Remote runner not uploading finished jobs
Hello.
I use three machines as remote runners.
  1. The server’s localhost
  2. A virtual machine in the same datacenter
  3. My home PC
The only problem is that the third one does not successfully upload its finished jobs.
They remain « processing » indefinitely at 100% progress, when viewed on the web interface.
Here is the prunner log.
Jan 03 14:59:28 obelisk systemd[1]: Started PeerTube runner daemon.
Jan 03 14:59:28 obelisk prunner[1097]: [14:59:28.986] INFO (1097): Running PeerTube runner in server mode
Jan 03 14:59:29 obelisk prunner[1097]: [14:59:28.993] INFO (1097): Supported and enabled job types: vod-web-video-transcoding, vod-hls-transcoding, vod-audio-merge-transcoding, live-rtmp-hls-transcoding, video-studio-transcoding, video-transcription
Jan 03 14:59:29 obelisk prunner[1097]: [14:59:28.993] INFO (1097): Using /srv/prunner/.config/peertube-runner-nodejs/default/config.toml as configuration file
Jan 03 14:59:29 obelisk prunner[1097]: [14:59:28.996] INFO (1097): IPC socket created on /srv/prunner/.local/share/peertube-runner-nodejs/default/peertube-runner.sock
Jan 03 14:59:29 obelisk prunner[1097]: [14:59:28.997] INFO (1097): Using /srv/prunner/.cache/peertube-runner-nodejs/default/transcoding for transcoding directory
Jan 03 15:02:04 obelisk prunner[1097]: [15:02:04.813] INFO (1097): Registering runner wally on https://tankie.tube...
Jan 03 15:02:05 obelisk prunner[1097]: [15:02:05.672] INFO (1097): Registered runner wally on https://tankie.tube
Jan 03 15:02:06 obelisk prunner[1097]: [15:02:06.829] INFO (1097): Connected to https://tankie.tube/runners socket
Jan 03 15:02:06 obelisk prunner[1097]: [15:02:06.829] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:02:08 obelisk prunner[1097]: [15:02:08.611] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 814242d3-0936-43db-b14a-8d30d8e60bbe
Jan 03 15:02:08 obelisk prunner[1097]: (node:1097) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
Jan 03 15:02:08 obelisk prunner[1097]: (Use `node --trace-deprecation ...` to show where the warning was created)
Jan 03 15:02:08 obelisk prunner[1097]: [15:02:08.613] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/814242d3-0936-43db-b14a-8d30d8e60bbe/files/videos/1f4da46c-5905-413d-a3d2-e67b682fc1e0/max-quality for web video transcoding job ptrjt-ae8d187f-b494-4672-b34d-93caad494282
Jan 03 15:02:11 obelisk prunner[1097]: [15:02:11.115] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:02:12 obelisk prunner[1097]: [15:02:12.945] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 8a75a4a2-8272-4475-ad4f-fd1e6e6a8fc4
Jan 03 15:02:12 obelisk prunner[1097]: [15:02:12.946] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/8a75a4a2-8272-4475-ad4f-fd1e6e6a8fc4/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for web video transcoding job ptrjt-3ad8ec4f-07a7-4d15-9192-828967e0adf0
Jan 03 15:02:15 obelisk prunner[1097]: [15:02:15.447] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:02:15 obelisk prunner[1097]: [15:02:15.732] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/8a75a4a2-8272-4475-ad4f-fd1e6e6a8fc4/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for job ptrjt-3ad8ec4f-07a7-4d15-9192-828967e0adf0. Running web video transcoding.
Jan 03 15:02:15 obelisk prunner[1097]: [15:02:15.887] INFO (1097): Built supported ffmpeg encoders.
Jan 03 15:02:15 obelisk prunner[1097]:     supportedEncoders: {}
Jan 03 15:02:15 obelisk prunner[1097]:     searchEncoders: {}
Jan 03 15:02:15 obelisk prunner[1097]:     tags: []
Jan 03 15:02:17 obelisk prunner[1097]: [15:02:17.360] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: bd62da99-bbc6-47a8-8aca-d26af4b6fbf6
Jan 03 15:02:17 obelisk prunner[1097]: [15:02:17.364] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/bd62da99-bbc6-47a8-8aca-d26af4b6fbf6/files/videos/f1b2ec29-e960-4c7f-9ddf-6b903a23bc34/max-quality for web video transcoding job ptrjt-f150a7a7-0345-4e9d-8fba-d250724a2d4f
Jan 03 15:02:19 obelisk prunner[1097]: [15:02:19.866] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:02:21 obelisk prunner[1097]: [15:02:21.792] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 74985816-e4f1-419b-9991-57b333850d3a
Jan 03 15:02:21 obelisk prunner[1097]: [15:02:21.796] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/74985816-e4f1-419b-9991-57b333850d3a/files/videos/34bbf454-e6d6-42d6-b77d-86b5cbcf00b7/max-quality for web video transcoding job ptrjt-286491ac-2ec1-43ca-8d7f-ad5e27d68125
Jan 03 15:02:21 obelisk prunner[1097]: [15:02:21.864] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/bd62da99-bbc6-47a8-8aca-d26af4b6fbf6/files/videos/f1b2ec29-e960-4c7f-9ddf-6b903a23bc34/max-quality for job ptrjt-f150a7a7-0345-4e9d-8fba-d250724a2d4f. Running web video transcoding.
Jan 03 15:02:24 obelisk prunner[1097]: [15:02:24.300] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:02:25 obelisk prunner[1097]: [15:02:25.614] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/814242d3-0936-43db-b14a-8d30d8e60bbe/files/videos/1f4da46c-5905-413d-a3d2-e67b682fc1e0/max-quality for job ptrjt-ae8d187f-b494-4672-b34d-93caad494282. Running web video transcoding.
Jan 03 15:02:26 obelisk prunner[1097]: [15:02:26.328] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 013bf1ad-1640-46b3-bd61-29b350838565
Jan 03 15:02:26 obelisk prunner[1097]: [15:02:26.331] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/013bf1ad-1640-46b3-bd61-29b350838565/files/videos/14db2af8-95ff-4047-8874-0dc1b5b482bb/max-quality for web video transcoding job ptrjt-7ca61f82-5159-42f6-b0b2-245d9f3140aa
Jan 03 15:02:28 obelisk prunner[1097]: [15:02:28.833] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:02:30 obelisk prunner[1097]: [15:02:30.619] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 840555ad-2b5c-4e37-b5b7-c56fe55e8ca6
Jan 03 15:02:30 obelisk prunner[1097]: [15:02:30.622] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/840555ad-2b5c-4e37-b5b7-c56fe55e8ca6/files/videos/4d2dd8a4-c3a3-4fc3-94f4-1a459bf80704/max-quality for web video transcoding job ptrjt-2c666d90-0989-489c-9d53-e0ad6aac0d79
Jan 03 15:02:33 obelisk prunner[1097]: [15:02:33.125] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:02:35 obelisk prunner[1097]: [15:02:35.354] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 61f4a90c-3d7e-46db-bd88-b6e886d03ca9
Jan 03 15:02:35 obelisk prunner[1097]: [15:02:35.357] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/61f4a90c-3d7e-46db-bd88-b6e886d03ca9/files/videos/4ee77de6-a85a-4c2e-867f-055ab0a77b6d/max-quality for web video transcoding job ptrjt-2f1bf611-1d21-45dd-9b2d-55e6995528e6
Jan 03 15:02:37 obelisk prunner[1097]: [15:02:37.858] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:02:38 obelisk prunner[1097]: [15:02:38.306] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/840555ad-2b5c-4e37-b5b7-c56fe55e8ca6/files/videos/4d2dd8a4-c3a3-4fc3-94f4-1a459bf80704/max-quality for job ptrjt-2c666d90-0989-489c-9d53-e0ad6aac0d79. Running web video transcoding.
Jan 03 15:02:39 obelisk prunner[1097]: [15:02:39.765] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 41dc5e24-be2b-4214-9b37-c375fc3bb48d
Jan 03 15:02:39 obelisk prunner[1097]: [15:02:39.769] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/41dc5e24-be2b-4214-9b37-c375fc3bb48d/files/videos/39bf10d0-3e40-4744-be88-141db1b22fe1/max-quality for web video transcoding job ptrjt-67681077-e327-453c-83ca-c1cb85410531
Jan 03 15:02:42 obelisk prunner[1097]: [15:02:42.169] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/61f4a90c-3d7e-46db-bd88-b6e886d03ca9/files/videos/4ee77de6-a85a-4c2e-867f-055ab0a77b6d/max-quality for job ptrjt-2f1bf611-1d21-45dd-9b2d-55e6995528e6. Running web video transcoding.
Jan 03 15:02:42 obelisk prunner[1097]: [15:02:42.271] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:02:42 obelisk prunner[1097]: [15:02:42.657] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/74985816-e4f1-419b-9991-57b333850d3a/files/videos/34bbf454-e6d6-42d6-b77d-86b5cbcf00b7/max-quality for job ptrjt-286491ac-2ec1-43ca-8d7f-ad5e27d68125. Running web video transcoding.
Jan 03 15:02:44 obelisk prunner[1097]: [15:02:44.140] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: eccdffca-33d1-47b4-885a-9cf4612aea73
Jan 03 15:02:44 obelisk prunner[1097]: [15:02:44.147] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/eccdffca-33d1-47b4-885a-9cf4612aea73/files/videos/4e81a73c-541d-463a-b3f5-113ba845b980/max-quality for web video transcoding job ptrjt-db28309a-3af0-4895-9fe5-4ef1318c547e
Jan 03 15:02:46 obelisk prunner[1097]: [15:02:46.653] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:02:47 obelisk prunner[1097]: [15:02:47.310] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/eccdffca-33d1-47b4-885a-9cf4612aea73/files/videos/4e81a73c-541d-463a-b3f5-113ba845b980/max-quality for job ptrjt-db28309a-3af0-4895-9fe5-4ef1318c547e. Running web video transcoding.
Jan 03 15:02:48 obelisk prunner[1097]: [15:02:48.594] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 465a5ce2-5dc5-4ac3-bf9d-e80ddb7a1376
Jan 03 15:02:48 obelisk prunner[1097]: [15:02:48.598] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/465a5ce2-5dc5-4ac3-bf9d-e80ddb7a1376/files/videos/f93119ad-1035-4cbd-8fa4-3d5cac8a1af3/max-quality for web video transcoding job ptrjt-8dc2b3f7-86d8-4fc7-9c8c-c79b1afe5db2
Jan 03 15:02:49 obelisk prunner[1097]: [15:02:49.971] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/013bf1ad-1640-46b3-bd61-29b350838565/files/videos/14db2af8-95ff-4047-8874-0dc1b5b482bb/max-quality for job ptrjt-7ca61f82-5159-42f6-b0b2-245d9f3140aa. Running web video transcoding.
