I am following this guide step by step:
I have made on my host the peertube directory (and ./docker-volume/nginx/peertube)
download yaml and .env file, and tweak them to my needs:
docker-compose.yaml:
services:
# You can comment this webserver section if you want to use another webserver/proxy or test PeerTube in local
webserver:
image: chocobozzz/peertube-webserver:latest
# If you don't want to use the official image and build one from sources:
# build:
# context: .
# dockerfile: ./support/docker/production/Dockerfile.nginx
env_file:
- .env
ports:
- "82:80"
- "444:443"
volumes:
- type: bind
# Switch sources if you downloaded the whole repository
#source: ../../nginx/peertube
source: ./docker-volume/nginx/peertube
target: /etc/nginx/conf.d/peertube.template
- assets:/var/www/peertube/peertube-latest/client/dist:ro
- ./docker-volume/data:/var/www/peertube/storage
- certbot-www:/var/www/certbot
- ./docker-volume/certbot/conf:/etc/letsencrypt
depends_on:
- peertube
restart: "always"
# You can comment this certbot section if you want to use another webserver/proxy or test PeerTube in local
# certbot:
# container_name: certbot
# image: certbot/certbot
# volumes:
# - ./docker-volume/certbot/conf:/etc/letsencrypt
# - certbot-www:/var/www/certbot
# restart: unless-stopped
# entrypoint: /bin/sh -c "trap exit TERM; while :; do certbot renew --webroot -w /var/www/certbot; sleep 12h & wait ${!}; done;"
# depends_on:
# - webserver
peertube:
# build:
# context: .
# dockerfile: ./support/docker/production/Dockerfile.bookworm
image: chocobozzz/peertube:production-bookworm
# Use a static IP for this container because nginx does not handle proxy host change without reload
# This container could be restarted on crash or until the postgresql database is ready for connection
networks:
default:
ipv4_address: 172.22.0.42
ipv6_address: fdab:e4b3:21a2:ef1b::42
env_file:
- .env
ports:
- "1935:1935" # Comment if you don't want to use the live feature
- "9000:9000" # Uncomment if you use another webserver/proxy or test PeerTube in local, otherwise not suitable for production
volumes:
# Remove the following line if you want to use another webserver/proxy or test PeerTube in local
#- assets:/app/client/dist
- ./docker-volume/data:/data
- ./docker-volume/config:/config
depends_on:
- postgres
- redis
- postfix
restart: "always"
postgres:
image: postgres:13-alpine
env_file:
- .env
volumes:
- ./docker-volume/db:/var/lib/postgresql/data
restart: "always"
redis:
image: redis:6-alpine
volumes:
- ./docker-volume/redis:/data
restart: "always"
postfix:
image: mwader/postfix-relay
env_file:
- .env
volumes:
- ./docker-volume/opendkim/keys:/etc/opendkim/keys
restart: "always"
networks:
default:
enable_ipv6: true
ipam:
driver: default
config:
- subnet: 172.22.0.0/16
- subnet: fdab:e4b3:21a2:ef1b::/64
volumes:
assets:
certbot-www:
what did I change from the default one?
