Hello. This is for a docker instllation. My setup is as follows, all machines are local within my network.
Peertube host:
local x86-64 machine with Ubuntu server 20.04 using docker
Reverse proxy
another local Ubuntu server 20.04 machine only used as a reverse proxy hosting nginx proxying about 10 other servers within my network
My docker-compose.yaml:
services:
# You can comment this webserver section if you want to use another webserver/proxy
# webserver:
# image: chocobozzz/peertube-webserver:latest
# If you don't want to use the official image and build one from sources:
# build:
# context: .
# dockerfile: Dockerfile.nginx
# env_file:
# - .env
# ports:
# - "80:80"
# - "443:443"
# volumes:
# - type: bind
# Switch sources if you downloaded the whole repository
#source: ../../nginx/peertube
# source: ./docker-volume/nginx/peertube
# target: /etc/nginx/conf.d/peertube.template
# - assets:/var/www/peertube/peertube-latest/client/dist:ro
# - ./docker-volume/data:/var/www/peertube/storage
# - certbot-www:/var/www/certbot
# - ./docker-volume/certbot/conf:/etc/letsencrypt
# depends_on:
# - peertube
# restart: "always"
# You can comment this certbot section if you want to use another webserver/proxy
# certbot:
# container_name: certbot
# image: certbot/certbot
# volumes:
# restart: unless-stopped
# entrypoint: /bin/sh -c "trap exit TERM; while :; do certbot renew --webroot -w /var/www/certbot; sleep 12h & wait $${!}; done;"
# depends_on:
# - webserver
peertube:
# build:
# context: .
# dockerfile: ./support/docker/production/Dockerfile.bullseye
image: chocobozzz/peertube:production-bullseye
# Use a static IP for this container because nginx does not handle proxy host change without reload
# This container could be restarted on crash or until the postgresql database is ready for connection
networks:
default:
ipv4_address: 172.19.0.42
env_file:
- .env
ports:
- "1935:1935" # If you don't want to use the live feature, you can comment this line
- "9000:9000" # If you provide your own webserver and reverse-proxy, otherwise not suitable for production
volumes:
- assets:/app/client/dist
- ./docker-volume/data:/data
- ./docker-volume/config:/config
depends_on:
- postgres
- redis
# - postfix
restart: "always"
postgres:
image: postgres:13-alpine
env_file:
- .env
volumes:
- ./docker-volume/db:/var/lib/postgresql/data
restart: "always"
redis:
image: redis:6-alpine
volumes:
- ./docker-volume/redis:/data
restart: "always"
# postfix:
# image: mwader/postfix-relay
# env_file:
# - .env
# volumes:
# - ./docker-volume/opendkim/keys:/etc/opendkim/keys
# restart: "always"
networks:
default:
ipam:
driver: default
config:
- subnet: 172.19.0.0/16
volumes:
assets:
# certbot-www:
My .env:
POSTGRES_USER="peertube"
POSTGRES_PASSWORD=<password>
# Postgres database name "peertube"
POSTGRES_DB=peertube
# Editable only with a suffix :
#POSTGRES_DB=peertube_prod
#PEERTUBE_DB_SUFFIX=_prod
PEERTUBE_DB_USERNAME="peertube"
PEERTUBE_DB_PASSWORD=<password>
PEERTUBE_DB_SSL=false
# Default to Postgres service name "postgres" in docker-compose.yml
PEERTUBE_DB_HOSTNAME=postgres
# Server configuration
PEERTUBE_WEBSERVER_HOSTNAME="nightshift.minnix.dev"
# If you do not use https and a reverse-proxy in docker-compose.yml
PEERTUBE_WEBSERVER_PORT=443
PEERTUBE_WEBSERVER_HTTPS=true
# If you need more than one IP as trust_proxy
# pass them as a comma separated array:
PEERTUBE_TRUST_PROXY=["127.0.0.1", "loopback", "172.19.0.0/16"]
# E-mail configuration
# If you use a Custom SMTP server
PEERTUBE_SMTP_USERNAME=me@myemail.com
PEERTUBE_SMTP_PASSWORD=<password>
# Default to Postfix service name "postfix" in docker-compose.yml
# May be the hostname of your Custom SMTP server
PEERTUBE_SMTP_HOSTNAME=mail.myserver.com
PEERTUBE_SMTP_PORT=587
PEERTUBE_SMTP_FROM=me@myemail.com
PEERTUBE_SMTP_TLS=false
PEERTUBE_SMTP_DISABLE_STARTTLS=false
PEERTUBE_ADMIN_EMAIL=me@myemail.com
# Postfix service configuration
#POSTFIX_myhostname=<MY DOMAIN>
# If you need to generate a list of sub/DOMAIN keys
# pass them as a whitespace separated string <DOMAIN>=<selector>
#OPENDKIM_DOMAINS=<MY DOMAIN>=peertube
# see https://github.com/wader/postfix-relay/pull/18
#OPENDKIM_RequireSafeKeys=no
# /!\ Prefer to use the PeerTube admin interface to set the following configurations /!\
#PEERTUBE_SIGNUP_ENABLED=true
#PEERTUBE_TRANSCODING_ENABLED=true
#PEERTUBE_CONTACT_FORM_ENABLED=true
I’m assuming I won’t need the webserver, certbot, or postfix blocks since I have an nginx proxy already and SSL is terminated there so I’ve commented those out. Please correct me if I’m wrong. I am having trouble with the nginx conf as I’m not sure what to change within the configuration so that it suits my use case. For reference, this is what I have and it doesnt work:
Nginx conf hosted on reverse proxy server. I’ve commented out both the ssl certificaate locations as they will be generated automatically when i run certbot:
# Please check your Nginx installation features the following modules via 'nginx -V':
# STANDARD HTTP MODULES: Core, Proxy, Rewrite, Access, Gzip, Headers, HTTP/2, Log, Real IP, SSL, Thread Pool, Upstream, AIO Multithreading.
