[Request] Function to delete all remote comments
After enabling remote search the instance got thousands of comments from instances which followed. Deleting these comments which are completely unrelated is only possible at 100 comments a time, with 10K comments this takes a lot of repetitive extra work.
Suggestion
Offer an option to only allow remote search on instances which are followed, instead of the default setting, instances which follow you.
Add an option to include comments, should not be enabled per default, imho.
There is a script to cleanup remote files:
I can’t find a script to cleanup remote comments, but maybe this could be the correct way to implement this (doing a script).
Has anyone got a solution for this? My instance has 9k such comments…
I’m not even sure why I have these in my system - they are all comments on videos on other servers, by other people… My server is only set to publish my own videos, unless I have that config’d wrong?