Jan 03 15:02:51 obelisk prunner[1097]: [15:02:51.101] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:02:53 obelisk prunner[1097]: [15:02:53.267] ERROR (1097): Cannot request/accept job on https://tankie.tube for runner wally
Jan 03 15:02:53 obelisk prunner[1097]:     err: {
Jan 03 15:02:53 obelisk prunner[1097]:       "type": "Error",
Jan 03 15:02:53 obelisk prunner[1097]:       "message": "Expected status 200, got 400. \nThe server responded: \"This runner job is not in pending state\".\nYou may take a closer look at the logs. To see how to do so, check out this page: https://github.com/Chocobozzz/PeerTube/blob/develop/support/doc/development/tests.md#debug-server-logs",
Jan 03 15:02:53 obelisk prunner[1097]:       "stack":
Jan 03 15:02:53 obelisk prunner[1097]:           Error: Expected status 200, got 400.
Jan 03 15:02:53 obelisk prunner[1097]:           The server responded: "This runner job is not in pending state".
Jan 03 15:02:53 obelisk prunner[1097]:           You may take a closer look at the logs. To see how to do so, check out this page: https://github.com/Chocobozzz/PeerTube/blob/develop/support/doc/development/tests.md#debug-server-logs
Jan 03 15:02:53 obelisk prunner[1097]:               at buildRequest (file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:81177:14)
Jan 03 15:02:53 obelisk prunner[1097]:               at makePostBodyRequest (file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:81119:10)
Jan 03 15:02:53 obelisk prunner[1097]:               at RunnerJobsCommand.postBodyRequest (file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:81249:12)
Jan 03 15:02:53 obelisk prunner[1097]:               at RunnerJobsCommand.accept (file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:81770:28)
Jan 03 15:02:53 obelisk prunner[1097]:               at RunnerServer.tryToExecuteJobAsync (file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:94101:45)
Jan 03 15:02:53 obelisk prunner[1097]:               at RunnerServer.checkAvailableJobs (file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:94067:20)
Jan 03 15:02:53 obelisk prunner[1097]:               at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
Jan 03 15:02:53 obelisk prunner[1097]:           ----
Jan 03 15:02:53 obelisk prunner[1097]:               at file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:81180:19
Jan 03 15:02:53 obelisk prunner[1097]:               at file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:51102:17
Jan 03 15:02:53 obelisk prunner[1097]:               at Test._assertFunction (file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:51089:17)
Jan 03 15:02:53 obelisk prunner[1097]:               at Test.assert (file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:50980:27)
Jan 03 15:02:53 obelisk prunner[1097]:               at localAssert (file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:50949:18)
Jan 03 15:02:53 obelisk prunner[1097]:               at file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:50952:11
Jan 03 15:02:53 obelisk prunner[1097]:               at Request3.callback (file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:50520:7)
Jan 03 15:02:53 obelisk prunner[1097]:               at file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:50694:22
Jan 03 15:02:53 obelisk prunner[1097]:               at IncomingMessage.<anonymous> (file:///usr/lib/node_modules/@peertube/peertube-runner/dist/peertube-runner.js:50038:11)
Jan 03 15:02:53 obelisk prunner[1097]:               at IncomingMessage.emit (node:events:525:35)
Jan 03 15:02:53 obelisk prunner[1097]:       "res": {
Jan 03 15:02:53 obelisk prunner[1097]:         "req": {
Jan 03 15:02:53 obelisk prunner[1097]:           "method": "POST",
Jan 03 15:02:53 obelisk prunner[1097]:           "url": "https://tankie.tube/api/v1/runners/jobs/9f16cc86-57d5-4a2f-b211-2c83f35e2c71/accept",
Jan 03 15:02:53 obelisk prunner[1097]:           "data": {
Jan 03 15:02:53 obelisk prunner[1097]:             "runnerToken": "ptrt-[REDACTED]"
Jan 03 15:02:53 obelisk prunner[1097]:           },
Jan 03 15:02:53 obelisk prunner[1097]:           "headers": {
Jan 03 15:02:53 obelisk prunner[1097]:             "content-type": "application/json"
Jan 03 15:02:53 obelisk prunner[1097]:         "header": {
Jan 03 15:02:53 obelisk prunner[1097]:           "server": "nginx",
Jan 03 15:02:53 obelisk prunner[1097]:           "date": "Fri, 03 Jan 2025 21:02:53 GMT",
Jan 03 15:02:53 obelisk prunner[1097]:           "content-type": "application/problem+json; charset=utf-8",
Jan 03 15:02:53 obelisk prunner[1097]:           "content-length": "158",
Jan 03 15:02:53 obelisk prunner[1097]:           "connection": "close",
Jan 03 15:02:53 obelisk prunner[1097]:           "x-powered-by": "PeerTube",
Jan 03 15:02:53 obelisk prunner[1097]:           "x-frame-options": "DENY",
Jan 03 15:02:53 obelisk prunner[1097]:           "tk": "N",
Jan 03 15:02:53 obelisk prunner[1097]:           "access-control-allow-origin": "*",
Jan 03 15:02:53 obelisk prunner[1097]:           "access-control-allow-credentials": "true",
Jan 03 15:02:53 obelisk prunner[1097]:           "access-control-expose-headers": "Retry-After",
Jan 03 15:02:53 obelisk prunner[1097]:           "x-ratelimit-limit": "50",
Jan 03 15:02:53 obelisk prunner[1097]:           "x-ratelimit-remaining": "46",
Jan 03 15:02:53 obelisk prunner[1097]:           "x-ratelimit-reset": "1735938179",
Jan 03 15:02:53 obelisk prunner[1097]:           "etag": "W/\"9e-pQ72Id20rqUqUkbACcA8Oqhg9p0\""
Jan 03 15:02:53 obelisk prunner[1097]:         "status": 400,
Jan 03 15:02:53 obelisk prunner[1097]:         "text": "{\"type\":\"about:blank\",\"title\":\"Bad Request\",\"detail\":\"This runner job is not in pending state\",\"status\":400,\"error\":\"This runner job is not in pending state\"}"
Jan 03 15:02:55 obelisk prunner[1097]: [15:02:55.217] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/41dc5e24-be2b-4214-9b37-c375fc3bb48d/files/videos/39bf10d0-3e40-4744-be88-141db1b22fe1/max-quality for job ptrjt-67681077-e327-453c-83ca-c1cb85410531. Running web video transcoding.
Jan 03 15:03:02 obelisk prunner[1097]: [15:03:02.127] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/465a5ce2-5dc5-4ac3-bf9d-e80ddb7a1376/files/videos/f93119ad-1035-4cbd-8fa4-3d5cac8a1af3/max-quality for job ptrjt-8dc2b3f7-86d8-4fc7-9c8c-c79b1afe5db2. Running web video transcoding.
Jan 03 15:03:08 obelisk prunner[1097]: [15:03:08.400] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:03:10 obelisk prunner[1097]: [15:03:10.284] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: f11a982a-f99a-4281-b7e4-8a29a6381f00
Jan 03 15:03:10 obelisk prunner[1097]: [15:03:10.287] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/f11a982a-f99a-4281-b7e4-8a29a6381f00/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for HLS transcoding job ptrjt-c7c3fe51-53b1-4741-b337-18882c8ebcb7
Jan 03 15:03:12 obelisk prunner[1097]: [15:03:12.790] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:03:14 obelisk prunner[1097]: [15:03:14.637] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 56903c40-619a-4f80-b93c-0130e9b52253
Jan 03 15:03:14 obelisk prunner[1097]: [15:03:14.641] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/56903c40-619a-4f80-b93c-0130e9b52253/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for HLS transcoding job ptrjt-e9900fe6-d817-434e-b07f-d43084ca070c
Jan 03 15:03:16 obelisk prunner[1097]: [15:03:16.115] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/f11a982a-f99a-4281-b7e4-8a29a6381f00/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for job ptrjt-c7c3fe51-53b1-4741-b337-18882c8ebcb7. Running HLS transcoding.
Jan 03 15:03:17 obelisk prunner[1097]: [15:03:17.145] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:03:19 obelisk prunner[1097]: [15:03:19.018] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 9546bc99-cc6a-42ae-ac3a-4cd4539ac1e9
Jan 03 15:03:19 obelisk prunner[1097]: [15:03:19.021] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/9546bc99-cc6a-42ae-ac3a-4cd4539ac1e9/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for HLS transcoding job ptrjt-2d413823-3ddc-447a-8f45-299e2392f1a3
Jan 03 15:03:21 obelisk prunner[1097]: [15:03:21.523] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:03:22 obelisk prunner[1097]: [15:03:22.043] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/56903c40-619a-4f80-b93c-0130e9b52253/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for job ptrjt-e9900fe6-d817-434e-b07f-d43084ca070c. Running HLS transcoding.
Jan 03 15:03:23 obelisk prunner[1097]: [15:03:23.459] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 44ae76fa-b5cb-428a-9c8c-11ee1d602cad
Jan 03 15:03:23 obelisk prunner[1097]: [15:03:23.462] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/44ae76fa-b5cb-428a-9c8c-11ee1d602cad/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for HLS transcoding job ptrjt-b78e1f3b-c6da-4fcb-97b0-de7eacee4da3
Jan 03 15:03:25 obelisk prunner[1097]: [15:03:25.964] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:03:27 obelisk prunner[1097]: [15:03:27.920] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: c0fdc580-a208-405b-92aa-0d4438b512c9
Jan 03 15:03:27 obelisk prunner[1097]: [15:03:27.923] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/c0fdc580-a208-405b-92aa-0d4438b512c9/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for HLS transcoding job ptrjt-fef21a75-3cd7-433e-ba30-f26d9d2ec79a
Jan 03 15:03:29 obelisk prunner[1097]: [15:03:29.134] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/44ae76fa-b5cb-428a-9c8c-11ee1d602cad/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for job ptrjt-b78e1f3b-c6da-4fcb-97b0-de7eacee4da3. Running HLS transcoding.
Jan 03 15:03:29 obelisk prunner[1097]: [15:03:29.260] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/9546bc99-cc6a-42ae-ac3a-4cd4539ac1e9/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for job ptrjt-2d413823-3ddc-447a-8f45-299e2392f1a3. Running HLS transcoding.
Jan 03 15:03:30 obelisk prunner[1097]: [15:03:30.426] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:03:32 obelisk prunner[1097]: [15:03:32.602] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 092ec76b-f773-421d-836c-216f8f0574e9
Jan 03 15:03:32 obelisk prunner[1097]: [15:03:32.606] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/092ec76b-f773-421d-836c-216f8f0574e9/files/videos/bb2165f3-596f-4003-93eb-06404264a3d8/max-quality for web video transcoding job ptrjt-f04ad8d0-295f-467b-9480-03ce29b71343
Jan 03 15:03:34 obelisk prunner[1097]: [15:03:34.656] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/c0fdc580-a208-405b-92aa-0d4438b512c9/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for job ptrjt-fef21a75-3cd7-433e-ba30-f26d9d2ec79a. Running HLS transcoding.
Jan 03 15:03:35 obelisk prunner[1097]: [15:03:35.112] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:03:37 obelisk prunner[1097]: [15:03:37.025] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 900a9cd6-7714-4961-90ee-ec0abb31ddf5
Jan 03 15:03:37 obelisk prunner[1097]: [15:03:37.029] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/900a9cd6-7714-4961-90ee-ec0abb31ddf5/files/videos/67b93c80-a706-47ae-bb0d-6784b9ae7bd1/max-quality for web video transcoding job ptrjt-c5637ce1-7118-4cd1-8433-9a79d356a8fc
Jan 03 15:03:39 obelisk prunner[1097]: [15:03:39.534] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:03:40 obelisk prunner[1097]: [15:03:40.212] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/092ec76b-f773-421d-836c-216f8f0574e9/files/videos/bb2165f3-596f-4003-93eb-06404264a3d8/max-quality for job ptrjt-f04ad8d0-295f-467b-9480-03ce29b71343. Running web video transcoding.
Jan 03 15:03:41 obelisk prunner[1097]: [15:03:41.504] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/900a9cd6-7714-4961-90ee-ec0abb31ddf5/files/videos/67b93c80-a706-47ae-bb0d-6784b9ae7bd1/max-quality for job ptrjt-c5637ce1-7118-4cd1-8433-9a79d356a8fc. Running web video transcoding.
Jan 03 15:03:41 obelisk prunner[1097]: [15:03:41.607] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 9d9185c9-20a6-48d8-bd81-1dd78905623d
Jan 03 15:03:41 obelisk prunner[1097]: [15:03:41.613] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/9d9185c9-20a6-48d8-bd81-1dd78905623d/files/videos/a5883fa1-8ae6-4d00-b714-6661647e73b4/max-quality for web video transcoding job ptrjt-d7ec14af-2653-459f-9381-d0e35689c144
Jan 03 15:03:42 obelisk prunner[1097]: [15:03:42.969] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/9d9185c9-20a6-48d8-bd81-1dd78905623d/files/videos/a5883fa1-8ae6-4d00-b714-6661647e73b4/max-quality for job ptrjt-d7ec14af-2653-459f-9381-d0e35689c144. Running web video transcoding.
Jan 03 15:03:44 obelisk prunner[1097]: [15:03:44.118] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:03:46 obelisk prunner[1097]: [15:03:46.025] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 66af3c6b-1331-4417-a4e7-01232d985cdb
Jan 03 15:03:46 obelisk prunner[1097]: [15:03:46.028] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/66af3c6b-1331-4417-a4e7-01232d985cdb/files/videos/1de30408-8d1f-4e3e-89ed-25213899dd6f/max-quality for web video transcoding job ptrjt-0e154bf1-e1ae-4c50-bd8e-13c73a6e90ac
Jan 03 15:03:48 obelisk prunner[1097]: [15:03:48.529] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:03:50 obelisk prunner[1097]: [15:03:50.575] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: a028a60e-8b93-4282-9fd6-1e6ae5a480a2
Jan 03 15:03:50 obelisk prunner[1097]: [15:03:50.579] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/a028a60e-8b93-4282-9fd6-1e6ae5a480a2/files/videos/c7543c86-02d0-44db-ae64-92c13db01d4a/max-quality for web video transcoding job ptrjt-b9e14078-0576-422b-a1ae-add2754adad3
Jan 03 15:03:53 obelisk prunner[1097]: [15:03:53.083] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:03:55 obelisk prunner[1097]: [15:03:55.775] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 128a6703-724a-4d0d-b5a6-18e8c624b938
Jan 03 15:03:55 obelisk prunner[1097]: [15:03:55.778] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/128a6703-724a-4d0d-b5a6-18e8c624b938/files/videos/d79a8a56-2a08-4a9b-977e-23bde814435d/max-quality for web video transcoding job ptrjt-2139bae7-43f0-4db7-bf97-b61b6675ff03
Jan 03 15:03:58 obelisk prunner[1097]: [15:03:58.282] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:04:00 obelisk prunner[1097]: [15:04:00.412] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: bf0120a7-4dd4-481b-9e9b-a0e9ca16c6a9
Jan 03 15:04:00 obelisk prunner[1097]: [15:04:00.416] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/bf0120a7-4dd4-481b-9e9b-a0e9ca16c6a9/files/videos/839d5fa9-23bb-48a6-a8b3-ab97ba1bd3ef/max-quality for web video transcoding job ptrjt-e5414fb3-d490-4e6e-a11c-2f013408ccc0
Jan 03 15:04:02 obelisk prunner[1097]: [15:04:02.919] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:04:05 obelisk prunner[1097]: [15:04:05.442] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 7ed2b240-fd20-428c-be26-aea00e950bcf
Jan 03 15:04:05 obelisk prunner[1097]: [15:04:05.446] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/7ed2b240-fd20-428c-be26-aea00e950bcf/files/videos/8d142f17-f424-48ba-a114-21983acf6423/max-quality for web video transcoding job ptrjt-8a1c3e8c-afca-485b-8126-61832de7bde6
Jan 03 15:04:07 obelisk prunner[1097]: [15:04:07.951] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:04:09 obelisk prunner[1097]: [15:04:09.941] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/66af3c6b-1331-4417-a4e7-01232d985cdb/files/videos/1de30408-8d1f-4e3e-89ed-25213899dd6f/max-quality for job ptrjt-0e154bf1-e1ae-4c50-bd8e-13c73a6e90ac. Running web video transcoding.
Jan 03 15:04:11 obelisk prunner[1097]: [15:04:11.004] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 806df0b2-8a9f-443e-b367-f319ff9ccc5e
Jan 03 15:04:11 obelisk prunner[1097]: [15:04:11.014] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/806df0b2-8a9f-443e-b367-f319ff9ccc5e/files/videos/b74789c2-8575-4665-a9d9-253330be850a/max-quality for web video transcoding job ptrjt-eeeedc4a-a9e0-497d-8de4-20fca7dbe45b
Jan 03 15:04:33 obelisk prunner[1097]: [15:04:33.367] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/a028a60e-8b93-4282-9fd6-1e6ae5a480a2/files/videos/c7543c86-02d0-44db-ae64-92c13db01d4a/max-quality for job ptrjt-b9e14078-0576-422b-a1ae-add2754adad3. Running web video transcoding.
Jan 03 15:04:51 obelisk prunner[1097]: [15:04:51.931] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/806df0b2-8a9f-443e-b367-f319ff9ccc5e/files/videos/b74789c2-8575-4665-a9d9-253330be850a/max-quality for job ptrjt-eeeedc4a-a9e0-497d-8de4-20fca7dbe45b. Running web video transcoding.
Jan 03 15:04:54 obelisk prunner[1097]: [15:04:54.921] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/bf0120a7-4dd4-481b-9e9b-a0e9ca16c6a9/files/videos/839d5fa9-23bb-48a6-a8b3-ab97ba1bd3ef/max-quality for job ptrjt-e5414fb3-d490-4e6e-a11c-2f013408ccc0. Running web video transcoding.
Jan 03 15:05:02 obelisk prunner[1097]: [15:05:02.311] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/7ed2b240-fd20-428c-be26-aea00e950bcf/files/videos/8d142f17-f424-48ba-a114-21983acf6423/max-quality for job ptrjt-8a1c3e8c-afca-485b-8126-61832de7bde6. Running web video transcoding.
Jan 03 15:05:05 obelisk prunner[1097]: [15:05:05.744] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: f11a982a-f99a-4281-b7e4-8a29a6381f00
Jan 03 15:05:05 obelisk prunner[1097]: [15:05:05.746] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:05:07 obelisk prunner[1097]: [15:05:07.645] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 58cc7e54-1d14-41ec-9497-d92545cee539
Jan 03 15:05:07 obelisk prunner[1097]: [15:05:07.648] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/58cc7e54-1d14-41ec-9497-d92545cee539/files/videos/b3f45086-2137-4bd6-b1f4-318f32be9c14/max-quality for HLS transcoding job ptrjt-9a32b767-bf6c-473b-9f65-0dea5b0474af
Jan 03 15:05:12 obelisk prunner[1097]: [15:05:12.906] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/58cc7e54-1d14-41ec-9497-d92545cee539/files/videos/b3f45086-2137-4bd6-b1f4-318f32be9c14/max-quality for job ptrjt-9a32b767-bf6c-473b-9f65-0dea5b0474af. Running HLS transcoding.
Jan 03 15:05:38 obelisk prunner[1097]: [15:05:38.627] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/128a6703-724a-4d0d-b5a6-18e8c624b938/files/videos/d79a8a56-2a08-4a9b-977e-23bde814435d/max-quality for job ptrjt-2139bae7-43f0-4db7-bf97-b61b6675ff03. Running web video transcoding.
Jan 03 15:05:40 obelisk prunner[1097]: [15:05:40.908] INFO (1097): [https://tankie.tube] Finished processing job of type vod-web-video-transcoding: 9d9185c9-20a6-48d8-bd81-1dd78905623d
Jan 03 15:05:40 obelisk prunner[1097]: [15:05:40.909] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:05:43 obelisk prunner[1097]: [15:05:43.168] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 15101b7b-ed62-4988-b718-a4a27bc2804b
Jan 03 15:05:43 obelisk prunner[1097]: [15:05:43.172] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/15101b7b-ed62-4988-b718-a4a27bc2804b/files/videos/a5883fa1-8ae6-4d00-b714-6661647e73b4/max-quality for HLS transcoding job ptrjt-b7d95f81-44a6-4b4b-a4dd-80cbbe87e05b
Jan 03 15:05:44 obelisk prunner[1097]: [15:05:44.534] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/15101b7b-ed62-4988-b718-a4a27bc2804b/files/videos/a5883fa1-8ae6-4d00-b714-6661647e73b4/max-quality for job ptrjt-b7d95f81-44a6-4b4b-a4dd-80cbbe87e05b. Running HLS transcoding.
Jan 03 15:06:16 obelisk prunner[1097]: [15:06:16.232] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 9546bc99-cc6a-42ae-ac3a-4cd4539ac1e9
Jan 03 15:06:16 obelisk prunner[1097]: [15:06:16.232] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:06:18 obelisk prunner[1097]: [15:06:18.117] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 3aa061d0-7fe7-4f62-8b4b-edda36c96901
Jan 03 15:06:18 obelisk prunner[1097]: [15:06:18.120] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/3aa061d0-7fe7-4f62-8b4b-edda36c96901/files/videos/a5883fa1-8ae6-4d00-b714-6661647e73b4/max-quality for HLS transcoding job ptrjt-af3fb28f-b03b-4daa-8524-e0a5996f1388
Jan 03 15:06:21 obelisk prunner[1097]: [15:06:21.317] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/3aa061d0-7fe7-4f62-8b4b-edda36c96901/files/videos/a5883fa1-8ae6-4d00-b714-6661647e73b4/max-quality for job ptrjt-af3fb28f-b03b-4daa-8524-e0a5996f1388. Running HLS transcoding.
