I first posted on the Brave forum, but then tested it on Firefox and got the same results. It looks like the player scaling for mobile browsers needs to be adjusted. Huawei P40 Lite Android 10
hi @bestperson
Thank you I just sent the feedback ![]()
And, that would be… Fennec, for mobile FF? Just asking, because recently I’ve jumped to Waterfox and Extensions are functioning >exactly< like desktop there. There isn’t some XML loader and /or whatever. So, perhaps worth giving it go (to see)?
EDIT:
Right, and I’m using: 1) uBlock Origin, and 2) Privacy Badger (EFF)
EDIT:
Also have to mention, about:config is needed for setting Advanced Preferences, and that list is quite long and rather impractical to even attempt to list here; some examples:
browser.cache.disk_enable (No caching, preserve your eMMC! :))
dom.serviceWorkers.enabled (This is among the most important, as it will limit most of the attack vectors and invalidate the Chromium advantage of page isolation, as nothing is loaded; expect unexpected website brakeage. :))
dom.event.clipboardevents.enabled (Private clipboard!)
dom.event.contextmenu.enabled (Get your context menu back, instead of local page overlay)
… There’s a whole bunch, a great project where all can be seen in user.js on GitHub, the Arkenfox project
extensions.htmlaboutaddons.recommendations.enabled
w00t! <3
No, it’s iceraven, but it’s the same in brave.
I’m sorry but I can’t reproduce. Could you post two screenshots of the same video, one at 100% and one at 110%? Which setting do you change to get 110%?
Первый это brave, второй firefox. При развороте видео как видно кнопка появляется
Thank you, the video helped a lot. What you see is the expected behaviour where PeerTube player has to hide buttons when there’s not enough space left.
Perhaps, but I’ll just describe the situation: for example, someone wants to use a constant 110% zoom level, due to vision problems or other reasons, and can’t control the player. In a single video, one button disappears, and in a playlist, two buttons disappear.
