I search the good way for modify mobilizon home page. I don’t find anyhting in the documentation nor in the forum…
Is it possible and supported ? (color, footer, homepage, picture)
I found that all css and pics are in /home/mobilizon/live/priv/static but I don’t want to broke something !
With a source install you can track your changes with git so you’re fairly safe to perform changes.
The biggest blocker to provide an easy way to change the theme or provide a theme system is our CSS framework which doesn’t support CSS variables to allow us to change the theme without recompiling the front-end: https://github.com/jgthms/bulma/issues/3028
Thanks for the explanation. I think I don’t have the skills to do what is needed at this point.
I will follow the roadmap and hope that it will be easier soon…