Jan 03 15:07:13 obelisk prunner[1097]: [15:07:13.178] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 3aa061d0-7fe7-4f62-8b4b-edda36c96901
Jan 03 15:07:13 obelisk prunner[1097]: [15:07:13.179] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:07:15 obelisk prunner[1097]: [15:07:15.600] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: c147400e-ab97-4aec-8b12-ca817331d62e
Jan 03 15:07:15 obelisk prunner[1097]: [15:07:15.603] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/c147400e-ab97-4aec-8b12-ca817331d62e/files/videos/a5883fa1-8ae6-4d00-b714-6661647e73b4/max-quality for HLS transcoding job ptrjt-26bdada0-3164-45fc-9bb0-5ceed9b62d45
Jan 03 15:07:18 obelisk prunner[1097]: [15:07:18.743] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/c147400e-ab97-4aec-8b12-ca817331d62e/files/videos/a5883fa1-8ae6-4d00-b714-6661647e73b4/max-quality for job ptrjt-26bdada0-3164-45fc-9bb0-5ceed9b62d45. Running HLS transcoding.
Jan 03 15:07:22 obelisk prunner[1097]: [15:07:22.570] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:07:29 obelisk prunner[1097]: [15:07:29.655] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 15101b7b-ed62-4988-b718-a4a27bc2804b
Jan 03 15:07:29 obelisk prunner[1097]: [15:07:29.656] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:07:31 obelisk prunner[1097]: [15:07:31.753] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: e847e882-7a41-4bce-9125-42b4584358f6
Jan 03 15:07:31 obelisk prunner[1097]: [15:07:31.757] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/e847e882-7a41-4bce-9125-42b4584358f6/files/videos/fa72cbaa-8eac-47b4-b950-bca4513e6bd4/max-quality for HLS transcoding job ptrjt-f8b445f3-8ad1-49ed-8493-d5e013dfcbc3
Jan 03 15:07:35 obelisk prunner[1097]: [15:07:35.249] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/e847e882-7a41-4bce-9125-42b4584358f6/files/videos/fa72cbaa-8eac-47b4-b950-bca4513e6bd4/max-quality for job ptrjt-f8b445f3-8ad1-49ed-8493-d5e013dfcbc3. Running HLS transcoding.
Jan 03 15:07:36 obelisk prunner[1097]: [15:07:36.772] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:08:32 obelisk prunner[1097]: [15:08:32.306] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:09:02 obelisk prunner[1097]: [15:09:02.588] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: c0fdc580-a208-405b-92aa-0d4438b512c9
Jan 03 15:09:02 obelisk prunner[1097]: [15:09:02.589] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:09:04 obelisk prunner[1097]: [15:09:04.432] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 4b239028-09c5-4aae-abde-c3338681d307
Jan 03 15:09:04 obelisk prunner[1097]: [15:09:04.435] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/4b239028-09c5-4aae-abde-c3338681d307/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for HLS transcoding job ptrjt-d530ff48-9b99-4c72-a6ad-3d732efd4607
Jan 03 15:09:10 obelisk prunner[1097]: [15:09:10.371] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/4b239028-09c5-4aae-abde-c3338681d307/files/videos/e6dfeed7-1a0d-4d5d-aae8-a28fbdaf98dc/max-quality for job ptrjt-d530ff48-9b99-4c72-a6ad-3d732efd4607. Running HLS transcoding.
Jan 03 15:09:39 obelisk prunner[1097]: [15:09:39.766] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: e847e882-7a41-4bce-9125-42b4584358f6
Jan 03 15:09:39 obelisk prunner[1097]: [15:09:39.767] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:09:41 obelisk prunner[1097]: [15:09:41.686] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 78345162-a1f7-4507-aec3-794860a1d410
Jan 03 15:09:41 obelisk prunner[1097]: [15:09:41.690] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/78345162-a1f7-4507-aec3-794860a1d410/files/videos/a5883fa1-8ae6-4d00-b714-6661647e73b4/max-quality for HLS transcoding job ptrjt-82751cd3-0521-4194-8262-8d31674693db
Jan 03 15:09:44 obelisk prunner[1097]: [15:09:44.742] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/78345162-a1f7-4507-aec3-794860a1d410/files/videos/a5883fa1-8ae6-4d00-b714-6661647e73b4/max-quality for job ptrjt-82751cd3-0521-4194-8262-8d31674693db. Running HLS transcoding.
Jan 03 15:09:57 obelisk prunner[1097]: [15:09:57.421] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 78345162-a1f7-4507-aec3-794860a1d410
Jan 03 15:09:57 obelisk prunner[1097]: [15:09:57.421] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:09:59 obelisk prunner[1097]: [15:09:59.347] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: c34e3f9a-b146-42ff-9f06-bdf60f79a878
Jan 03 15:09:59 obelisk prunner[1097]: [15:09:59.350] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/c34e3f9a-b146-42ff-9f06-bdf60f79a878/files/videos/b3f45086-2137-4bd6-b1f4-318f32be9c14/max-quality for HLS transcoding job ptrjt-2c7d4e6b-aa93-45e3-a614-5eced0383e5b
Jan 03 15:10:04 obelisk prunner[1097]: [15:10:04.955] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/c34e3f9a-b146-42ff-9f06-bdf60f79a878/files/videos/b3f45086-2137-4bd6-b1f4-318f32be9c14/max-quality for job ptrjt-2c7d4e6b-aa93-45e3-a614-5eced0383e5b. Running HLS transcoding.
Jan 03 15:11:22 obelisk prunner[1097]: [15:11:22.624] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: c34e3f9a-b146-42ff-9f06-bdf60f79a878
Jan 03 15:11:22 obelisk prunner[1097]: [15:11:22.625] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:11:25 obelisk prunner[1097]: [15:11:25.135] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: f424965f-b534-493a-bf82-e93fe972760d
Jan 03 15:11:25 obelisk prunner[1097]: [15:11:25.139] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/f424965f-b534-493a-bf82-e93fe972760d/files/videos/b3f45086-2137-4bd6-b1f4-318f32be9c14/max-quality for HLS transcoding job ptrjt-45ba0584-ac9e-4d9f-9407-8784907876be
Jan 03 15:11:30 obelisk prunner[1097]: [15:11:30.990] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/f424965f-b534-493a-bf82-e93fe972760d/files/videos/b3f45086-2137-4bd6-b1f4-318f32be9c14/max-quality for job ptrjt-45ba0584-ac9e-4d9f-9407-8784907876be. Running HLS transcoding.
Jan 03 15:11:36 obelisk prunner[1097]: [15:11:36.949] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 4b239028-09c5-4aae-abde-c3338681d307
Jan 03 15:11:36 obelisk prunner[1097]: [15:11:36.952] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:11:39 obelisk prunner[1097]: [15:11:39.113] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 3071ee58-7e89-45f9-9fd6-b4b76f6f3c59
Jan 03 15:11:39 obelisk prunner[1097]: [15:11:39.117] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/3071ee58-7e89-45f9-9fd6-b4b76f6f3c59/files/videos/78fca04f-f7cb-40b8-9c8d-4d1e42bd6c55/max-quality for web video transcoding job ptrjt-4153bcd2-c9ae-44f9-a641-8e958b5c6ef6
Jan 03 15:11:40 obelisk prunner[1097]: [15:11:40.132] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 58cc7e54-1d14-41ec-9497-d92545cee539
Jan 03 15:11:40 obelisk prunner[1097]: [15:11:40.133] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:11:42 obelisk prunner[1097]: [15:11:42.134] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: ed184417-0ab6-46c8-8392-a70c69746fd0
Jan 03 15:11:42 obelisk prunner[1097]: [15:11:42.138] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/ed184417-0ab6-46c8-8392-a70c69746fd0/files/videos/b3f45086-2137-4bd6-b1f4-318f32be9c14/max-quality for HLS transcoding job ptrjt-484db4ce-59fd-4fef-9977-d4207b1c55f8
Jan 03 15:11:42 obelisk prunner[1097]: [15:11:42.951] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/3071ee58-7e89-45f9-9fd6-b4b76f6f3c59/files/videos/78fca04f-f7cb-40b8-9c8d-4d1e42bd6c55/max-quality for job ptrjt-4153bcd2-c9ae-44f9-a641-8e958b5c6ef6. Running web video transcoding.
Jan 03 15:11:48 obelisk prunner[1097]: [15:11:48.438] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/ed184417-0ab6-46c8-8392-a70c69746fd0/files/videos/b3f45086-2137-4bd6-b1f4-318f32be9c14/max-quality for job ptrjt-484db4ce-59fd-4fef-9977-d4207b1c55f8. Running HLS transcoding.
Jan 03 15:11:52 obelisk prunner[1097]: [15:11:52.724] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 44ae76fa-b5cb-428a-9c8c-11ee1d602cad
Jan 03 15:11:52 obelisk prunner[1097]: [15:11:52.725] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:11:54 obelisk prunner[1097]: [15:11:54.607] INFO (1097): [https://tankie.tube] Processing job of type vod-web-video-transcoding: 50ced117-e85c-4be8-a4b7-481a88781b30
Jan 03 15:11:54 obelisk prunner[1097]: [15:11:54.612] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/50ced117-e85c-4be8-a4b7-481a88781b30/files/videos/f066c486-7dc9-4d9d-b5b8-807ecaafa0fb/max-quality for web video transcoding job ptrjt-76a28744-2d8e-43b6-b3aa-43ce689413e4
Jan 03 15:12:14 obelisk prunner[1097]: [15:12:14.383] INFO (1097): [https://tankie.tube] Finished processing job of type vod-web-video-transcoding: eccdffca-33d1-47b4-885a-9cf4612aea73
Jan 03 15:12:14 obelisk prunner[1097]: [15:12:14.384] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:12:16 obelisk prunner[1097]: [15:12:16.385] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 1a5e6a49-f496-4b17-8ad2-947f0f8d5b85
Jan 03 15:12:16 obelisk prunner[1097]: [15:12:16.388] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/1a5e6a49-f496-4b17-8ad2-947f0f8d5b85/files/videos/4e81a73c-541d-463a-b3f5-113ba845b980/max-quality for HLS transcoding job ptrjt-c7df26d6-9b29-4d6f-a480-859849df7602
Jan 03 15:12:17 obelisk prunner[1097]: [15:12:17.427] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/50ced117-e85c-4be8-a4b7-481a88781b30/files/videos/f066c486-7dc9-4d9d-b5b8-807ecaafa0fb/max-quality for job ptrjt-76a28744-2d8e-43b6-b3aa-43ce689413e4. Running web video transcoding.
