I would like to try PeerTube and I am stuck at one installation step in this guide [1]. I am exactly trying to accomplish the step [2]. There are few items I do not know how to fill.
I am trying to run PeerTube in Google Cloud Platform (GCP), in a Virtual Instance. I already have stuff going on there. I use GCP to host a few web apps using Apache mainly.
Now, I did install NGINX as required, and made it listen to port 81 (different from my Apache listening port). I installed PeerTube using the same folder structure in [1] i.e. in /var/www/peertube.
I do not know how to change the variables « port » in the entry « listen » and « webserver », and the variable « hostname » in the entry « webserver ».
listen:
hostname: 'localhost'
port: 9000
# Correspond to your reverse proxy server_name/listen configuration (i.e., your public PeerTube instance URL)
webserver:
https: true
hostname: 'example.com'
port: 443
My apps that use Apache are accessed using « example_com/apps/some_app ». I would like PeerTube to be accessed using « example_com/apps/mypeertube » [3].
How do I fill in the above to make this happen?
Cheers.
[1] https://github.com/Chocobozzz/PeerTube/blob/develop/support/doc/production.md
[2] Then edit the config/production.yaml file according to your webserver and database configuration (webserver , database , redis , smtp and admin.email sections in particular). Keys defined in config/production.yaml will override keys defined in config/default.yaml .
[3] I am using « example_com » instead of « example dot com » because this editor is making them into URLs and apparently I am too new to post URLs.
