Hello!
I set up a peertube instance yet uploading to it - even on local network with1Gbit is painfully slow,
I tried to play with some configs but none had any effect.
Uploading the file with SFTP works at normal speed but thru webbrowser it takes hours…
Anyone has any idea how to resolve this please?
Thanks
Can you display the network log of your web browser?
I don’t know exactly what you’re looking for and well I use firefox normally so here you go
The only thing I found that is related to the upload.
How is your peertube instance deployed? Docker? VM? Baremetal?
I simply followed the AnyOS guide and installed it on a dedicated machine.
Could you link here the instructions you’ve followed?
