after FINALLY successfully having peertube working on my setup:
i would like to know how to set up s3 storage.
I have read this:
however:
If I understood correctly, the s3 configuration goes into the yaml config file. as opposed to the json one.
Hence, on my current yunohost based installation, that is where it is at:
but on the docker based installation, two things:
the only mapped file, is the json one:
even more odd, if i go within the docker container, in /app/config
there doesnt seem to be a production.yaml?
so two questions in total:
- topic title, how do I enable s3 storage in docker based solution
- which yaml file is being applied?
thanks!!
another step closer…
