Trust_proxy setting
I’m not sure how to set trust_proxy parameter in production.yaml file. My instance run on a server with a reverse proxy server in front of it. In this case should I have to set it to ‘loopback’?
Laurent
Is it a remote reverse proxy or a local reverse proxy?
If local reverse proxy means a reverse proxy in the LAN then that’s it.
