I’m going to try and upgrade again from 4.2.2 to 5.0.1
When the instructions say "You must update your nginx configuration:
We introduced a new location for plugin websocket routes: does that mean we add
Plugin websocket routes
location ~ ^/plugins/[^/]+(/[^/]+)?/ws/ {
to our existing nginx config file located at /etc/nginx/sites-available/peertube
Same thing for We introduced a new location for private videos files:
|location ~ ^(/static/(webseed|streaming-playlists)/private/)|^/download {
Thanks Keith
Hi Keith, I was struggling with the same. Eventually what I did is use the entire example config file for version 5.0.x (https://raw.githubusercontent.com/Chocobozzz/PeerTube/v5.0.0/support/nginx/peertube) as a template.
Make a copy of this and put it side to side with yours. I recommend using Notepad++.
Basically copy your specific config sections to this new file, save it and copy it over your existing file (overwriting it). Worked perfectly for me! Of course, make a backup first to you can always go back.
Hi.
The changelog says you need to add the whole [location](https://nginx.org/en/docs/http/ngx_http_core_module.html#location) block indicated. The link in the changelog shows the exact location block you need to copy, so yes, you will need to add this block:
# Plugin websocket routes
and this one:
# We can't rate limit a try_files directive, so we need to duplicate @api
proxy_set_header Host $host;
proxy_limit_rate 5M;
proxy_pass http://backend;
If you are not familiar with what locations block are in Nginx, I recommend you to read the Nginx documentation: Module ngx_http_core_module
When they are configuration modifications, you can use the diff command to see the différence, as it is said in the documentation
cd /var/www/peertube/versions
diff -u "$(ls --sort=t | head -2 | tail -1)/config/production.yaml.example" "$(ls --sort=t | head -1)/config/production.yaml.example"
diff -u "$(ls --sort=t | head -2 | tail -1)/support/nginx/peertube" "$(ls --sort=t | head -1)/support/nginx/peertube"
diff -u "$(ls --sort=t | head -2 | tail -1)/support/systemd/peertube.service" "$(ls --sort=t | head -1)/support/systemd/peertube.service"
Ok found the peertube-v5.0.1/Support/nginx file where is my current nginx file located at to compare of just copy the new one to
PLEASE disreguard looks like I am up
HOWEVER you might make a note that redis may need to be upgraded to something greater then 4.0.9
Thanks
