Recurrent livestream info
Hi, i tried finding a solution but i couldnt. So the thing is that if recurrent lives work in different days (my idea is to set it on OBS and not change that info anymore) i cant see the way to change the name of the live. What i mostly do are interviews about different topics, so i would like to name it differently each day so the title would say something about what are we going to talk about, and the only way i see for that is after ending the livestream. As i understand if i create a new normal live each day changing the name is easy, but id have to change a lot of stuff plus share the new link.
Am i missing something? Am i understanding correctly what are concurrent lives for?
I’m not sure to understand, but you can update the permanent live metadata (and so the name) before your live stream :slight_smile:
