Categories-management-plugin TypeError
Hi, i installed the categories-management-plugin on Peertube v7.0.0 and when i try to use it i get the following error :
{"level":"error","message":{"stack":"TypeError: Cannot convert undefined or null to object\n    at Function.keys (<anonymous>)\n    at toArray (/home/yunohost.app/peertube/storage/plugins/node_modules/peertube-plugin-categories/src/enhancedCategories.js:2:10)\n    at toEnhancedCategories (/home/yunohost.app/peertube/storage/plugins/node_modules/peertube-plugin-categories/src/enhancedCategories.js:9:36)\n    at /home/yunohost.app/peertube/storage/plugins/node_modules/peertube-plugin-categories/src/index.js:87:34\n    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)","message":"Cannot convert undefined or null to object"},"label":"peertube.smtnco.net:443 peertube-plugin-categories","timestamp":"2025-01-17T10:10:35.855Z"}
First i thought of a syntax error in my definition of a new category but it does the same with the example provided with the plugin
{"add":[{"key":42,"label":"The meaning of life"}],"delete":[1]}
I tried also the syntax like in this post without any success
Any hint to help me make it work ?
Thank you
Hi, look at your peertube production.yaml config and try adding categories, i.e. will be 19, 20, 21, etc. but don’t delete
  categories:
#    - 1  # Music
#    - 2  # Films
#    - 3  # Vehicles
#    - 4  # Art
#    - 5  # Sports
#    - 6  # Travels
#    - 7  # Gaming
#    - 8  # People
#    - 9  # Comedy
#    - 10 # Entertainment
#    - 11 # News & Politics
#    - 12 # How To
#    - 13 # Education
#    - 14 # Activism
#    - 15 # Science & Technology
#    - 16 # Animals
#    - 17 # Kids
#    - 18 # Food
  "add": [
    {"key": 42, "label": "The meaning of life"},
    {"key": 19, "label": "Категория 19"},
    {"key": 20, "label": "Категория 20"},
    {"key": 21, "label": "Категория 21"}
i copied your code ("add:[« key »,etc…without delete) in the plugin windows and clicked update plugin settings.
i still have the same error in peertube.log and Internal Server Error below preview in the plugin page. No added category
I found the part listing categories in production.yaml file but what am i supposed to do with that ?
Thank you
If there are categories in the list that suit you, you can uncomment them and they will appear for you. if there are other plugins(maybe it conflicts). Maybe someone else will tell you)
Ok right, the categories listed in production.yaml are already available. What i want to do is adding my own categories.
As i tried to understand the error message, it seems that the object (categories) is null or undefined when called in by the file /home/yunohost.app/peertube/storage/plugins/node_modules/peertube-plugin-categories/src/enhancedCategories.js and then index.js
That’s where my knowledge of javascript stops. I don’t know why it happens and what to do to test and try to correct it.
Thanks anyway @bestperson for your answers
@bestperson Are you developer of this plugin?
What @manusim is talking about is the same issue I am facing
Below the input field where we have to add categories there is an error message
This is the problem we are trying to solve.
Hi, no developer, i user). Maybe it’s related to peertube version. You looked at your server logs?
Has anyone been able to get the plugin to work on PeerTube v7.0.1? I experience the exact same behaviour as described by @manusim. No additional log entries as far as I can see.
