I realize that on Issue with fresh docker install (invalid client) I may have been trying to cover too much ground asking different questions. I would like to take a step back and cover the first one, the setup. Would anyone be so kind to check if what I am doing is right please?
From the top, I have following these instructions:
- SSH into server
- make a peertube root folder
- curl the compose yaml file and env
- then the following tree (if I dont I get the error:
« Error response from daemon: invalid mount config for type « bind »: bind source path does not exist: /home/user/docker/feditubo/docker-volume/nginx/peertube »
- docker-volume/certbot/conf
- docker-volume/data
- docker-volume/conf
- docker-volume/db
- docker-volume/nginx
- In short, all the directories mentioned in the compose yaml file
Here is my compose yaml file:
services:
You can comment this webserver section if you want to use another webserver/proxy or test PeerTube in local
webserver:
image: chocobozzz/peertube-webserver:latest
# If you don’t want to use the official image and build one from sources:
# build:
# context: .
# dockerfile: ./support/docker/production/Dockerfile.nginx
env_file:
- .env
ports:
- « 800:80 »
- « 4433:443 »
volumes:
- type: bind
# Switch sources if you downloaded the whole repository
#source: …/…/nginx/peertube
source: ./docker-volume/nginx/peertube
target: /etc/nginx/conf.d/peertube.template
- assets:/var/www/peertube/peertube-latest/client/dist:ro
- ./docker-volume/data:/var/www/peertube/storage
- certbot-www:/var/www/certbot
- ./docker-volume/certbot/conf:/etc/letsencrypt
depends_on:
- peertube
restart: « always »You can comment this certbot section if you want to use another webserver/proxy or test PeerTube in local
certbot:
container_name: certbot
image: certbot/certbot
volumes:
restart: unless-stopped
entrypoint: /bin/sh -c « trap exit TERM; while :; do certbot renew --webroot -w /var/www/certbot; sleep 12h & wait ${!}; done; »
depends_on:
- webserver
peertube:
# build:
# context: .
# dockerfile: ./support/docker/production/Dockerfile.bookworm
image: chocobozzz/peertube:production-bookworm
# Use a static IP for this container because nginx does not handle proxy host change without reload
# This container could be restarted on crash or until the postgresql database is ready for connection
networks:
default:
ipv4_address: 172.24.0.42
ipv6_address: fdab:e4b3:21a2:ef1b::42
env_file:
- .envports: - "1935:1935" # Comment if you don't want to use the live feature - "9000:9000" # Uncomment if you use another webserver/proxy or test PeerTube in local, otherwise not suitable for production volumes: # Remove the following line if you want to use another webserver/proxy or test PeerTube in local # - assets:/app/client/dist - ./docker-volume/data:/data - ./docker-volume/config:/config depends_on: - postgres - redis - postfix restart: "always"postgres:
image: postgres:13-alpine
env_file:
- .env
volumes:
- ./docker-volume/db:/var/lib/postgresql/data
restart: « always »redis:
image: redis:6-alpine
volumes:
- ./docker-volume/redis:/data
restart: « always »postfix:
image: mwader/postfix-relay
env_file:
- .env
volumes:
- ./docker-volume/opendkim/keys:/etc/opendkim/keys
restart: « always »networks:
default:
enable_ipv6: true
ipam:
driver: default
config:
- subnet: 172.24.0.0/16
- subnet: fdab:e4b3:21a2:ef1b::/64volumes:
assets:
certbot-www:
what did I change?
- Port 80 to 800 because its taken already
- Port 443 to 4433 because its taken already
- Commented the cerbot section since I am planning to use Nginx Proxy Manager with letsencrypt (already done)
- I changed the IPV4 address from 172.18.0.42 to 172.24.0.42 because its taken (probably a stupid question but… Do I need to change the IPV6 too?)
