Several hostname for same instance ?
Is it possible to configure several hostname one the same instance of peertube ?
If we try to access with another hostname, we got this error:
Cannot retrieve OAuth Client credentials: undefined. Ensure you have correctly configured PeerTube (config/ directory), in particular the “webserver” section.Cannot retrieve OAuth Client credentials: undefined. Ensure you have correctly configured PeerTube (config/ directory), in particular the “webserver” section.Cannot retrieve OAuth Client credentials: undefined. Ensure you have correctly configured PeerTube (config/ directory), in particular the “webserver” section.Cannot retrieve OAuth Client credentials: undefined. Ensure you have correctly configured PeerTube (config/ directory), in particular the “webserver” section.
It’s a normal reaction, but I would like to know if we can tweark it, to use with 2 differents URL address ?
If you mean two hostnames for the same peertube node, no it’s not possible for now.
If you want to add such feature, please create an issue: https://github.com/Chocobozzz/PeerTube/issues