# THIRD PARTY MODULES: None.
server {
listen 80;
listen [::]:80;
server_name nightshift.minnix.dev;
default_type "text/plain";
root /var/www/certbot;
upstream backend {
server 192.168.57.145:9000;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
error_log /var/log/nginx/peertube.error.log;
# Certificates
# you need a certificate to run in production. see https://letsencrypt.org/
#ssl_certificate /etc/letsencrypt/live/${WEBSERVER_HOST}/fullchain.pem;
#ssl_certificate_key /etc/letsencrypt/live/${WEBSERVER_HOST}/privkey.pem;
# Security hardening (as of Nov 15, 2020)
# based on Mozilla Guideline v5.6
ssl_protocols TLSv1.2 TLSv1.3;
ssl_prefer_server_ciphers on;
ssl_ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256; # add ECDHE-RSA-AES256-SHA if you want compatibility with Android 4
ssl_session_timeout 1d; # defaults to 5m
ssl_session_cache shared:SSL:10m; # estimated to 40k sessions
ssl_session_tickets off;
ssl_stapling on;
ssl_stapling_verify on;
# HSTS (https://hstspreload.org), requires to be copied in 'location' sections that have add_header directives
#add_header Strict-Transport-Security "max-age=63072000; includeSubDomains";
# Application
location @api {
proxy_set_header Host $host;
client_max_body_size 100k; # default is 1M
proxy_connect_timeout 10m;
proxy_send_timeout 10m;
proxy_read_timeout 10m;
send_timeout 10m;
proxy_pass http://backend;
location / {
try_files /dev/null @api;
location = /api/v1/videos/upload-resumable {
client_max_body_size 0;
proxy_request_buffering off;
location = /api/v1/videos/upload {
# on a dedicated filesystem.
client_max_body_size 12G; # default is 1M
add_header X-File-Maximum-Size 8G always; # inform backend of the set value in bytes before mime-encoding (x * 1.4 >= client_max_body_size)
client_max_body_size 6M; # default is 1M
add_header X-File-Maximum-Size 4M always; # inform backend of the set value in bytes before mime-encoding (x * 1.4 >= client_max_body_size)
# Websocket
location @api_websocket {
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
location /socket.io {
location /tracker/socket {
# Performance optimizations
gzip on;
gzip_vary on;
gzip_types # text/html is always compressed by HttpGzipModule
text/css
application/javascript
font/truetype
font/opentype
application/vnd.ms-fontobject
image/svg+xml;
gzip_min_length 1000; # default is 20 bytes
gzip_buffers 16 8k;
gzip_comp_level 2; # default is 1
client_body_timeout 30s; # default is 60
client_header_timeout 10s; # default is 60
send_timeout 10s; # default is 60
keepalive_timeout 10s; # default is 75
resolver_timeout 10s; # default is 30
reset_timedout_connection on;
proxy_ignore_client_abort on;
tcp_nopush on; # send headers in one piece
tcp_nodelay on; # don't buffer data sent, good for small data bursts in real time
# If you have a small /var/lib partition, it could be interesting to store temp nginx uploads in a different place
# See https://nginx.org/en/docs/http/ngx_http_core_module.html#client_body_temp_path
# Should be consistent with client-overrides assets list in /server/controllers/client.ts
location ~ ^/client/(assets/images/(icons/icon-36x36\.png|icons/icon-48x48\.png|icons/icon-72x72\.png|icons/icon-96x96\.png|icons/icon-144x144\.png|icons/icon-192x192\.png|icons/icon-512x512\.png|logo\.svg|favicon\.png|default-playlist\.jpg|default-avatar-account\.png|default-avatar-video-channel\.png))$ {
add_header Cache-Control "public, max-age=31536000, immutable"; # Cache 1 year
root /var/www/peertube;
try_files /storage/client-overrides/$1 /peertube-latest/client/dist/$1 @api;
add_header Access-Control-Allow-Origin '*';
add_header Access-Control-Allow-Methods 'GET, OPTIONS';
add_header Access-Control-Allow-Headers 'Range,DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type';
add_header Access-Control-Max-Age 1728000; # Preflight request can be cached 20 days
add_header Content-Type 'text/plain charset=UTF-8';
add_header Content-Length 0;
return 204;
add_header Cache-Control "public, max-age=7200"; # Cache response 2 hours
rewrite ^/static/(.*)$ /$1 break;
try_files $uri @api;
location ~ ^/static/(webseed|redundancy|streaming-playlists)/ {
limit_rate_after 5M;
set $peertube_limit_rate 800k;
# Increase rate limit in HLS mode, because we don't have multiple simultaneous connections
if ($request_uri ~ -fragmented.mp4$) {
set $peertube_limit_rate 5M;
#limit_rate $peertube_limit_rate;
# Or this line if your nginx < 1.17.0
set $limit_rate $peertube_limit_rate;
return 204;
access_log off;
sendfile on;
sendfile_max_chunk 1M; # prevent one fast connection from entirely occupying the worker process. should be > 800k.
aio threads;
What changes do I need to make to any of these files when running a reverse proxy on another machine?