Jan 03 15:12:29 obelisk prunner[1097]: [15:12:29.763] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/1a5e6a49-f496-4b17-8ad2-947f0f8d5b85/files/videos/4e81a73c-541d-463a-b3f5-113ba845b980/max-quality for job ptrjt-c7df26d6-9b29-4d6f-a480-859849df7602. Running HLS transcoding.
Jan 03 15:12:45 obelisk prunner[1097]: [15:12:45.632] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:14:08 obelisk prunner[1097]: [15:14:08.808] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:15:05 obelisk prunner[1097]: [15:15:05.533] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: c147400e-ab97-4aec-8b12-ca817331d62e
Jan 03 15:15:05 obelisk prunner[1097]: [15:15:05.534] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:15:07 obelisk prunner[1097]: [15:15:07.409] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 45f619e7-1ecb-40f1-bcde-61cb7e57ca04
Jan 03 15:15:07 obelisk prunner[1097]: [15:15:07.413] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/45f619e7-1ecb-40f1-bcde-61cb7e57ca04/files/videos/3a06dbd1-a2af-406e-9dc7-ea4d9ed0b193/max-quality for HLS transcoding job ptrjt-0dc17708-a94e-4204-a019-49ea98667200
Jan 03 15:15:13 obelisk prunner[1097]: [15:15:13.950] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/45f619e7-1ecb-40f1-bcde-61cb7e57ca04/files/videos/3a06dbd1-a2af-406e-9dc7-ea4d9ed0b193/max-quality for job ptrjt-0dc17708-a94e-4204-a019-49ea98667200. Running HLS transcoding.
Jan 03 15:15:28 obelisk prunner[1097]: [15:15:28.201] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 56903c40-619a-4f80-b93c-0130e9b52253
Jan 03 15:15:28 obelisk prunner[1097]: [15:15:28.202] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:15:30 obelisk prunner[1097]: [15:15:30.157] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 56ff1995-60a9-4d97-af8c-7a52cc9d88cf
Jan 03 15:15:30 obelisk prunner[1097]: [15:15:30.161] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/56ff1995-60a9-4d97-af8c-7a52cc9d88cf/files/videos/3a06dbd1-a2af-406e-9dc7-ea4d9ed0b193/max-quality for HLS transcoding job ptrjt-ea1bf6fa-964d-43f7-9125-a53814238578
Jan 03 15:15:30 obelisk prunner[1097]: [15:15:30.736] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:15:35 obelisk prunner[1097]: [15:15:35.891] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/56ff1995-60a9-4d97-af8c-7a52cc9d88cf/files/videos/3a06dbd1-a2af-406e-9dc7-ea4d9ed0b193/max-quality for job ptrjt-ea1bf6fa-964d-43f7-9125-a53814238578. Running HLS transcoding.
Jan 03 15:16:39 obelisk prunner[1097]: [15:16:39.503] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:17:07 obelisk prunner[1097]: [15:17:07.663] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:17:28 obelisk prunner[1097]: [15:17:28.168] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: f424965f-b534-493a-bf82-e93fe972760d
Jan 03 15:17:28 obelisk prunner[1097]: [15:17:28.169] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:17:30 obelisk prunner[1097]: [15:17:30.106] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 97982b6f-37cd-490e-8ef9-77e320d4b821
Jan 03 15:17:30 obelisk prunner[1097]: [15:17:30.109] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/97982b6f-37cd-490e-8ef9-77e320d4b821/files/videos/932d9219-45d2-4753-a7cc-e395fb8665e5/max-quality for HLS transcoding job ptrjt-dfd8ba50-3b66-45bf-be47-93c2224f88e5
Jan 03 15:17:43 obelisk prunner[1097]: [15:17:43.036] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/97982b6f-37cd-490e-8ef9-77e320d4b821/files/videos/932d9219-45d2-4753-a7cc-e395fb8665e5/max-quality for job ptrjt-dfd8ba50-3b66-45bf-be47-93c2224f88e5. Running HLS transcoding.
Jan 03 15:19:10 obelisk prunner[1097]: [15:19:10.968] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 45f619e7-1ecb-40f1-bcde-61cb7e57ca04
Jan 03 15:19:10 obelisk prunner[1097]: [15:19:10.970] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:19:13 obelisk prunner[1097]: [15:19:13.162] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 8bf9ffee-1480-4a77-b956-e820be3c7136
Jan 03 15:19:13 obelisk prunner[1097]: [15:19:13.165] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/8bf9ffee-1480-4a77-b956-e820be3c7136/files/videos/3a06dbd1-a2af-406e-9dc7-ea4d9ed0b193/max-quality for HLS transcoding job ptrjt-690ace2e-ff13-43ce-9b0f-934cee04e9ad
Jan 03 15:19:19 obelisk prunner[1097]: [15:19:19.333] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/8bf9ffee-1480-4a77-b956-e820be3c7136/files/videos/3a06dbd1-a2af-406e-9dc7-ea4d9ed0b193/max-quality for job ptrjt-690ace2e-ff13-43ce-9b0f-934cee04e9ad. Running HLS transcoding.
Jan 03 15:19:23 obelisk prunner[1097]: [15:19:23.636] INFO (1097): Checking available jobs on https://tankie.tube
Log continued.
Jan 03 15:19:34 obelisk prunner[1097]: [15:19:34.988] INFO (1097): [https://tankie.tube] Finished processing job of type vod-web-video-transcoding: 3071ee58-7e89-45f9-9fd6-b4b76f6f3c59
Jan 03 15:19:34 obelisk prunner[1097]: [15:19:34.989] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:19:36 obelisk prunner[1097]: [15:19:36.945] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 3f13173a-e8ef-4653-aaaa-2e099df07f58
Jan 03 15:19:36 obelisk prunner[1097]: [15:19:36.949] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/3f13173a-e8ef-4653-aaaa-2e099df07f58/files/videos/2be5b73d-8d8e-41e9-8ee6-65b176283003/max-quality for HLS transcoding job ptrjt-67f68faa-336f-4ead-8afc-9d5155106470
Jan 03 15:20:12 obelisk prunner[1097]: [15:20:12.251] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/3f13173a-e8ef-4653-aaaa-2e099df07f58/files/videos/2be5b73d-8d8e-41e9-8ee6-65b176283003/max-quality for job ptrjt-67f68faa-336f-4ead-8afc-9d5155106470. Running HLS transcoding.
Jan 03 15:20:32 obelisk prunner[1097]: [15:20:32.962] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:21:41 obelisk prunner[1097]: [15:21:41.691] INFO (1097): [https://tankie.tube] Finished processing job of type vod-web-video-transcoding: 74985816-e4f1-419b-9991-57b333850d3a
Jan 03 15:21:41 obelisk prunner[1097]: [15:21:41.692] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:21:43 obelisk prunner[1097]: [15:21:43.603] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: a84d1177-8d0c-4c76-8a40-02584ac25d7d
Jan 03 15:21:43 obelisk prunner[1097]: [15:21:43.606] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/a84d1177-8d0c-4c76-8a40-02584ac25d7d/files/videos/9876df1c-66be-41ae-8685-06fd31fb427f/max-quality for HLS transcoding job ptrjt-2da5af8f-c10a-42df-929a-00fc98882f44
Jan 03 15:21:50 obelisk prunner[1097]: [15:21:50.934] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/a84d1177-8d0c-4c76-8a40-02584ac25d7d/files/videos/9876df1c-66be-41ae-8685-06fd31fb427f/max-quality for job ptrjt-2da5af8f-c10a-42df-929a-00fc98882f44. Running HLS transcoding.
Jan 03 15:22:30 obelisk prunner[1097]: [15:22:30.480] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:22:56 obelisk prunner[1097]: [15:22:56.136] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: a84d1177-8d0c-4c76-8a40-02584ac25d7d
Jan 03 15:22:56 obelisk prunner[1097]: [15:22:56.137] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:22:58 obelisk prunner[1097]: [15:22:58.034] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 0f7f6d55-2186-449f-8dac-0be6a69ea181
Jan 03 15:22:58 obelisk prunner[1097]: [15:22:58.038] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/0f7f6d55-2186-449f-8dac-0be6a69ea181/files/videos/9876df1c-66be-41ae-8685-06fd31fb427f/max-quality for HLS transcoding job ptrjt-1f860392-6527-435f-9a59-9447039cf181
Jan 03 15:23:00 obelisk prunner[1097]: [15:23:00.007] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: ed184417-0ab6-46c8-8392-a70c69746fd0
Jan 03 15:23:00 obelisk prunner[1097]: [15:23:00.007] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:23:02 obelisk prunner[1097]: [15:23:02.159] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 4961634a-715c-4e3b-85af-334796c03c70
Jan 03 15:23:02 obelisk prunner[1097]: [15:23:02.162] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/4961634a-715c-4e3b-85af-334796c03c70/files/videos/9876df1c-66be-41ae-8685-06fd31fb427f/max-quality for HLS transcoding job ptrjt-97cf5f9b-c09e-4bc6-8ec4-3cb1690dd1aa
Jan 03 15:23:03 obelisk prunner[1097]: [15:23:03.883] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/0f7f6d55-2186-449f-8dac-0be6a69ea181/files/videos/9876df1c-66be-41ae-8685-06fd31fb427f/max-quality for job ptrjt-1f860392-6527-435f-9a59-9447039cf181. Running HLS transcoding.
Jan 03 15:23:10 obelisk prunner[1097]: [15:23:10.038] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/4961634a-715c-4e3b-85af-334796c03c70/files/videos/9876df1c-66be-41ae-8685-06fd31fb427f/max-quality for job ptrjt-97cf5f9b-c09e-4bc6-8ec4-3cb1690dd1aa. Running HLS transcoding.
Jan 03 15:23:25 obelisk prunner[1097]: [15:23:25.730] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 0f7f6d55-2186-449f-8dac-0be6a69ea181
Jan 03 15:23:25 obelisk prunner[1097]: [15:23:25.731] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:23:27 obelisk prunner[1097]: [15:23:27.559] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 808824f7-eee3-4aab-ae68-58bba3b2712a
Jan 03 15:23:27 obelisk prunner[1097]: [15:23:27.563] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/808824f7-eee3-4aab-ae68-58bba3b2712a/files/videos/3a06dbd1-a2af-406e-9dc7-ea4d9ed0b193/max-quality for HLS transcoding job ptrjt-df6eca0d-7f42-4839-aecd-36191e5355b8
Jan 03 15:23:34 obelisk prunner[1097]: [15:23:34.221] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/808824f7-eee3-4aab-ae68-58bba3b2712a/files/videos/3a06dbd1-a2af-406e-9dc7-ea4d9ed0b193/max-quality for job ptrjt-df6eca0d-7f42-4839-aecd-36191e5355b8. Running HLS transcoding.
