Too many dependencies problems on develop branch with docker compose
I’m installing peertube with docker compose in order to work inside the container in bind mount mode. Essentially, according the documentation i’m started from the official docker compose files, downloaded the official repo from github, and mounted inside the container.
So, perhaps everything seems to be ok, i get too many dependecies errors such as, but not only:
2024-11-08 17:13:31 [0] Error: Cannot find module '/app/client/node_modules/.bin/ng'
2024-11-08 17:13:31 [0]     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
2024-11-08 17:13:31 [0]     at Module._load (node:internal/modules/cjs/loader:981:27)
2024-11-08 17:13:31 [0]     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
2024-11-08 17:13:31 [0]     at node:internal/main/run_main_module:28:49 {
2024-11-08 17:13:31 [0]   code: 'MODULE_NOT_FOUND',
My question is: there is a way in order to develop directly from the repo inside a docker container in bind mode way?
I attach my configuration files:
version: '3.8'
services:
  # You can comment this webserver section if you want to use another webserver/proxy or test PeerTube in local
  webserver:
    image: chocobozzz/peertube-webserver:latest
    # If you don't want to use the official image and build one from sources:
    # build:
    #   context: .
    #   dockerfile: Dockerfile.nginx
    env_file:
      - .env
    ports:
     - "80:80"
     - "443:443"
    volumes:
      - type: bind
        # Switch sources if you downloaded the whole repository
        source: ./PeerTube/support/nginx/peertube
        #source: ./docker-volume/nginx/peertube
        target: /etc/nginx/conf.d/peertube.template
      - assets:/var/www/peertube/peertube-latest/client/dist:ro
      - ./docker-volume/data:/var/www/peertube/storage
      - certbot-www:/var/www/certbot
      - ./docker-volume/certbot/conf:/etc/letsencrypt
      - ./certs:/etc/letsencrypt/live/localhost
    depends_on:
      - peertube
    restart: "always"
  # You can comment this certbot section if you want to use another webserver/proxy or test PeerTube in local
  certbot:
    container_name: certbot
    image: certbot/certbot
    volumes:
    restart: unless-stopped
    entrypoint: /bin/sh -c "trap exit TERM; while :; do certbot renew --webroot -w /var/www/certbot; sleep 12h & wait $${!}; done;"
    depends_on:
      - webserver
  peertube:
    build:
      dockerfile: ./Dockerfile
    #image: chocobozzz/peertube:production-bookworm
    # Use a static IP for this container because nginx does not handle proxy host change without reload
    # This container could be restarted on crash or until the postgresql database is ready for connection
    networks:
      default:
        ipv4_address: 172.18.0.42
    env_file:
      - .env
    ports:
      - "1935:1935" # Comment if you don't want to use the live feature
      - "3000:3000" # Client dev port
      #- "9000:9000" # Uncomment if you use another webserver/proxy or test PeerTube in local, otherwise not suitable for production
    volumes:
      - ./PeerTube:/app
      - ./entrypoint.sh:/app/entrypoint.sh
    depends_on:
      - postgres
      - redis
      - postfix
    #restart: "always"
    working_dir: /app
    entrypoint: ./entrypoint.sh
  postgres:
    image: postgres:13-alpine
    env_file:
      - .env
    volumes:
      - ./docker-volume/db:/var/lib/postgresql/data
    restart: "always"
  redis:
    image: redis:6-alpine
    volumes:
      - ./docker-volume/redis:/data
    restart: "always"
  postfix:
    image: mwader/postfix-relay
    env_file:
      - .env
    volumes:
      - ./docker-volume/opendkim/keys:/etc/opendkim/keys
    restart: "always"
networks:
  default:
    driver: bridge
    ipam:
      driver: default
      config:
        - subnet: 172.18.0.0/16
          gateway: 172.18.0.1
volumes:
  assets:
  certbot-www:
Dockerfile:
FROM node:18-bookworm-slim
# Install dependencies
RUN apt update \
 && apt install -y --no-install-recommends openssl ffmpeg python3 python3-pip ca-certificates gnupg gosu build-essential curl git \
 && gosu nobody true \
 && rm /var/lib/apt/lists/* -fR
# Add peertube user
RUN groupadd -r peertube \
    && useradd -r -g peertube -m peertube
# Install PeerTube
WORKDIR /app
USER root
RUN mkdir /data /config
RUN chown -R peertube:peertube /data /config
ENV NODE_ENV production
ENV NODE_CONFIG_DIR /app/config:/app/support/docker/production/config:/config
ENV PEERTUBE_LOCAL_CONFIG /config
VOLUME /data
VOLUME /config
# Expose API and RTMP
EXPOSE 9000 3000 1935
My Entrypoint:
#!/bin/bash
chown -R peertube:peertube .
echo "Install concurrently"
yarn global add concurrently
echo "Install Angular CLI"
yarn global add @angular/cli
echo "Installed Angular CLI"
yarn global add typescript
echo "Installed TSC"
yarn install --pure-lockfile
yarn dev
exit
In my entrypoint a have already tried to solve the dependencies errors without success.
Let me know.
It is possibile to know something about? Because if i open a bug on github, and then you tell me to write here, but no one reply, i don’t know what to say.
You mean « develop on Peertube »? Right? (not « developp Peertube plugins »?)
You don’t need certbot for a dev instance.
You can also do it without nginx.
And postfix could be replaced by something like « mailpit » (which allow to intercept any outgoing mail in a kind of webmail).
And I think it would be simpler to just forget about any entrypoint.
Just use a « debian-slim » image, install Peertube dependencies using the Dockerfile (ffmpeg, yarn, npm, …).
Then, log into your container using bash, and follow the dev documentation (configure as a dev instance, use yarn to install, then npm run dev:server)
Your dev server will be available on http://localhost:9000
For yarn to be able to install dependencies, you will also probably map the docker user and group ID to your current UID and GID. So it can write in the node_modules directory (or maybe you could map a writable module to this directory?).
I did never test this kind of setup, that’s just some idea that should theoretically work).
