Waiting transcoding
latest peertube 6.2.1
uploaded videos are waiting for transcoding
error[9/4/2024, 12:18:48 PM] uncaughtException: « length » is outside of buffer bounds RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: « length » is outside of buffer bounds at proto.utf8Write (node:internal/buffer:1066:13) at Packr.encodeUtf8 (/var/www/peertube/versions/peertube-v6.2.1/node_modules/msgpackr/dist/node.cjs:1211:18) at pack (/var/www/peertube/versions/peertube-v6.2.1/node_modules/msgpackr/dist/node.cjs:1504:15) at packArray (/var/www/peertube/versions/peertube-v6.2.1/node_modules/msgpackr/dist/node.cjs:1418:5) at pack (/var/www/peertube/versions/peertube-v6.2.1/node_modules/msgpackr/dist/node.cjs:1604:7) at Packr.pack.encode (/var/www/peertube/versions/peertube-v6.2.1/node_modules/msgpackr/dist/node.cjs:1309:6) at Scripts.addStandardJob (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/scripts.js:99:19) at Scripts.addJob (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/scripts.js:143:33) at Job.addJob (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/job.js:782:29) at FlowProducer.addNode (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/flow-producer.js:183:17) at /var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/flow-producer.js:243:39 at Array.map () at FlowProducer.addChildren (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/flow-producer.js:243:22) at FlowProducer.addNode (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/flow-producer.js:168:35) at /var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/flow-producer.js:243:39 at Array.map ()
« error »: {
« stack »: « RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: "length" is outside of buffer bounds\n at proto.utf8Write (node:internal/buffer:1066:13)\n at Packr.encodeUtf8 (/var/www/peertube/versions/peertube-v6.2.1/node_modules/msgpackr/dist/node.cjs:1211:18)\n at pack (/var/www/peertube/versions/peertube-v6.2.1/node_modules/msgpackr/dist/node.cjs:1504:15)\n at packArray (/var/www/peertube/versions/peertube-v6.2.1/node_modules/msgpackr/dist/node.cjs:1418:5)\n at pack (/var/www/peertube/versions/peertube-v6.2.1/node_modules/msgpackr/dist/node.cjs:1604:7)\n at Packr.pack.encode (/var/www/peertube/versions/peertube-v6.2.1/node_modules/msgpackr/dist/node.cjs:1309:6)\n at Scripts.addStandardJob (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/scripts.js:99:19)\n at Scripts.addJob (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/scripts.js:143:33)\n at Job.addJob (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/job.js:782:29)\n at FlowProducer.addNode (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/flow-producer.js:183:17)\n at /var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/flow-producer.js:243:39\n at Array.map ()\n at FlowProducer.addChildren (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/flow-producer.js:243:22)\n at FlowProducer.addNode (/var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/flow-producer.js:168:35)\n at /var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/flow-producer.js:243:39\n at Array.map () »,
« code »: « ERR_BUFFER_OUT_OF_BOUNDS »,
« message »: « "length" is outside of buffer bounds »
« exception »: true,
« date »: « Wed Sep 04 2024 12:18:48 GMT+0200 (Central European Summer Time) »,
« process »: {
« pid »: 50033,
« uid »: 1000,
« gid »: 1000,
« cwd »: « /var/www/peertube/versions/peertube-v6.2.1 »,
« execPath »: « /usr/bin/node »,
« version »: « v22.7.0 »,
« argv »: [
« /usr/bin/node »,
« /var/www/peertube/versions/peertube-v6.2.1/dist/server »
« memoryUsage »: {
« rss »: 591585280,
« heapTotal »: 115200000,
« heapUsed »: 107699016,
« external »: 123996548,
« arrayBuffers »: 120151676
« os »: {
« loadavg »: [
0.32,
0.51,
0.46
« uptime »: 69623.69
« trace »: [
« column »: 13,
« file »: « node:internal/buffer »,
« function »: « proto.utf8Write »,
« line »: 1066,
« method »: « utf8Write »,
« native »: false
« column »: 18,
« file »: « /var/www/peertube/versions/peertube-v6.2.1/node_modules/msgpackr/dist/node.cjs »,
« function »: « Packr.encodeUtf8 »,
« line »: 1211,
« method »: « encodeUtf8 »,
« native »: false
« column »: 15,
« function »: « pack »,
« line »: 1504,
« method »: null,
« native »: false
« column »: 5,
« function »: « packArray »,
« line »: 1418,
« method »: null,
« native »: false
« column »: 7,
« line »: 1604,
« method »: null,
« native »: false
« column »: 6,
« function »: « Packr.pack.encode »,
« line »: 1309,
« method »: « encode »,
« native »: false
« column »: 19,
« file »: « /var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/scripts.js »,
« function »: « Scripts.addStandardJob »,
« line »: 99,
« method »: « addStandardJob »,
« native »: false
« column »: 33,
« function »: « Scripts.addJob »,
« line »: 143,
« method »: « addJob »,
« native »: false
« column »: 29,
« file »: « /var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/job.js »,
« function »: « Job.addJob »,
« line »: 782,
« native »: false
« column »: 17,
« file »: « /var/www/peertube/versions/peertube-v6.2.1/node_modules/bullmq/dist/cjs/classes/flow-producer.js »,
« function »: « FlowProducer.addNode »,
« line »: 183,
« method »: « addNode »,
« native »: false
« column »: 39,
« function »: null,
« line »: 243,
« method »: null,
« native »: false
« column »: null,
« file »: null,
« function »: « Array.map »,
« line »: null,
« method »: « map »,
« native »: false
« column »: 22,
« function »: « FlowProducer.addChildren »,
« line »: 243,
« method »: « addChildren »,
« native »: false
« column »: 35,
« line »: 168,
« native »: false
« column »: 39,
« function »: null,
« line »: 243,
« method »: null,
« native »: false
« column »: null,
« file »: null,
« line »: null,
« native »: false
found the issue
lasst debian system update also updated nodejs
Node.js (nodejs)
  • Updated from: v22.5.0 to v22.7.0
  • Since PeerTube heavily relies on Node.js, any updates to the Node.js version could cause issues. If your error relates to runtime behavior or package management, consider rolling back Node.js to the previous version (22.5.0).
Rollback to v22.5
Seems like a nodejs bug: ERR_BUFFER_OUT_OF_BOUNDS error with Google Vision package on Node 22.7.0 · Issue #54518 · nodejs/node · GitHub
I suggest to stay on Node 20 (LTS)