Jan 03 15:24:10 obelisk prunner[1097]: [15:24:10.786] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:24:30 obelisk prunner[1097]: [15:24:30.401] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:24:31 obelisk prunner[1097]: [15:24:31.902] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 808824f7-eee3-4aab-ae68-58bba3b2712a
Jan 03 15:24:31 obelisk prunner[1097]: [15:24:31.903] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:24:33 obelisk prunner[1097]: [15:24:33.845] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 162cfb3c-5c58-44f4-adc9-7d0737bcec98
Jan 03 15:24:33 obelisk prunner[1097]: [15:24:33.848] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/162cfb3c-5c58-44f4-adc9-7d0737bcec98/files/videos/6b8f246d-1d94-430f-867d-6fff86e41876/max-quality for HLS transcoding job ptrjt-7ed680d5-c3e0-4ba2-b81c-6b2043964f35
Jan 03 15:24:46 obelisk prunner[1097]: [15:24:46.837] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/162cfb3c-5c58-44f4-adc9-7d0737bcec98/files/videos/6b8f246d-1d94-430f-867d-6fff86e41876/max-quality for job ptrjt-7ed680d5-c3e0-4ba2-b81c-6b2043964f35. Running HLS transcoding.
Jan 03 15:26:49 obelisk prunner[1097]: [15:26:49.158] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 97982b6f-37cd-490e-8ef9-77e320d4b821
Jan 03 15:26:49 obelisk prunner[1097]: [15:26:49.159] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:26:51 obelisk prunner[1097]: [15:26:51.000] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 755f305e-41e4-4d36-9e03-cf5b873dd1d7
Jan 03 15:26:51 obelisk prunner[1097]: [15:26:51.003] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/755f305e-41e4-4d36-9e03-cf5b873dd1d7/files/videos/6b8f246d-1d94-430f-867d-6fff86e41876/max-quality for HLS transcoding job ptrjt-603f3cc0-f467-4084-be97-8b41fca48eaf
Jan 03 15:27:07 obelisk prunner[1097]: [15:27:07.464] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/755f305e-41e4-4d36-9e03-cf5b873dd1d7/files/videos/6b8f246d-1d94-430f-867d-6fff86e41876/max-quality for job ptrjt-603f3cc0-f467-4084-be97-8b41fca48eaf. Running HLS transcoding.
Jan 03 15:27:11 obelisk prunner[1097]: [15:27:11.290] INFO (1097): [https://tankie.tube] Finished processing job of type vod-web-video-transcoding: 013bf1ad-1640-46b3-bd61-29b350838565
Jan 03 15:27:11 obelisk prunner[1097]: [15:27:11.291] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:27:13 obelisk prunner[1097]: [15:27:13.500] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 30027692-754e-43a6-ae5e-03ccb97a3dda
Jan 03 15:27:13 obelisk prunner[1097]: [15:27:13.503] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/30027692-754e-43a6-ae5e-03ccb97a3dda/files/videos/34bbf454-e6d6-42d6-b77d-86b5cbcf00b7/max-quality for HLS transcoding job ptrjt-21fba48a-6922-40f2-b6c0-3c804b1f99b5
Jan 03 15:27:33 obelisk prunner[1097]: [15:27:33.935] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/30027692-754e-43a6-ae5e-03ccb97a3dda/files/videos/34bbf454-e6d6-42d6-b77d-86b5cbcf00b7/max-quality for job ptrjt-21fba48a-6922-40f2-b6c0-3c804b1f99b5. Running HLS transcoding.
Jan 03 15:27:36 obelisk prunner[1097]: [15:27:36.763] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 3f13173a-e8ef-4653-aaaa-2e099df07f58
Jan 03 15:27:36 obelisk prunner[1097]: [15:27:36.764] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:27:38 obelisk prunner[1097]: [15:27:38.745] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 73988d2a-250b-45b9-bedf-e4eca5b95c69
Jan 03 15:27:38 obelisk prunner[1097]: [15:27:38.750] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/73988d2a-250b-45b9-bedf-e4eca5b95c69/files/videos/34bbf454-e6d6-42d6-b77d-86b5cbcf00b7/max-quality for HLS transcoding job ptrjt-871b8dc7-a384-44c1-9fab-482ceaf879f3
Jan 03 15:27:59 obelisk prunner[1097]: [15:27:59.470] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/73988d2a-250b-45b9-bedf-e4eca5b95c69/files/videos/34bbf454-e6d6-42d6-b77d-86b5cbcf00b7/max-quality for job ptrjt-871b8dc7-a384-44c1-9fab-482ceaf879f3. Running HLS transcoding.
Jan 03 15:28:46 obelisk prunner[1097]: [15:28:46.300] INFO (1097): [https://tankie.tube] Finished processing job of type vod-web-video-transcoding: 50ced117-e85c-4be8-a4b7-481a88781b30
Jan 03 15:28:46 obelisk prunner[1097]: [15:28:46.301] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:28:48 obelisk prunner[1097]: [15:28:48.134] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 0da7951c-8769-463b-a169-e100dba9ac42
Jan 03 15:28:48 obelisk prunner[1097]: [15:28:48.137] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/0da7951c-8769-463b-a169-e100dba9ac42/files/videos/14db2af8-95ff-4047-8874-0dc1b5b482bb/max-quality for HLS transcoding job ptrjt-7be28599-6958-4865-93a1-269674c9f518
Jan 03 15:29:15 obelisk prunner[1097]: [15:29:15.131] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/0da7951c-8769-463b-a169-e100dba9ac42/files/videos/14db2af8-95ff-4047-8874-0dc1b5b482bb/max-quality for job ptrjt-7be28599-6958-4865-93a1-269674c9f518. Running HLS transcoding.
Jan 03 15:29:18 obelisk prunner[1097]: [15:29:18.187] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:29:26 obelisk prunner[1097]: [15:29:26.613] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 755f305e-41e4-4d36-9e03-cf5b873dd1d7
Jan 03 15:29:26 obelisk prunner[1097]: [15:29:26.614] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:29:28 obelisk prunner[1097]: [15:29:28.662] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 67cddcc5-a809-40a5-ac5c-5eb5bc502750
Jan 03 15:29:28 obelisk prunner[1097]: [15:29:28.666] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/67cddcc5-a809-40a5-ac5c-5eb5bc502750/files/videos/14db2af8-95ff-4047-8874-0dc1b5b482bb/max-quality for HLS transcoding job ptrjt-09d14962-4177-4dc0-8430-6ec3ff412d0a
Jan 03 15:29:52 obelisk prunner[1097]: [15:29:52.772] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/67cddcc5-a809-40a5-ac5c-5eb5bc502750/files/videos/14db2af8-95ff-4047-8874-0dc1b5b482bb/max-quality for job ptrjt-09d14962-4177-4dc0-8430-6ec3ff412d0a. Running HLS transcoding.
Jan 03 15:30:40 obelisk prunner[1097]: [15:30:40.853] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:31:43 obelisk prunner[1097]: [15:31:43.528] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:32:50 obelisk prunner[1097]: [15:32:50.138] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:32:51 obelisk prunner[1097]: [15:32:51.590] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 67cddcc5-a809-40a5-ac5c-5eb5bc502750
Jan 03 15:32:51 obelisk prunner[1097]: [15:32:51.590] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:32:53 obelisk prunner[1097]: [15:32:53.632] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: cb5420f1-5c75-42a7-b9cc-aee73a9cd70c
Jan 03 15:32:53 obelisk prunner[1097]: [15:32:53.635] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/cb5420f1-5c75-42a7-b9cc-aee73a9cd70c/files/videos/25addcbc-73cf-4c46-94ec-a369456102fd/max-quality for HLS transcoding job ptrjt-10a046ba-aacd-4b82-86c1-00f7ebf7d3b9
Jan 03 15:33:10 obelisk prunner[1097]: [15:33:10.250] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/cb5420f1-5c75-42a7-b9cc-aee73a9cd70c/files/videos/25addcbc-73cf-4c46-94ec-a369456102fd/max-quality for job ptrjt-10a046ba-aacd-4b82-86c1-00f7ebf7d3b9. Running HLS transcoding.
Jan 03 15:33:34 obelisk prunner[1097]: [15:33:34.123] INFO (1097): [https://tankie.tube] Finished processing job of type vod-web-video-transcoding: 8a75a4a2-8272-4475-ad4f-fd1e6e6a8fc4
Jan 03 15:33:34 obelisk prunner[1097]: [15:33:34.124] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:33:36 obelisk prunner[1097]: [15:33:36.123] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: a63dc2e4-6ea3-4523-859c-cc0ca3651369
Jan 03 15:33:36 obelisk prunner[1097]: [15:33:36.127] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/a63dc2e4-6ea3-4523-859c-cc0ca3651369/files/videos/25addcbc-73cf-4c46-94ec-a369456102fd/max-quality for HLS transcoding job ptrjt-33a84cd2-ef72-4394-aea1-0a1b888c913e
Jan 03 15:33:52 obelisk prunner[1097]: [15:33:52.462] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/a63dc2e4-6ea3-4523-859c-cc0ca3651369/files/videos/25addcbc-73cf-4c46-94ec-a369456102fd/max-quality for job ptrjt-33a84cd2-ef72-4394-aea1-0a1b888c913e. Running HLS transcoding.
Jan 03 15:34:03 obelisk prunner[1097]: [15:34:03.248] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 8bf9ffee-1480-4a77-b956-e820be3c7136
Jan 03 15:34:03 obelisk prunner[1097]: [15:34:03.249] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:34:05 obelisk prunner[1097]: [15:34:05.346] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: d764a96e-2cc4-4a18-8469-dec3da0f9cb6
Jan 03 15:34:05 obelisk prunner[1097]: [15:34:05.349] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/d764a96e-2cc4-4a18-8469-dec3da0f9cb6/files/videos/25addcbc-73cf-4c46-94ec-a369456102fd/max-quality for HLS transcoding job ptrjt-7a7afba0-a766-4562-982c-562ae6efa40e
Jan 03 15:34:31 obelisk prunner[1097]: [15:34:31.923] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/d764a96e-2cc4-4a18-8469-dec3da0f9cb6/files/videos/25addcbc-73cf-4c46-94ec-a369456102fd/max-quality for job ptrjt-7a7afba0-a766-4562-982c-562ae6efa40e. Running HLS transcoding.
Jan 03 15:35:36 obelisk prunner[1097]: [15:35:36.633] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: d764a96e-2cc4-4a18-8469-dec3da0f9cb6
Jan 03 15:35:36 obelisk prunner[1097]: [15:35:36.634] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:35:38 obelisk prunner[1097]: [15:35:38.782] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 5f057e81-ffc9-4f32-995b-9d348922fe69
Jan 03 15:35:38 obelisk prunner[1097]: [15:35:38.784] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/5f057e81-ffc9-4f32-995b-9d348922fe69/files/videos/a4850405-0170-4749-8de5-88a460a431a5/max-quality for HLS transcoding job ptrjt-edc4bc37-e5f6-4e2a-b6d6-2d0bfe90bd40
Jan 03 15:35:51 obelisk prunner[1097]: [15:35:51.683] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:35:52 obelisk prunner[1097]: [15:35:52.261] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/5f057e81-ffc9-4f32-995b-9d348922fe69/files/videos/a4850405-0170-4749-8de5-88a460a431a5/max-quality for job ptrjt-edc4bc37-e5f6-4e2a-b6d6-2d0bfe90bd40. Running HLS transcoding.
