is it somehow possible to add an onEnded Handler to an Embed Video? According to the PeerTube Embed API, « playbackStatusUpdate » should transmit the status « ended », but unfortunately it does not.
Greetings
Banzai
Greetings
Banzai
Is this the same issue: https://github.com/Chocobozzz/PeerTube/issues/2574 ?
NB: the fix is not released yet.
Is it possible to add the patch manually in an already running installation?
If you speak french, see the Chocobozzz response here: Procédure pour intégrer des modifications customs à son instance?
If you don’t speak french: there are 2 solutions.