- network changed to 17.22.0. because 17.18.0 taken by other networks
- for webserver, host port changed from 82 because 80 taken
- same for 444 from 443 because already taken
- commented out certbot, because I will handle certs with nginx proxy manager / lets encrypt
.env:
# Database / Postgres service configuration
POSTGRES_USER=someusername
POSTGRES_PASSWORD=somepassword
# Postgres database name "peertube"
POSTGRES_DB=peertube
# The database name used by PeerTube will be PEERTUBE_DB_NAME (only if set) *OR* 'peertube'+PEERTUBE_DB_SUFFIX
#PEERTUBE_DB_NAME=<MY POSTGRES DB NAME>
#PEERTUBE_DB_SUFFIX=_prod
# Database username and password used by PeerTube must match Postgres', so they are copied:
PEERTUBE_DB_USERNAME=$POSTGRES_USER
PEERTUBE_DB_PASSWORD=$POSTGRES_PASSWORD
PEERTUBE_DB_SSL=false
# Default to Postgres service name "postgres" in docker-compose.yml
PEERTUBE_DB_HOSTNAME=postgres
# PeerTube server configuration
# If you test PeerTube in local: use "peertube.localhost" and add this domain to your host file resolving on 127.0.0.1
PEERTUBE_WEBSERVER_HOSTNAME=mydomain
# If you just want to test PeerTube on local
PEERTUBE_WEBSERVER_PORT=9000
PEERTUBE_WEBSERVER_HTTPS=true
# If you need more than one IP as trust_proxy
# pass them as a comma separated array:
PEERTUBE_TRUST_PROXY=["127.0.0.1", "loopback", "172.22.0.0/16"]
# Generate one using `openssl rand -hex 32`
PEERTUBE_SECRET=mysecret
# E-mail configuration
# If you use a Custom SMTP server
#PEERTUBE_SMTP_USERNAME=
#PEERTUBE_SMTP_PASSWORD=
# Default to Postfix service name "postfix" in docker-compose.yml
# May be the hostname of your Custom SMTP server
PEERTUBE_SMTP_HOSTNAME=postfix
PEERTUBE_SMTP_PORT=25
PEERTUBE_SMTP_FROM=noreply@mydomain
PEERTUBE_SMTP_TLS=false
PEERTUBE_SMTP_DISABLE_STARTTLS=false
PEERTUBE_ADMIN_EMAIL=admin@mydomain
# Postfix service configuration
POSTFIX_myhostname=mydomain
# If you need to generate a list of sub/DOMAIN keys
# pass them as a whitespace separated string <DOMAIN>=<selector>
OPENDKIM_DOMAINS=mydomain=peertube
# see https://github.com/wader/postfix-relay/pull/18
OPENDKIM_RequireSafeKeys=no
PEERTUBE_OBJECT_STORAGE_UPLOAD_ACL_PUBLIC="public-read"
PEERTUBE_OBJECT_STORAGE_UPLOAD_ACL_PRIVATE="private"
#PEERTUBE_LOG_LEVEL=info
# /!\ Prefer to use the PeerTube admin interface to set the following configurations /!\
#PEERTUBE_SIGNUP_ENABLED=true
#PEERTUBE_TRANSCODING_ENABLED=true
#PEERTUBE_CONTACT_FORM_ENABLED=true
then, I run docker compose up, go to ip:9000 (same happens with mydomain after I add a proxy host to ip:9000), try to login with root account (which password I got from running
docker compose exec -u peertube peertube npm run reset-password – -u root
But I get the error:
peertube-1 | [mydomain:9000] 2025-01-04 21:17:59.148 error: Client log: Backend returned code 400, errorMessage is: Invalid client: client is invalid {
peertube-1 | "userAgent": "Mozilla/5.0 (X11; Linux x86_64; rv:128.0) Gecko/20100101 Firefox/128.0",
peertube-1 | "meta": "{\"url\":\"http://ip:9000/api/v1/users/token\"}",
peertube-1 | "url": "http://ip:9000/login"
peertube-1 | }
I also get this other error btw:
peertube-1 | [mydomain:9000] 2025-01-04 21:14:17.715 error: Client log: Error: Cannot retrieve OAuth Client credentials: Getting client tokens for host myip:9000 is forbidden.
peertube-1 | Ensure you have correctly configured PeerTube (config/ directory), in particular the « webserver » section. {
peertube-1 | « userAgent »: « Mozilla/5.0 (X11; Linux x86_64; rv:128.0) Gecko/20100101 Firefox/128.0 »,
peertube-1 | « url »: « http://myip:9000/login »
peertube-1 | }
but my config directory is empty! there isnt the production etc yaml files. At which point are they supposed to be generated in this process?
The rest of the file structure, seems? to be correct?
Also, I would like to know if there is any way to pre configure, at deployment time, s3 storage. I have been trying to follow this:
And add the storage block to the docker compose, but I get the error those values are not accepted for the peertube service.
Thank you very much!