Jan 03 15:35:58 obelisk prunner[1097]: [15:35:58.590] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:36:13 obelisk prunner[1097]: [15:36:13.175] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 4961634a-715c-4e3b-85af-334796c03c70
Jan 03 15:36:13 obelisk prunner[1097]: [15:36:13.176] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:36:15 obelisk prunner[1097]: [15:36:15.577] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 19d0f1ce-c196-4a49-a7a2-13d786ec685f
Jan 03 15:36:15 obelisk prunner[1097]: [15:36:15.579] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/19d0f1ce-c196-4a49-a7a2-13d786ec685f/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for HLS transcoding job ptrjt-8b3a674f-486f-49b9-bf0a-096a34dea2ea
Jan 03 15:36:17 obelisk prunner[1097]: [15:36:17.485] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:36:18 obelisk prunner[1097]: [15:36:18.680] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/19d0f1ce-c196-4a49-a7a2-13d786ec685f/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for job ptrjt-8b3a674f-486f-49b9-bf0a-096a34dea2ea. Running HLS transcoding.
Jan 03 15:37:44 obelisk prunner[1097]: [15:37:44.089] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:40:02 obelisk prunner[1097]: [15:40:02.581] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 56ff1995-60a9-4d97-af8c-7a52cc9d88cf
Jan 03 15:40:02 obelisk prunner[1097]: [15:40:02.581] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:40:04 obelisk prunner[1097]: [15:40:04.479] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: efd5f011-9b79-4963-b3df-9f7e025f8578
Jan 03 15:40:04 obelisk prunner[1097]: [15:40:04.480] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/efd5f011-9b79-4963-b3df-9f7e025f8578/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for HLS transcoding job ptrjt-ef953240-d269-4abb-924d-4edd4cae8cf1
Jan 03 15:40:07 obelisk prunner[1097]: [15:40:07.290] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/efd5f011-9b79-4963-b3df-9f7e025f8578/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for job ptrjt-ef953240-d269-4abb-924d-4edd4cae8cf1. Running HLS transcoding.
Jan 03 15:40:14 obelisk prunner[1097]: [15:40:14.389] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: efd5f011-9b79-4963-b3df-9f7e025f8578
Jan 03 15:40:14 obelisk prunner[1097]: [15:40:14.390] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:40:16 obelisk prunner[1097]: [15:40:16.384] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 5cdc895b-18af-4b21-910a-aa46a4b3b874
Jan 03 15:40:16 obelisk prunner[1097]: [15:40:16.385] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/5cdc895b-18af-4b21-910a-aa46a4b3b874/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for HLS transcoding job ptrjt-9e8755ec-6b70-4d17-b399-ae40729a646d
Jan 03 15:40:19 obelisk prunner[1097]: [15:40:19.506] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/5cdc895b-18af-4b21-910a-aa46a4b3b874/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for job ptrjt-9e8755ec-6b70-4d17-b399-ae40729a646d. Running HLS transcoding.
Jan 03 15:40:29 obelisk prunner[1097]: [15:40:29.916] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 5cdc895b-18af-4b21-910a-aa46a4b3b874
Jan 03 15:40:29 obelisk prunner[1097]: [15:40:29.917] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:40:31 obelisk prunner[1097]: [15:40:31.803] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: ae17c487-284d-45d9-a6f9-aa726f712071
Jan 03 15:40:31 obelisk prunner[1097]: [15:40:31.804] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/ae17c487-284d-45d9-a6f9-aa726f712071/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for HLS transcoding job ptrjt-ca5c9e8b-d862-48b6-9e4c-2644f3ff5b35
Jan 03 15:40:34 obelisk prunner[1097]: [15:40:34.827] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/ae17c487-284d-45d9-a6f9-aa726f712071/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for job ptrjt-ca5c9e8b-d862-48b6-9e4c-2644f3ff5b35. Running HLS transcoding.
Jan 03 15:40:42 obelisk prunner[1097]: [15:40:42.131] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: ae17c487-284d-45d9-a6f9-aa726f712071
Jan 03 15:40:42 obelisk prunner[1097]: [15:40:42.131] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:40:44 obelisk prunner[1097]: [15:40:44.056] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 967a0cf1-6956-476c-a9d0-29de679a6da9
Jan 03 15:40:44 obelisk prunner[1097]: [15:40:44.057] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/967a0cf1-6956-476c-a9d0-29de679a6da9/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for HLS transcoding job ptrjt-b041c8fc-d645-4f12-b680-91e7d9af80ab
Jan 03 15:40:46 obelisk prunner[1097]: [15:40:46.942] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/967a0cf1-6956-476c-a9d0-29de679a6da9/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for job ptrjt-b041c8fc-d645-4f12-b680-91e7d9af80ab. Running HLS transcoding.
Jan 03 15:42:34 obelisk prunner[1097]: [15:42:34.529] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 967a0cf1-6956-476c-a9d0-29de679a6da9
Jan 03 15:42:34 obelisk prunner[1097]: [15:42:34.529] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:42:36 obelisk prunner[1097]: [15:42:36.375] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: c604d4d6-f507-4f11-b0a9-1b56872e2a72
Jan 03 15:42:36 obelisk prunner[1097]: [15:42:36.376] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/c604d4d6-f507-4f11-b0a9-1b56872e2a72/files/videos/0e13ffa0-a063-4e3c-9e04-1c1568e43c60/max-quality for HLS transcoding job ptrjt-6a4dcd40-5716-4238-9dda-49707c86a2f8
Jan 03 15:42:41 obelisk prunner[1097]: [15:42:41.673] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/c604d4d6-f507-4f11-b0a9-1b56872e2a72/files/videos/0e13ffa0-a063-4e3c-9e04-1c1568e43c60/max-quality for job ptrjt-6a4dcd40-5716-4238-9dda-49707c86a2f8. Running HLS transcoding.
Jan 03 15:43:01 obelisk prunner[1097]: [15:43:01.231] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: c604d4d6-f507-4f11-b0a9-1b56872e2a72
Jan 03 15:43:01 obelisk prunner[1097]: [15:43:01.232] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:43:02 obelisk prunner[1097]: [15:43:02.045] INFO (1097): [https://tankie.tube] Finished processing job of type vod-web-video-transcoding: 806df0b2-8a9f-443e-b367-f319ff9ccc5e
Jan 03 15:43:03 obelisk prunner[1097]: [15:43:03.157] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 687ef0e8-e444-4b1f-9e6d-1788182abd03
Jan 03 15:43:03 obelisk prunner[1097]: [15:43:03.158] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/687ef0e8-e444-4b1f-9e6d-1788182abd03/files/videos/0e13ffa0-a063-4e3c-9e04-1c1568e43c60/max-quality for HLS transcoding job ptrjt-41e1d42d-df07-4323-98af-959cf7795446
Jan 03 15:43:05 obelisk prunner[1097]: [15:43:05.659] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:43:07 obelisk prunner[1097]: [15:43:07.597] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 3628e557-c310-405c-b17f-7f74eae37354
Jan 03 15:43:07 obelisk prunner[1097]: [15:43:07.598] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/3628e557-c310-405c-b17f-7f74eae37354/files/videos/0e13ffa0-a063-4e3c-9e04-1c1568e43c60/max-quality for HLS transcoding job ptrjt-4525f745-4f15-41a9-ae9e-a7b27a8cb70b
Jan 03 15:43:08 obelisk prunner[1097]: [15:43:08.127] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/687ef0e8-e444-4b1f-9e6d-1788182abd03/files/videos/0e13ffa0-a063-4e3c-9e04-1c1568e43c60/max-quality for job ptrjt-41e1d42d-df07-4323-98af-959cf7795446. Running HLS transcoding.
Jan 03 15:43:13 obelisk prunner[1097]: [15:43:13.163] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/3628e557-c310-405c-b17f-7f74eae37354/files/videos/0e13ffa0-a063-4e3c-9e04-1c1568e43c60/max-quality for job ptrjt-4525f745-4f15-41a9-ae9e-a7b27a8cb70b. Running HLS transcoding.
Jan 03 15:43:46 obelisk prunner[1097]: [15:43:46.385] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:44:05 obelisk prunner[1097]: [15:44:05.142] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 3628e557-c310-405c-b17f-7f74eae37354
Jan 03 15:44:05 obelisk prunner[1097]: [15:44:05.142] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:44:07 obelisk prunner[1097]: [15:44:07.116] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 8b5341b6-a3d1-49df-97d5-fb9f698d4788
Jan 03 15:44:07 obelisk prunner[1097]: [15:44:07.117] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/8b5341b6-a3d1-49df-97d5-fb9f698d4788/files/videos/0e13ffa0-a063-4e3c-9e04-1c1568e43c60/max-quality for HLS transcoding job ptrjt-7e14275a-12e4-4707-978f-57d9a946d300
Jan 03 15:44:12 obelisk prunner[1097]: [15:44:12.739] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/8b5341b6-a3d1-49df-97d5-fb9f698d4788/files/videos/0e13ffa0-a063-4e3c-9e04-1c1568e43c60/max-quality for job ptrjt-7e14275a-12e4-4707-978f-57d9a946d300. Running HLS transcoding.
Jan 03 15:44:29 obelisk prunner[1097]: [15:44:29.630] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 8b5341b6-a3d1-49df-97d5-fb9f698d4788
Jan 03 15:44:29 obelisk prunner[1097]: [15:44:29.631] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:44:32 obelisk prunner[1097]: [15:44:32.052] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 5314fc7e-3bdc-496a-8c9c-cdcc6d40e5ea
Jan 03 15:44:32 obelisk prunner[1097]: [15:44:32.053] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/5314fc7e-3bdc-496a-8c9c-cdcc6d40e5ea/files/videos/b74789c2-8575-4665-a9d9-253330be850a/max-quality for HLS transcoding job ptrjt-dfc8a2c7-8eb9-48d0-bd6f-436345f63286
Jan 03 15:45:05 obelisk prunner[1097]: [15:45:05.420] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/5314fc7e-3bdc-496a-8c9c-cdcc6d40e5ea/files/videos/b74789c2-8575-4665-a9d9-253330be850a/max-quality for job ptrjt-dfc8a2c7-8eb9-48d0-bd6f-436345f63286. Running HLS transcoding.
