.
http2 on;
Also for relay protection
  # TLS 1.3 0-RTT anti-replay
  if ($anti_replay = 307) { return 307 https://$host$request_uri; }
  if ($anti_replay = 425) { return 425; }
Place the file 0rtt-anti-replay.conf with the following contents in /etc/nginx/conf.d
# Implement TLS 1.3 0-RTT anti-replay for NGINX
# Requires: NGINX directive "ssl_early_data" on
# Usage:
# Make sure these "map" blocks are included in "http" block
# Put the following two lines in SSL "server" block, before any "location" blocks
# if ($anti_replay = 307) { return 307 https://$host$request_uri; }
# if ($anti_replay = 425) { return 425; }
# Pass "Early-Data" header to backend/upstream
# Only for 0-RTT requests from clients that understand 425 status code (RFC 8470)
# fastcgi_param HTTP_EARLY_DATA $rfc_early_data if_not_empty;
# proxy_set_header Early-Data $rfc_early_data;
# Copyright © myrevery
# Copyright © 7677333 (An anagram of a Anonymous Cybersecurity Research Team)
map "$request_method:$is_args" $ar_idempotent {
	default 0;
	"~^GET:$|^(HEAD|OPTIONS|TRACE):\?*$" 1;
map $http_user_agent $ar_support_425 {
	default 0;
	"~Firefox/((58|59)|([6-9]\d)|([1-9]\d{2,}))\.\d+" 1;
map "$ssl_early_data:$ar_idempotent:$ar_support_425" $anti_replay {
	1:0:0 307;
	1:0:1 425;
map "$ssl_early_data:$ar_support_425" $rfc_early_data {
	1:1 1;
As a result, we get a config for Ngnix version no lower than 1.25 (check nginx -V to ensure there is an with-http_v3_module)
server {
  listen 80;
  listen [::]:80;
upstream backend {
server {
  listen 443 ssl;
  # Certificates
  ssl_stapling              on;
  # Application
  location @api {
    send_timeout          10m;
  location / {
  # Websocket
  gzip              on;
  gzip_vary         on;
                    text/css
                    font/truetype
                    font/opentype
                    image/svg+xml;
  gzip_buffers      16 8k;
      return 204;
      access_log off;
    sendfile on;
    aio threads;
Check here
P.S. And also, add to the main file Nginx, /etc/nginx/nginx.conf ssl_early_data on;
user www-data;
worker_processes auto;
pid /run/nginx.pid;
error_log /var/log/nginx/error.log;
include /etc/nginx/modules-enabled/*.conf;
events {
	worker_connections 768;
	# multi_accept on;
http {
	# Basic Settings
    ssl_early_data on;
	sendfile on;
	tcp_nopush on;
	types_hash_max_size 2048;
	# server_tokens off;
	# server_names_hash_bucket_size 64;
	# server_name_in_redirect off;
	include /etc/nginx/mime.types;
	default_type application/octet-stream;
	# SSL Settings
	ssl_protocols TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
	# Logging Settings
	access_log /var/log/nginx/access.log;
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
	# gzip_comp_level 6;
	# gzip_buffers 16 8k;
	# gzip_http_version 1.1;
	# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
	# Virtual Host Configs
	include /etc/nginx/conf.d/*.conf;
	include /etc/nginx/sites-enabled/*;
#mail {
#	# See sample authentication script at:
#	# http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#	# auth_http localhost/auth.php;
#	# pop3_capabilities "TOP" "USER";
#	# imap_capabilities "IMAP4rev1" "UIDPLUS";
#	server {
#		listen     localhost:110;
#		protocol   pop3;
#		proxy      on;
#	server {
#		listen     localhost:143;
#		protocol   imap;
#		proxy      on;