- Uncommented 9000 since I am planning to use it
- Commented - assets:/app/client/dist
- Changed 172.18.0.0/16 to 172.24.0.0/16 because its taken already
my .env:
Database / Postgres service configuration
POSTGRES_USER=somecoolusername
POSTGRES_PASSWORD=somecoolpassword
Postgres database name « peertube »
POSTGRES_DB=peertube
The database name used by PeerTube will be PEERTUBE_DB_NAME (only if set) OR ‹ peertube ›+PEERTUBE_DB_SUFFIX
#PEERTUBE_DB_NAME=
#PEERTUBE_DB_SUFFIX=_prod
Database username and password used by PeerTube must match Postgres’, so they are copied:
PEERTUBE_DB_USERNAME=$POSTGRES_USER
PEERTUBE_DB_PASSWORD=$POSTGRES_PASSWORD
PEERTUBE_DB_SSL=false
Default to Postgres service name « postgres » in docker-compose.yml
PEERTUBE_DB_HOSTNAME=postgres
PeerTube server configuration
If you test PeerTube in local: use « peertube.localhost » and add this domain to your host file resolving on 127.0.0.1
PEERTUBE_WEBSERVER_HOSTNAME=mywanip
If you just want to test PeerTube on local
PEERTUBE_WEBSERVER_PORT=9000
PEERTUBE_WEBSERVER_HTTPS=true
If you need more than one IP as trust_proxy
pass them as a comma separated array:
PEERTUBE_TRUST_PROXY=[« 127.0.0.1 », « loopback », « 172.24.0.0/16 »]
Generate one using
openssl rand -hex 32PEERTUBE_SECRET=somecoolsecret
E-mail configuration
If you use a Custom SMTP server
#PEERTUBE_SMTP_USERNAME=
#PEERTUBE_SMTP_PASSWORD=
Default to Postfix service name « postfix » in docker-compose.yml
May be the hostname of your Custom SMTP server
PEERTUBE_SMTP_HOSTNAME=postfix
PEERTUBE_SMTP_PORT=25
PEERTUBE_SMTP_FROM=noreply@mydomain
PEERTUBE_SMTP_TLS=false
PEERTUBE_SMTP_DISABLE_STARTTLS=false
PEERTUBE_ADMIN_EMAIL=admin@mydomain
Postfix service configuration
POSTFIX_myhostname=mydomain
If you need to generate a list of sub/DOMAIN keys
pass them as a whitespace separated string =
OPENDKIM_DOMAINS=mydomain=peertube
see Add OPENDKIM env config support by wader · Pull Request #18 · wader/postfix-relay · GitHub
OPENDKIM_RequireSafeKeys=no
PEERTUBE_OBJECT_STORAGE_UPLOAD_ACL_PUBLIC=« public-read »
PEERTUBE_OBJECT_STORAGE_UPLOAD_ACL_PRIVATE=« private »
#PEERTUBE_LOG_LEVEL=info
/!\ Prefer to use the PeerTube admin interface to set the following configurations /!\
#PEERTUBE_SIGNUP_ENABLED=true
#PEERTUBE_TRANSCODING_ENABLED=true
#PEERTUBE_CONTACT_FORM_ENABLED=true
I save both file, docker compose up, go to mydomain (which is npm pointing to mywanip:9000)
extract the root password:
docker compose logs peertube | grep -A1 root
peertube-1 | [95.216.202.44:9000] 2025-01-14 20:16:28.210 info: Username: root
peertube-1 | [95.216.202.44:9000] 2025-01-14 20:16:28.211 info: User password: supercooldefaultpassword
And I get the errors I have described in Issue with fresh docker install (invalid client)
First error:
peertube-1 | [mydomain:9000] 2025-01-04 21:17:59.148 error: Client log: Backend returned code 400, errorMessage is: Invalid client: client is invalid {
peertube-1 | "userAgent": "Mozilla/5.0 (X11; Linux x86_64; rv:128.0) Gecko/20100101 Firefox/128.0",
peertube-1 | "meta": "{\"url\":\"http://ip:9000/api/v1/users/token\"}",
peertube-1 | "url": "http://ip:9000/login"
peertube-1 | }
Second error:
peertube-1 | [mydomain:9000] 2025-01-04 21:14:17.715 error: Client log: Error: Cannot retrieve OAuth Client credentials: Getting client tokens for host myip:9000 is forbidden.
peertube-1 | Ensure you have correctly configured PeerTube (config/ directory), in particular the « webserver » section. {
peertube-1 | « userAgent »: « Mozilla/5.0 (X11; Linux x86_64; rv:128.0) Gecko/20100101 Firefox/128.0 »,
peertube-1 | « url »: « http://myip:9000/login »
peertube-1 | }
Am I following correctly the official docker setup instructions? I honestly ask; and I am just started to get familiar with docker. I learn every day… I use to use a Peertube installed via YunoHost.
Regarding the possible fix of the login error, I have absolutely no idea how to apply a patch / commit to a docker installation
I have no clue how to apply this Use $http_host instead of $host · Chocobozzz/PeerTube@6a03b50 · GitHub to my setup
Thank you very much for your time and help.
