I’m trying to upgrade from 6.03 to 6.1 & this is my error…
Backing up PostgreSQL database in /mnt/2/var/www/videos.domain.org/peertube/backup/sql-peertube_prod-20240524-0813.bak
pg_dump: error: query failed: ERROR: permission denied for schema pgagent
pg_dump: detail: Query was: COPY pgagent.pga_jobagent (jagpid, jaglogintime, jagstation) TO stdout;
I’m not asked for a password. I had to edit my script.sh to include the proper directory.
Hi @Tyler_h
Since 24th may did you resolve your problem ?
For me, it is unclear what actions or pg_dump script arguments you did to create this backup.
Best Regards
I had to give my Postgres peertube user more rights in order to do the backup.
Stop the PeerTube service
sudo systemctl stop peertube && sudo su - postgres
pg_dump -Fc peertube_prod > ~/peertube_prod-dump.db
sudo systemctl start peertube
The file is located /var/lib/postgresql/
When restoring the rights remain postgres