Jan 03 15:47:06 obelisk prunner[1097]: [15:47:06.021] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:47:35 obelisk prunner[1097]: [15:47:35.818] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:49:28 obelisk prunner[1097]: [15:49:28.184] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 5314fc7e-3bdc-496a-8c9c-cdcc6d40e5ea
Jan 03 15:49:28 obelisk prunner[1097]: [15:49:28.184] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:49:30 obelisk prunner[1097]: [15:49:30.024] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 5cdf5e2d-6f02-49b1-99b6-11d8f0610b42
Jan 03 15:49:30 obelisk prunner[1097]: [15:49:30.025] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/5cdf5e2d-6f02-49b1-99b6-11d8f0610b42/files/videos/b4ad97d1-483c-4e8e-9c6b-8378916cc901/max-quality for HLS transcoding job ptrjt-b7668d2e-1312-4b55-96eb-6959e66a7cc0
Jan 03 15:49:54 obelisk prunner[1097]: [15:49:54.419] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/5cdf5e2d-6f02-49b1-99b6-11d8f0610b42/files/videos/b4ad97d1-483c-4e8e-9c6b-8378916cc901/max-quality for job ptrjt-b7668d2e-1312-4b55-96eb-6959e66a7cc0. Running HLS transcoding.
Jan 03 15:50:33 obelisk prunner[1097]: [15:50:33.345] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 5cdf5e2d-6f02-49b1-99b6-11d8f0610b42
Jan 03 15:50:33 obelisk prunner[1097]: [15:50:33.346] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:50:35 obelisk prunner[1097]: [15:50:35.162] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: a05ffeba-5135-48f3-ad0b-606e2c3d6c79
Jan 03 15:50:35 obelisk prunner[1097]: [15:50:35.163] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/a05ffeba-5135-48f3-ad0b-606e2c3d6c79/files/videos/8155732d-353c-44ef-ad2f-18faf1bdc3b7/max-quality for HLS transcoding job ptrjt-ef229f8b-afe5-4bf1-b073-447517fcce90
Jan 03 15:51:19 obelisk prunner[1097]: [15:51:19.250] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/a05ffeba-5135-48f3-ad0b-606e2c3d6c79/files/videos/8155732d-353c-44ef-ad2f-18faf1bdc3b7/max-quality for job ptrjt-ef229f8b-afe5-4bf1-b073-447517fcce90. Running HLS transcoding.
Jan 03 15:55:52 obelisk prunner[1097]: [15:55:52.448] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 15:59:34 obelisk prunner[1097]: [15:59:34.044] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:00:35 obelisk prunner[1097]: [16:00:35.228] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 19d0f1ce-c196-4a49-a7a2-13d786ec685f
Jan 03 16:00:35 obelisk prunner[1097]: [16:00:35.228] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:00:37 obelisk prunner[1097]: [16:00:37.408] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 16eae205-8f2a-4385-97d7-06ed2c0f6f94
Jan 03 16:00:37 obelisk prunner[1097]: [16:00:37.409] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/16eae205-8f2a-4385-97d7-06ed2c0f6f94/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for HLS transcoding job ptrjt-41738d53-d5fd-463b-a2ea-2801a4e80968
Jan 03 16:00:40 obelisk prunner[1097]: [16:00:40.415] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/16eae205-8f2a-4385-97d7-06ed2c0f6f94/files/videos/ca715158-e012-4476-8477-b0918982047c/max-quality for job ptrjt-41738d53-d5fd-463b-a2ea-2801a4e80968. Running HLS transcoding.
Jan 03 16:01:09 obelisk prunner[1097]: [16:01:09.792] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:01:50 obelisk prunner[1097]: [16:01:50.285] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 687ef0e8-e444-4b1f-9e6d-1788182abd03
Jan 03 16:01:50 obelisk prunner[1097]: [16:01:50.285] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:01:52 obelisk prunner[1097]: [16:01:52.430] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: fc7044ee-d601-4fb5-a385-fc6b8563e4ac
Jan 03 16:01:52 obelisk prunner[1097]: [16:01:52.431] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/fc7044ee-d601-4fb5-a385-fc6b8563e4ac/files/videos/78fca04f-f7cb-40b8-9c8d-4d1e42bd6c55/max-quality for HLS transcoding job ptrjt-e4204fcd-0bff-4b93-a25d-19a6c6c66a2b
Jan 03 16:01:56 obelisk prunner[1097]: [16:01:56.867] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/fc7044ee-d601-4fb5-a385-fc6b8563e4ac/files/videos/78fca04f-f7cb-40b8-9c8d-4d1e42bd6c55/max-quality for job ptrjt-e4204fcd-0bff-4b93-a25d-19a6c6c66a2b. Running HLS transcoding.
Jan 03 16:04:51 obelisk prunner[1097]: [16:04:51.823] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:06:24 obelisk prunner[1097]: [16:06:24.114] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:07:13 obelisk prunner[1097]: [16:07:13.633] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:07:56 obelisk prunner[1097]: [16:07:56.783] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 16eae205-8f2a-4385-97d7-06ed2c0f6f94
Jan 03 16:07:56 obelisk prunner[1097]: [16:07:56.783] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:07:59 obelisk prunner[1097]: [16:07:59.406] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 6f06affa-d21d-43b2-b90c-ff81d51c7c91
Jan 03 16:07:59 obelisk prunner[1097]: [16:07:59.407] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/6f06affa-d21d-43b2-b90c-ff81d51c7c91/files/videos/a1d332d0-89d4-439f-9b74-b3e956af27e6/max-quality for HLS transcoding job ptrjt-b751bca3-417f-4610-b650-ba3bf13bbf40
Jan 03 16:08:02 obelisk prunner[1097]: [16:08:02.823] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/6f06affa-d21d-43b2-b90c-ff81d51c7c91/files/videos/a1d332d0-89d4-439f-9b74-b3e956af27e6/max-quality for job ptrjt-b751bca3-417f-4610-b650-ba3bf13bbf40. Running HLS transcoding.
Jan 03 16:08:11 obelisk prunner[1097]: [16:08:11.739] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:09:22 obelisk prunner[1097]: [16:09:22.508] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: fc7044ee-d601-4fb5-a385-fc6b8563e4ac
Jan 03 16:09:22 obelisk prunner[1097]: [16:09:22.508] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:09:24 obelisk prunner[1097]: [16:09:24.455] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 36312eab-5dbd-47bb-968c-f79573a17bb6
Jan 03 16:09:24 obelisk prunner[1097]: [16:09:24.456] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/36312eab-5dbd-47bb-968c-f79573a17bb6/files/videos/a804157b-75c0-4e3d-b006-1ddcfde795bf/max-quality for HLS transcoding job ptrjt-b6863d4b-4179-4cc3-ab1d-6b146051a8bd
Jan 03 16:09:46 obelisk prunner[1097]: [16:09:46.867] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/36312eab-5dbd-47bb-968c-f79573a17bb6/files/videos/a804157b-75c0-4e3d-b006-1ddcfde795bf/max-quality for job ptrjt-b6863d4b-4179-4cc3-ab1d-6b146051a8bd. Running HLS transcoding.
Jan 03 16:10:36 obelisk prunner[1097]: [16:10:36.991] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 6f06affa-d21d-43b2-b90c-ff81d51c7c91
Jan 03 16:10:36 obelisk prunner[1097]: [16:10:36.992] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:10:39 obelisk prunner[1097]: [16:10:39.041] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 3eb97e5c-c51b-4cd3-951c-02d765321f38
Jan 03 16:10:39 obelisk prunner[1097]: [16:10:39.044] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/3eb97e5c-c51b-4cd3-951c-02d765321f38/files/videos/a804157b-75c0-4e3d-b006-1ddcfde795bf/max-quality for HLS transcoding job ptrjt-369eceb6-deef-4d69-ac6b-60c70f622e36
Jan 03 16:10:57 obelisk prunner[1097]: [16:10:57.259] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/3eb97e5c-c51b-4cd3-951c-02d765321f38/files/videos/a804157b-75c0-4e3d-b006-1ddcfde795bf/max-quality for job ptrjt-369eceb6-deef-4d69-ac6b-60c70f622e36. Running HLS transcoding.
Jan 03 16:12:17 obelisk prunner[1097]: [16:12:17.456] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 36312eab-5dbd-47bb-968c-f79573a17bb6
Jan 03 16:12:17 obelisk prunner[1097]: [16:12:17.456] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:12:19 obelisk prunner[1097]: [16:12:19.461] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: 5babf107-64cb-4be2-bfde-b0564b1d023f
Jan 03 16:12:19 obelisk prunner[1097]: [16:12:19.463] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/5babf107-64cb-4be2-bfde-b0564b1d023f/files/videos/05c36be9-2ddc-4713-8899-21f9c860d13f/max-quality for HLS transcoding job ptrjt-5e2e1d26-d289-4c2b-bd82-02d4611eda84
Jan 03 16:13:39 obelisk prunner[1097]: [16:13:39.771] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:14:36 obelisk prunner[1097]: [16:14:36.922] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/5babf107-64cb-4be2-bfde-b0564b1d023f/files/videos/05c36be9-2ddc-4713-8899-21f9c860d13f/max-quality for job ptrjt-5e2e1d26-d289-4c2b-bd82-02d4611eda84. Running HLS transcoding.
Jan 03 16:14:39 obelisk prunner[1097]: [16:14:39.915] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:16:08 obelisk prunner[1097]: [16:16:08.274] INFO (1097): [https://tankie.tube] Finished processing job of type vod-hls-transcoding: 5babf107-64cb-4be2-bfde-b0564b1d023f
Jan 03 16:16:08 obelisk prunner[1097]: [16:16:08.275] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:16:10 obelisk prunner[1097]: [16:16:10.698] INFO (1097): [https://tankie.tube] Processing job of type vod-hls-transcoding: e148acda-3b74-4caf-bf5f-fb2d7808523d
Jan 03 16:16:10 obelisk prunner[1097]: [16:16:10.699] INFO (1097): Downloading input file https://tankie.tube/api/v1/runners/jobs/e148acda-3b74-4caf-bf5f-fb2d7808523d/files/videos/a6ee5d2e-81bd-4225-8b5c-1dd038d6ab62/max-quality for HLS transcoding job ptrjt-b5addaa1-1862-49c6-bdfc-e7b7eb76a173
Jan 03 16:16:17 obelisk prunner[1097]: [16:16:17.172] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:16:23 obelisk prunner[1097]: [16:16:23.345] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:16:50 obelisk prunner[1097]: [16:16:50.240] INFO (1097): Downloaded input file https://tankie.tube/api/v1/runners/jobs/e148acda-3b74-4caf-bf5f-fb2d7808523d/files/videos/a6ee5d2e-81bd-4225-8b5c-1dd038d6ab62/max-quality for job ptrjt-b5addaa1-1862-49c6-bdfc-e7b7eb76a173. Running HLS transcoding.
Jan 03 16:16:58 obelisk prunner[1097]: [16:16:58.832] INFO (1097): Checking available jobs on https://tankie.tube
Jan 03 16:17:29 obelisk prunner[1097]: [16:17:29.470] INFO (1097): Checking available jobs on https://tankie.tube
Hi, is a ffmpeg process running on the runner machine? If yes, it is consuming CPU?
What is your ffmpeg version?
