I was running peertube via docker using the tag production-buster which means version 3.4 I believe. I now upgraded to production-bullseye and added the webserver to my docker-compose.yml. It now looks line this:
version: "3.3"
services:
webserver:
image: chocobozzz/peertube-webserver:latest
# If you don't want to use the official image and build one from sources:
# build:
# context: .
# dockerfile: Dockerfile.nginx
env_file:
- .env
# ports:
# - "80:80"
# - "443:443"
volumes:
- type: bind
# Switch sources if you downloaded the whole repository
#source: ../../nginx/peertube
source: ./docker-volume/nginx/peertube
target: /etc/nginx/conf.d/peertube.template
- assets:/var/www/peertube/peertube-latest/client/dist:ro
- ./docker-volume/data:/var/www/peertube/storage
- certbot-www:/var/www/certbot
- ./docker-volume/certbot/conf:/etc/letsencrypt
depends_on:
- peertube
restart: "unless-stopped"
networks:
- default
- caddy_net
peertube:
image: chocobozzz/peertube:production-bullseye
env_file:
- .env
volumes:
- ./docker-volume/data:/data
- ./docker-volume/config:/config
- /mnt/speicher/peertube/videos:/data/videos
- /mnt/speicher/peertube/streaming-playlists:/data/streaming-playlists
ports:
- "1935:1935"
networks:
default:
ipv4_address: 172.20.0.42
caddy_net:
postgres:
image: postgres:10-alpine
env_file:
- .env
volumes:
- ./docker-volume/db:/var/lib/postgresql/data
redis:
image: redis:6-alpine
volumes:
- ./docker-volume/redis:/data
# postfix:
# image: mwader/postfix-relay
# env_file:
# - .env
# volumes:
# - ./docker-volume/opendkim/keys:/etc/opendkim/keys
# labels:
# restart: "unless-stopped"
networks:
default:
ipam:
driver: default
config:
- subnet: 172.20.0.0/16
caddy_net:
external: true
volumes:
assets:
certbot-www:
Since I run all my services behind caddy, I disabled ssl in the webserver setting
# Minimum Nginx version required: 1.13.0 (released Apr 25, 2017)
# Please check your Nginx installation features the following modules via 'nginx -V':
# STANDARD HTTP MODULES: Core, Proxy, Rewrite, Access, Gzip, Headers, HTTP/2, Log, Real IP, SSL, Thread Pool, Upstream, AIO Multithreading.
# THIRD PARTY MODULES: None.
upstream backend {
server ${PEERTUBE_HOST};
server {
listen 80;
listen [::]:80;
server_name ${WEBSERVER_HOST};
error_log /var/log/nginx/peertube.error.log;
# Application
location @api {
proxy_set_header Host $host;
client_max_body_size 100k; # default is 1M
proxy_connect_timeout 10m;
proxy_send_timeout 10m;
proxy_read_timeout 10m;
send_timeout 10m;
proxy_pass http://backend;
location / {
try_files /dev/null @api;
location = /api/v1/videos/upload-resumable {
client_max_body_size 0;
proxy_request_buffering off;
location = /api/v1/videos/upload {
# on a dedicated filesystem.
client_max_body_size 12G; # default is 1M
add_header X-File-Maximum-Size 8G always; # inform backend of the set value in bytes before mime-encoding (x * 1.4 >= client_max_body_size)
client_max_body_size 6M; # default is 1M
add_header X-File-Maximum-Size 4M always; # inform backend of the set value in bytes before mime-encoding (x * 1.4 >= client_max_body_size)
# Websocket
location @api_websocket {
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
location /socket.io {
location /tracker/socket {
# Performance optimizations
gzip on;
gzip_vary on;
gzip_types # text/html is always compressed by HttpGzipModule
text/css
application/javascript
font/truetype
font/opentype
application/vnd.ms-fontobject
image/svg+xml;
gzip_min_length 1000; # default is 20 bytes
gzip_buffers 16 8k;
gzip_comp_level 2; # default is 1
client_body_timeout 30s; # default is 60
client_header_timeout 10s; # default is 60
send_timeout 10s; # default is 60
keepalive_timeout 10s; # default is 75
resolver_timeout 10s; # default is 30
reset_timedout_connection on;
proxy_ignore_client_abort on;
tcp_nopush on; # send headers in one piece
tcp_nodelay on; # don't buffer data sent, good for small data bursts in real time
# If you have a small /var/lib partition, it could be interesting to store temp nginx uploads in a different place
# See https://nginx.org/en/docs/http/ngx_http_core_module.html#client_body_temp_path
# Should be consistent with client-overrides assets list in /server/controllers/client.ts
location ~ ^/client/(assets/images/(icons/icon-36x36\.png|icons/icon-48x48\.png|icons/icon-72x72\.png|icons/icon-96x96\.png|icons/icon-144x144\.png|icons/icon-192x192\.png|icons/icon-512x512\.png|logo\.svg|favicon\.png|default-playlist\.jpg|default-avatar-account\.png|default-avatar-video-channel\.png))$ {
add_header Cache-Control "public, max-age=31536000, immutable"; # Cache 1 year
root /var/www/peertube;
try_files /storage/client-overrides/$1 /peertube-latest/client/dist/$1 @api;
add_header Access-Control-Allow-Origin '*';
add_header Access-Control-Allow-Methods 'GET, OPTIONS';
add_header Access-Control-Allow-Headers 'Range,DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type';
add_header Access-Control-Max-Age 1728000; # Preflight request can be cached 20 days
add_header Content-Type 'text/plain charset=UTF-8';
add_header Content-Length 0;
return 204;
add_header Cache-Control "public, max-age=7200"; # Cache response 2 hours
rewrite ^/static/(.*)$ /$1 break;
try_files $uri @api;
location ~ ^/static/(webseed|redundancy|streaming-playlists)/ {
limit_rate_after 5M;
set $peertube_limit_rate 800k;
# Increase rate limit in HLS mode, because we don't have multiple simultaneous connections
if ($request_uri ~ -fragmented.mp4$) {
set $peertube_limit_rate 5M;
#limit_rate $peertube_limit_rate;
# Or this line if your nginx < 1.17.0
set $limit_rate $peertube_limit_rate;
return 204;
access_log off;
sendfile on;
sendfile_max_chunk 1M; # prevent one fast connection from entirely occupying the worker process. should be > 800k.
aio threads;
You can find the default one here: https://raw.githubusercontent.com/Chocobozzz/PeerTube/master/support/nginx/peertube
Currently it seems like peertube is working, but the webinterface is broken. Meaning i can watch videos using newpipe, but the website is just white. Strangely I still get code 200 and the source code looks like the one from other instances.
Did I mess up the webserver config? I also have custom css and plugins installed. Could that case the problem?
