Dear Team,
I’m new to PeerTube and am using a Linux installation (no Docker). Everything works perfectly on newer devices, but I am encountering an issue with my older Android 10 system in the car (Xtrons PX6).
After installing the app, it starts correctly (though it throws an « unsupported » message, it still launches). I can connect to my instance via IPSec without any issues. However, when I try to play any videos, I get the following error:
PlatformException(VideoError, Video player had error e1.m: MediaCodeVideoRenderer error, index=0, format=Format(1, null, video/mp4, video/avc, avc 1.64001F, 328000, und, [720, 720, 25.0, Colorinfo(BT709, Limited range, SDR SMPTE 170M, false, 8bit Luma, 8bit Chroma)], [-1,-1]), format_supported=YES, null, null)
Could you help me identify if the issue is related to codecs or suggest any troubleshooting steps? I’m wondering if I should try different transcoding options or something else.
Thank you for your hard work—this ecosystem looks very promising!
Best regards,
Jaroslav
